No LiveVideo and /dev/fb0 when monitor unplugged from DP.
I got DiplayPort LiveVideo interface enabled, so I will get video data stream in PL for processing and output from PL to LVDS LCD panel. And everything works fine.
But if system boots without monitor - no /dev/fb0 appears until I plug monitor to DP and no video data coming from LiveVideo interface to PL (except clock which I get).
Plug - image on both monitor and LiveVideo, unplug monitor - no LiveVideo data.
How I can force/enable MaliGPU/FBDev to form image all the time - with or without monitor ?
I got it to work.
So, solution is:
1. Switch to current (as of 26July2018) master branch of Xilinx Kernel from github repo. It contains a patch which allow enable DP without PHY's attached/configured.
2. Add flag "e" to kernel cmd, in my case: video=DP-1:1024x768@60e
Hi @fanat9,
Which release are you using? In 2018.1 DP driver supports hotplug
fbdev isn't initialized until the entire DRM pipeline is enabled.
If the lvds driver is implemented as a drm encoder driver, that will format the entire pipeline, and the fbdev will be initialized properly
if not, the drm core will see the pipeline as not complete, and fbdev emulation doesn't happen.
Sandeep
Just switched to 2018.2
My design is just a PL converter/serializer of DP LiveVideo to LVDS based on XAPP1315 and I have to have it to work even if DP physically unplugged. I tried to pull DP_HPD_R line up and down, but it obviously failed to read EDID.
How I can force it always on? Its not possible to do thru devicetree?
So, I switched to new DP driver with this commit. which should allow init DP without PHY.
But it didn't help - if DP unplugged PLL shuts down, no clock/data on LiveVideo PS-to-PL, no FBDEV got created and etc.
Looking around I found next PL Display Driver description, but can't make sense of it. Can any body explain what it for and how to use it properly:
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/display/xlnx/xlnx%2Cpl-disp.txt
Thanks in advance!
I got it to work.
So, solution is:
I'm tryng to do the same thing :
  • DisplayPort enabled
  • EMIO output (No physical output pin)
  • No Lanes (= No PSGTR)
  • Custom output to PL
I've applied the commit mentionet before in config:
CONFIG_SUBSYSTEM_COMPONENT_LINUX__KERNEL_NAME_REMOTE_DOWNLOAD_PATH="git://github.com/Xilinx/linux-xlnx.git;protocol=https"
CONFIG_SUBSYSTEM_COMPONENT_LINUX__KERNEL_NAME_REMOTE_REFERENCE="99c43ab5afc0717cd6bace1a8667df2badc7b082"
I added also the flag "e" tokernel bootargs
setenv bootargs 'console=ttyPS0,115200 earlyprintk root=/dev/nfs nfsroot=10.0.0.1:/tftpboot/nfsroot,tcp ip=10.0.0.2:10.0.0.1:10.0.0.1:255.255.255.0:zynqmp:eth0:off rw video=DP-1:1280x1024@30e'
But if i enable the zynqmp_dpsub: zynqmp-display@fd4a0000 in the device tree:
&zynqmp_dpsub {
    status = "okay";
The kernel hang after ZynqMP DMA driver Probe success without any error.
could you help me?
Thank you
I go  ahead on my project but i created a post to follow on:
https://forums.xilinx.com/t5/Embedded-Linux/DP-Display-Port-Live-video-to-PL/m-p/896374#M29143
