Visitor miladmoo7
No framebuffer available while building Linux for Zedboard/QEMU-Zynq using Yocto
Hi there.
I am trying to build my custom Linux using Yocto and Poky reference design for Zedboard and Qemu-Zynq. However, I've had no luck adding X11 to my rootfs mainly because there is no framebuffer available and "/dev/fb0" doesn't exist, so X11 can not start.
I did some research and it turned out that I need to add some logic to my PL since HDMI is connected to PL instead of PS in Zedboards but I have no idea why there in no /dev/fb0 on QEMU-Zynq. I am using morty branch of Yocto and my machine name is "qemu-zynq7".
Is it possible to add some framebuffer to "qemu-zynq7" machine? It's available for "qemux86" so there's got to be a way.
Re: No framebuffer available while building Linux for Zedboard/QEMU-Zynq using Yocto
Hi @miladmoo7,
You need to implement the frame buffer in the PL (FPGA part) and connect it to the HDMI. Use the video frame buffer IP, this will create your fb0 entry:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842049/Video+Frame+Buffer+Read
