No "linux_bd_wrapper.bit" generated by "petalinux-package"
I just finished  petalinux-build on the Ultra96 using the lates ultra96 board support package.
Using the command
petalinux-package --boot --force --fsbl ./images/linux/zynqmp_fsbl.elf --fpga ./images/linux/linux_bd_wrapper.bit --u-boot
I got an error message
ERROR: Failed to generate BIF file, File ......images/linux/linux_bd_wrapper.bit doesn't exist.
I checked and in fact, linux_bd_wrapper.bit does not exist.
I am running petalinux on an ubuntu 16.04 virtual machine, as recommended in the docs.
Suggestions?
Thank You
Tom
Tags (2)
Re: No "linux_bd_wrapper.bit" generated by "petalinux-package"
Hi @miner_tom
Could you please check "linux_bd_wrapper.bit" present in your images/linux/ folder.
If that is not there , please check what is the name of bit file. By default it should be system.bit if you are using 2018.x/2019.1 sw.
petalinux-package --boot --force --fsbl ./images/linux/zynqmp_fsbl.elf --fpga ./images/linux/system.bit --u-boot
Thanks & regards
Aravind
Hi @miner_tom
Thanks & regards
Aravind
ptalinux doesnt generate the bit file, it just extracts it from the HDF (and renames and places it itn the images/linux directory).
When you exported to SDK from Vivado, did you tick the box to include the bitstream?
If not, then the bit file will not be here. However, you can just point to it in the command
petalinux-package --force --boot --fpga <path to the vivado project impl_1 folder where the bit is>.bit --u-boot
Thank you for your help.
Tom
