[OSL2018.2 manual build] FSBL stuck at build time message -> SD card boot
Hi All,
I'm currently making a bootable image the manual way for the ZynqMP.  When I boot my SD card the only thing showing is:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2   Nov 19 2018  -  10:04:17
I Can't figure out what's wrong. The next thing which should happen is the loading of the ATF bin file.
Here is my boot.bif file:
the_ROM_image:
        [bootloader,destination_cpu=a53-0] fsbl.elf
        [pmufw_image] pmufw.elf
        [destination_device=pl]  design_1_wrapper.bit
        [destination_cpu=a53-0, exception_level=el-3,trustzone] bl31.elf
        [destination_cpu=a53-0, exception_level=el-2] uboot.elf
The command I used:
 hsi::generate_app -hw design_1_wrapper.hdf  -app zynqmp_fsbl -os standalone -proc psu_cortexa53_0 -compile -verbose -sw fsbl -dir ./dir )
Inside the hdf file, the xml file states:
SYSTEMINFO BOARD="xilinx.com:zcu102:3.2" PART="xczu9eg-ffvb1156-2-e" ARCH="zynquplus" PACKAGE="ffvb1156" DEVICE="xczu9eg" SPEED="-2" LUT="274080" FF="548160" BRAM="912" DSP="2520
The only thing what was a bit weird is the fact I had to add the package name to the bootgen command line which I needed to do in order to avoid the error:  [ERROR]  : Partname 7z020clg400 in Bit file is incompatible with Zynq MP parts
bootgen -image "boot.bif" -arch zynqmp -w -o i "BOOT.bin"  -packagename xczu9eg -log trace
Edit:
Enabling the fsbl debug option gives me:  (last couple of printouts )
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x4
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0xF6EBF
Data word offset: 0xF6EBF
Total Data word length: 0xF6EBF
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0xF930
Partition Attributes: 0x26
Destination Device is PL, changing LoadAddress
Non authenticated Bitstream download to start now
DMA transfer done
XFSBL_ERROR_BITSTREAM_LOAD_FAIL
Partition 1 Load Failed, 0x37
================= In Stage Err ============
Fsbl Error Status: 0x0
Re: [OSL2018.2 manual build] FSBL stuck at build time message -> SD card boot
The FSBL compiling warning was a clue indeed. There has been messup with different bitstreams. We regenerated a clean .hdf file intended for the ZynqMP and cleared all the previous files.
Now it works, the bitstream was loaded well.
