Observer nikola.stojkov
Occasionally Linux boot freeze at Registering SWP/SWPB emulation handler
Hi everybody,
I am facing some strange behavior occasionally when booting Linux (Kernel: Linux-3.15.0) on Xilinx ZC706 development board,
lets say once in 10 times when rebooting device via power switch or with PS SRST button.
Console log and devicetree can be found in attachments.
[ 1.888114] mmc0: no vqmmc regulator found
[ 1.892126] mmc0: no vmmc regulator found
[ 1.927742] mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
[ 1.952826] si570 1-005d: registered, current frequency 148500000 Hz
[ 1.960528] TCP: cubic registered
[ 1.965860] NET: Registered protocol family 17
[ 1.970457] Registering SWP/SWPB emulation handler -- stuck after this line sometimes
[ 1.976190] RAMDISK: gzip image found at block 0 -- this line doesn't show
Any help will be appreciate.
Best regads!
Re: Occasionally Linux boot freeze at Registering SWP/SWPB emulation handler
Hi Nikola
Can you try disabling function clk_disable_unused() in drivers/clk/clk.c?
Best Regards
Shabbir
Can you try changing once the value of CONF_TMEOUT_MAX from (HZ*30) to (HZ*1). you can find this as a macro in:
<petalinux_install_dir>/components/linux-kernel/xlnx-3.15/net/ipv4/ipconfig.c
Best Regards
Shabbir
Thank you for reply!
Still the same issue. I got the same stalling after 20 times of rebooting at:
"Registering SWP/SWPB emulation handler"
Best Regards,
Nikola
Hi Nicola
Also can you please check the Interrupt configuration in the devicetree for the UART, something like below:
        uart@e0000000 {
            compatible = "xlnx,ps7-uart-1.00.a";
            reg = <0xe0000000 0x1000>;
            interrupts = <0x0 0x3B 0x4>;
            interrupt-parent = <0x1>;
            clock = <0x2faf080>;
Check specifically if interrupts are configured with proper details.
Best Regards
Shabbir
In zynq-7000.dtsi file this is the UART configuration:
uart0: serial@e0000000 {
compatible = "xlnx,xuartps";
status = "disabled";
clocks = <&clkc 23>, <&clkc 40>;
clock-names = "uart_clk", "pclk";
reg = <0xE0000000 0x1000>;
interrupts = <0 27 4>;
uart1: serial@e0001000 {
clocks = <&clkc 24>, <&clkc 41>;
reg = <0xE0001000 0x1000>;
interrupts = <0 50 4>;
As you see interrupts are different...
I will change IRQ as you proposed and let you know the result.
Br,
Nikola
HI,
Linux won't boot if i change IRQ for UART as you suggested.
According to Table 7-3 in TRM’s section 7.2.3, UART1′s interrupt number is 82. Since the first value is 0, it’s declared as a non-SPI, so the second value should be the hardware number minus 32, which is 50, or 0x32.
Do you think this is not ok?
Br,
Nikola
Anybody ?
Can someone shed light on this issue?
Hi Nikola
Best Regards
Shabbir
Hi shabbirk,
I did what you suggested and did 50 reboots on board without the problem!
Console log now looks like:
[ 2.006436] Registering SWP/SWPB emulation handler
[ 2.011853] clk: Not disabling unused clocks
[ 2.016567] RAMDISK: gzip image found at block 0
As I can see next line after " Registering SWP/SWPB emulation handler" is definitely clock disabling function.
Can you explain to me why sometimes boot is stuck on disabling unused clocks ?
Can i leave this as you suggested ? It won't affect any part of system if i leave it as a "PATCH"?
Br,
Nikola
Hi Nicolas
Glad that your problem has been solved.
Reason being we are enabling all the clocks irrespective of whether we use or not. It should not impact any functionality. And I also dont know in detail about this.
Best REgards
Shabbir
This is an old post, but I've run into similar problem. When starting the kernel it hangs on the lines
In my case it always hangs, not only occacionally.
I tried the accepted solution of disabling the disable_clk_unused() function by chaning the clk_ignore_unused  to false, but it still hangs.
