astromorgan
OpenCV Neon optimization on PetaLinux 2019.1
I'm building PetaLinux for the Zynq 7020. I have used the "petalinux-configure -c rootfs" to add opencv to the build, and this works fine.
When I run opencv applications in PetaLinux, I see that there is no NEON acceleration support. For example, running " std::cout << cv::getBuildInformation() << std::endl;" in my C++ app results in the following output:
General configuration for OpenCV 3.4.3 =====================================
  Version control:               unknown
  <snip>
CPU/HW features:
Baseline: NEON
requested: DETECT
disabled: VFPV3 NEON
<snip>
We would like to build OpenCV with NEON support enabled. How can we do that?
sandeepg
Hi @astromorgan ,
All the compiler flags can be passed from recipes using EXTRA_OEMAKE or CMAKE options as shown below.
$ mkdir -p <plnx-proj-root>/project-spec/meta-user/recipes-support/opencv
$ vim <plnx-proj-root>/project-spec/meta-user/recipes-support/opencv/opencv_%.bbappend
# opencv_%.bbappend content
EXTRA_OECMAKE_append_zynq = " -DENABLE_NEON=ON -DENABLE_VFPV3=ON"
Now cleanall opencv and rebuild.
$ petalinux-build -c opencv -x cleanall
Sandeep
sandeepg
Hi @astromorgan ,
By default we enable neon for Zynq-7000 in petalinux https://github.com/Xilinx/meta-xilinx/blob/rel-v2019.1/meta-xilinx-bsp/conf/machine/include/tune-zynq.inc#L1
Sandeep
astromorgan
Hi Sandeep,
I understand that NEON is enabled in PetaLinux OS in general. It looks to me like OpenCV doesn't use NEON unless it's compiled to. See here: https://docs.opencv.org/master/d0/d76/tutorial_arm_crosscompile_with_cmake.html
That page indicates there are two build flags (-DENABLE_NEON=ON and -DENABLE_VFPV3=ON) that need to be passed to the OpenCV library compilation to cause OpenCV to use the NEON co-processor. It looks like that isn't being done by default in PetaLinux 2019.1. Is there a way to add that compiler flag to the OpenCV recipe for PetaLinux?
Morgan
sandeepg
Hi @astromorgan ,
Sandeep
astromorgan
Thanks Sandeep. That worked great.
