Participant j_ney
OpenGl drm driver Zynq Ultrascale Ubuntu
Hey Guys,
I'm trying to implement a small OpenGL Application on the ZCU102. I think I've loaded all the necessary libraries but when I execute the program it says:
gbm: failed to open any driver (search paths /usr/lib/aarch64-linux-gnu/dri:${ORIGIN}/dri:/usr/lib/dri)
gbm: Last dlopen error: /usr/lib/dri/xilinx_drm_dri.so: cannot open shared object file: No such file or directory
failed to load driver: xilinx_drm
gbm: Last dlopen error: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: No such file or directory
failed to load driver: kms_swrast
opengl: main.cpp:49: int32_t main(int32_t, char**): Assertion `strstr (egl_extension_st, "EGL_KHR_create_context") != __null' failed.
Aborted
I activated the drm driver in Petalinux, but it doesn't seem to be there.
If I check the drivers with ubuntu-drivers list or ubuntu-drivers devices both doesnt show any output.
If I click on "Additional Drivers" in the settings it says "no additional drivers available".
I'm accessing the board over remote-desktop, could that be a problem?
If I connect a cable to the display port, there is no output on the screen and while booting there is the same message that drm driver loading fails:
[   28.224618] rc.local[3484]: gbm: failed to open any driver (search paths /usr/lib/aarch64-linux-gnu/dri:${ORIGIN}/dri:/usr/lib/dri)
[   28.244595] rc.local[3484]: gbm: Last dlopen error: /usr/lib/dri/xilinx_drm_dri.so: cannot open shared object file: No such file or directory
[   28.264519] rc.local[3484]: failed to load driver: xilinx_drm
[   28.280467] rc.local[3484]: gbm: failed to open any driver (search paths /usr/lib/aarch64-linux-gnu/dri:${ORIGIN}/dri:/usr/lib/dri)
[   28.300477] rc.local[3484]: gbm: Last dlopen error: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: No such file or directory
[   28.320517] rc.local[3484]: failed to load driver: kms_swrast
[   28.336680] rc.local[3484]: EGL_MESA_drm_image required.
As you see I'm a newbie regarding those topics, so I'd be happy if someone can help me.
Thanks for any replie!
Re: OpenGl drm driver Zynq Ultrascale Ubuntu
Hi, @j_ney
Have you solved the drm problem ?
I'm also facing similar problem running graphical applications on ubuntu on zynq.
Kang
Participant j_ney
Hi @hu_kang!
I didn't use OpenGl in the end, but I got the ubuntu desktop to work.
My main issue was that I connected the HDMI output wrong.
You need an active HDMI adapter that you connect to the Display Port of the board.
This one worked for me: https://www.amazon.de/gp/product/B01M5DX296/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Best regards,
Jonas
