PCI hot-pluggable support in Linux
Dear community,
I am facing a problem that involves too many things and I am not so sure where to put my attention.
Hope somebody of you could spread some light.
We built a custom board based on a spartan3A and a PCI bus.
If I program the FPGA and restart the PC the board is correctly seen and I can map the memory and so on.
But if I reprogram the bitstream on the fly and try to remap the memory I only read 0xff values.
I think I may need some sort of hot-pluggability in the FPGA PCI core implementation or the Linux system.
Are the PCI capabilities related (those output by lspci -vv)?
I am not using any particular driver in Linux, but simply remapping the physical address via mmap function.
In attachment I have uploaded the Linux application I am using to map memory.
Linux O.S. is Ubuntu 9.10 (kernel 2.6.32).
HW configuration on PCI core is as follows:
BEGIN plbv46_pci
 PARAMETER INSTANCE = PCI32_BRIDGE
 PARAMETER HW_VER = 1.03.a
 PARAMETER C_PCIBAR_LEN_0 = 22
 PARAMETER C_PCIBAR2IPIFBAR_0 = 0x8FC00000
 PARAMETER C_DEVICE_ID = 0x0300
 PARAMETER C_VENDOR_ID = 0x10EE
 PARAMETER C_CLASS_CODE = 0x060000
 PARAMETER C_REV_ID = 0x1A
 PARAMETER C_SUBSYSTEM_ID = 0xBEEF
 PARAMETER C_SUBSYSTEM_VENDOR_ID = 0xB0DE
 PARAMETER C_IPIFBAR_NUM = 1
 PARAMETER C_PCIBAR2IPIFBAR_1 = 0x83400000
 PARAMETER C_PCIBAR_LEN_2 = 24
 PARAMETER C_PCIBAR2IPIFBAR_2 = 0x89000000
 PARAMETER C_MAX_LAT = 0x54
 PARAMETER C_MIN_GNT = 0x32
 PARAMETER C_PCIBAR_LEN_1 = 18
 PARAMETER C_INCLUDE_PCI_CONFIG = 0
 PARAMETER C_NUM_IDSEL = 1
 PARAMETER C_BASEADDR = 0x86c08000
 PARAMETER C_HIGHADDR = 0x86c081ff
 PARAMETER C_IPIFBAR_0 = 0x90000000
 PARAMETER C_IPIF_HIGHADDR_0 = 0x9fffffff
 BUS_INTERFACE SPLB = mb_plb
 BUS_INTERFACE MPLB = mb_plb
 PORT PAR = fpga_0_PCI32_BRIDGE_PAR
 PORT PERR_N = fpga_0_PCI32_BRIDGE_PERR_N
 PORT SERR_N = fpga_0_PCI32_BRIDGE_SERR_N
 PORT IRDY_N = fpga_0_PCI32_BRIDGE_IRDY_N
 PORT FRAME_N = fpga_0_PCI32_BRIDGE_FRAME_N
 PORT DEVSEL_N = fpga_0_PCI32_BRIDGE_DEVSEL_N
 PORT STOP_N = fpga_0_PCI32_BRIDGE_STOP_N
 PORT TRDY_N = fpga_0_PCI32_BRIDGE_TRDY_N
 PORT INTR_A = fpga_0_PCI32_BRIDGE_INTR_A
 PORT GNT_N = fpga_0_PCI32_BRIDGE_GNT_N
 PORT REQ_N = fpga_0_PCI32_BRIDGE_REQ_N
 PORT IDSEL = fpga_0_PCI32_BRIDGE_IDSEL
 PORT AD = fpga_0_PCI32_BRIDGE_AD
 PORT CBE = fpga_0_PCI32_BRIDGE_CBE
 PORT PCLK = fpga_0_PCI32_BRIDGE_CLK
 PORT RST_N = fpga_0_PCI32_BRIDGE_RST_N
 PORT Bus2PCI_INTR = counter_FILO_PPS_F
END
Many thanks for any help you could provide.
Best regards,
Giulio
Re: PCI hot-pluggable support in Linux
PCI registers are set by OS (Linux) at boot time. When you reconfigure the FPGA these registers are erased.
So you need to force OS to reload these register.
I don't know about hot plug capacities of Linux. However you can try to force Linux to rescan its PCI buses.
Log as root and type :
echo "1" > /sys/bus/pci/rescan
For me it works on the ML605 board.
PS : /sys/bus/pci/rescan appears in the lastest version of the kernel, I don't know if your kernel already support it
