fpgalearner
Voyager
Voyager
PCIE driver (KC705 <-> ARM Yocto Linux)
Where I can get PCIE driver that is compatible with Xilinx Kc705 Eval board and ARM Yocto Linux?
sandeepg
Hi @fpgalearner,
All our pcie drivers are in https://github.com/Xilinx/linux-xlnx/blob/master/drivers/pci/host/pcie-xilinx.c
Refer our wiki page and see which driver are in mainline upstream or not http://www.wiki.xilinx.com/Linux+Drivers
If you are using Yocto I would suggest to use meta-xilinx and meta-xilinx-tools layer.
https://github.com/Xilinx/meta-xilinx/tree/rel-v2017.4
https://github.com/Xilinx/meta-xilinx-tools/tree/rel-v2017.4
Sandeep
fpgalearner
Voyager
Voyager
hi @sandeepg
I have the driver now.
As mentioned above I have connected PCIE interface of IMX7(ARM A7- Yocto-Linux) and KC705 FPGA EVAL board and both are set to Gen2, 1 Lane. https://www.nxp.com/products/processors-and-microcontrollers/applications-processors/i.mx-applications-processors/i.mx-7-processors/i.mx-7dual-processors-heterogeneous-processing-with-dual-arm-cortex-a7-cores-and-cortex-m4-core:i.MX7D
https://www.xilinx.com/support/documentation/boards_and_kits/kc705/ug810_KC705_Eval_Bd.pdf
When BARs size is set to 64 Megabytes(our requirement) in FPGA, IMX7 doesn’t support with standard Xilinx pcie driver and end up with following error:
root@imx7d-phyboard-zeta-001:/lib/modules# insmod /lib/modules/xpcie.ko
Base hw val 0
Base hw len 0
BAR0 of 0K
BAR0 of 0M
xpcie: Init: Could not remap memory.
insmod: ERROR: could not insert module /lib/modules/xpcie.ko: Operation not
permitted
but when BARs size is set to 4 Megabytes in FPGA, then IMX7 works. Is it due to limitation of IMX7 kernel memory size? I think default IMX7 kernel memory has to be increased by some means.
but I don't know how to increase default kernel memory size in Yocto. Is there any way for this? or there is another issue?
Relevant files are in attachment.
P.S. same Xilinx pcie driver in PC(Centos/Ubuntu) works for any setting.
venkata
This is a debug check:
If there are any other devices attached to IMX7 that need high BAR size to be allocated by Kernel, please check the possibility to remove them and connect KC705 alone with BAR size set to 64 Megabytes.
