PMUFW Mismatch - U-Boot from 2018.1 & PMUFW.elf from 2018.2
There is U-Boot.elf given to us by some other team. We are using that U-Boot.elf and packaging with pmufw.elf generated from 2018.2 and I am getting version mismatch. Can someone help with a workaround?
Fsbl, pmufw, asnd uboot versions must match.
What version is your uboot?
HI @nikeeag
You need to use the same version for  both u-boot & PMUFW.
We recomond to use same version only to avoid any unneccessary issues.
Thanks & regards
Aarvind
Aarvind and Stephen,
can we get a download link for prebuilt pmufw.elf 2018.1 link from somewhere?
You can build pmufw in SDK, or from git sources
Or, you can use the released images:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842543/Zynq+2018.2+Release
Or, you can use the 2018.1 board BSP, and use the prebuilt images here.
The pmufw would be common across all zynq ultrascale devices
Hi Stephenm,
Based on your suggestion, we tried 2018.1 BSP. We are using 2018.1 based U-Boot.
PMUFW, BL31, FSBL are all taken from pre-built folder, yet it is giving PMUFW mismatch error. But if we use directly the BOOT.BIN which came along with release folder along with uboot.elf which I have it is working fine.
Can you help how we localize the issue? Looks like it is a trivial problem. You can suggest where should we go and disable this error check.
Can you share the boot log
