Passing device name to gpio function
I am trying to build driver for my GPIO in xilinx board ZCU102
I can understand that we can define the GPIO pins in device tree file as below
while building the driver we shall use gpiod_get as below
My question is how to know or extract the "dev" parameter to pass it to "gpiod_get" arguments?
My background in hardware area so I don't know if it is tough or easy question but anyways I hope I can get your support
Re: Passing device name to gpio function
@moibrahim,
yes matching compatible fields
to access a specific one, you can use the optionnal name field you can provide in the devicetree:
dev_U0@address0{
     compatible="gpio-v1.0";
dev_U1@address1{
probe will be called because compatible values do match. To identify the devices, a quick way to do it would be..
device_probe(struct platform_device *pdev){
struct device_node *node;
node = pdev->dev.of_node;
// quick device discrimination int id = of_alias_get_id(node, "dev_U"); if (id < 0) // not specified id = 0; // default if (id == 1) printk(KERN_INFO "talking about device 1\n"); .... }
I am pretty sure the devicetree node API (#include <linux/of.h>) provides stuff to retrieve the address value too
G.W.,
NIST - Time Frequency metrology
@moibrahim,
this takes place in device_probe(struct platform_device *pdev) and device_release(struct platform_device *pdev).
The generic platform device structure embedds a generic struct *device structure (the "driver data"), which you can retrieve with *pdev->dev. In your custom driver you created a custom device structure, one of the main things your driver should do is customizing the generic device structure. Usually we do it this way:
device_probe(struct platform_dev *pdev){
struct my_dev *mdev;
mdev->dev = &pdev->dev; platform_set_drvdata(pdev, mdev);
line 2 allows you to work on pdev->dev directly too
G.W.,
@guillaumebresThanks a lot for your response.
Well, this will turn the question to be how to get "pdev" parameter?
I wanted to walk step be step on controlling my hardware (which is a GPIO controller).
So I thought I can use gpiod_get function to get a structure about my GPIO pins,
struct gpio_desc *gpiod_get(struct device *dev, const char *con_id, enum gpiod_flags flags);
then I can control it for isnstance using
int gpiod_direction_input(struct gpio_desc *desc);
int gpiod_get_value(const struct gpio_desc *desc);
I came accross this simple example for having overview of how the final driver should look like. But I want to walk step by step please as I have to learn it.
"pdev", platform device parameter, will match whatever you specified from the devicetree. This is specified @line 34 in your example. Any node in the devicetree matching "example" will call a seperate gpio_probe()
G.W.,
@guillaumebres,
I really apprciate your help. I still need to make it clear please,
matching with what in the device tree? (with the "compatible" field value ?)
If I have 2 GPIO modules (as in ch 6 of UG1209). How to access specific one?
Why can't I access my device simply using its address?
Thanks in Advance
@moibrahim,
dev_U0@address0{
dev_U1@address1{
G.W.,
@guillaumebres
Many Thanks for your replies it was very helpful for me.
Now I understand how it should be, but I got other problem here, that I wish you can contribute in.
