kallensf
Peta 2019.1 add fbtest
I saw:  http://petalinux.xilinx.com/sswreleases/rel-v2019/sdkupdate/esdks/arm/layers/meta-openembedded/meta-oe/recipes-test/fbtest/
I'd like to add this to my peta project but I only saw fbset in rootfs config.
I didn't find instructions on how to add it.  Can anyone reply with instructions or point me to a web page that has it?
Thanks in advance!
shabbirk
Hi @kallensf
You will have to add the package name as fb-test (IMAGE_INSTALL_append = " fb-test") in "project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend"
Enable it in rootfs and build. Upon boot, it appears as fb-test
Best regards
Shabbir
shabbirk
Hi @kallensf
Best regards
Shabbir
