jgiotis
PetaLinux 2017.1 Zynq 7030 USB Not working
We transitioned from PetaLinux 2014.4 to 2017.1 and found that the USB interface was no longer working.
After reviewing the many posts on this issue, and adjusting the device tree for host operation, the detection of the interface started working properly. We had to add custom udev rules because the device was not appearing under /dev automatically (as in 2014.4).
Note that we are using USB1 (and not USB0) and the reset is on MIO7. The USB1 portion of the device tree is:
   usb_phy1: usb_phy@1 {
   compatible = "ulpi-phy";
   #phy-cells = <0>;
   reg = <0xe0003000 0x1000>;
   view-port = <0x0170>;
   drv-vbus;
&usb1 {
  usb-phy = <&usb_phy1>;
  dr_mode = "host";
  usb-reset = <&gpio0 7 0>;
At boot time things appear normal. The interface is detected along with the USB stick:
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usbserial
e0003000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.1 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbhid: USB HID core driver
usb 1-1: new high-speed USB device number 2 using ci_hdrc
random: fast init done
usb 1-1: New USB device found, idVendor=0781, idProduct=5571
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: Cruzer Fit
usb 1-1: Manufacturer: SanDisk
usb 1-1: SerialNumber: 4C530007060503108534
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi host0: usb-storage 1-1:1.0
EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
/etc/mdev/mdev-mount.sh: line 28: [: /sys/block/mmcblk0/mmcblk0boot1: binary operator expected
mount: /dev/mmcblk0 is already mounted or /run/media/mmcblk0 busy
Starting udev
udevd[868]: starting version 3.2
udevd[869]: starting eudev-3.2
scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Fit       1.00 PQ: 0 ANSI: 6
sd 0:0:0:0: [sda] 62521344 512-byte logical blocks: (32.0 GB/29.8 GiB)
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
usb 1-1: reset high-speed USB device number 2 using ci_hdrc
Populating dev cache
tar: /dev/shm/udev-cache-tmp.tar: Wrote only 2048 of 10240 bytes
tar: Error is not recoverable: exiting now
udev-cache: update failed!
 sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
The problem is that when the USB memory stick is mounted we see a burst of device resets:
root@plnx_arm:~#
root@plnx_arm:~# mount /dev/sda1 /media/usb
sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 00 30 00 00 20 00
blk_update_request: I/O error, dev sda, sector 48
sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 00 30 00 00 08 00
Buffer I/O error on dev sda1, logical block 2, async page read
FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
root@plnx_arm:~# ls -l /media/usb
total 15680
-rwxr-xr-x 1 root root 16024600 Feb  5  2015 RunSanDiskSecureAccess_Win.exe
drwxr-xr-x 2 root root    16384 Feb 23  2015 SanDiskSecureAccess
-rwxr-xr-x 1 root root        0 Jan  1  1980 jimfile.txt
root@plnx_arm:~#
A similar burst of resets also happens when the device is unmounted.
As suggestions as to how to deal with this?
Thanks!
