Participant dtubbs
PetaLinux 2018.2 build fails on u-boot ... undefined references to find_mmc_device, mmc_get_blk_desc, mmc_init
Subject line describes the issue for Ubuntu 16.04 LTS, PetaLinux 2018.2, Zynq7000
Sequence:
- Fresh install of a new project
- petalinux-config --get-hw-description  (updated config options)
- petalinux-config -c rootfs   (updated rootfs options)
- petalinux-config -c kernel   (updated kernel options)
-petalinux-build
then:
ERROR: Task (/opt/xilinx/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/u-boot/u-boot-xlnx_2018.2.bb:do_compile) failed with exit code '1'
log shows:
...../build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot/xlnx/v2018.01-xilinx-v2018.2+gitAUTOINC+21812b5fd3-r0/git/drivers/dfu/dfu_mmc.c:30: undefined reference to 'find_mmc_device'
plus, same path and error with these functions:  mmc_get_blk_desc, mmc_init
Thanks for your help!
-Dave
Re: PetaLinux 2018.2 build fails on u-boot ... undefined references to find_mmc_device, mmc_get_blk_desc, mmc_init
If you dont need SD card functionality I'd recommend turning that config option off.
If you do need it - The needed drivers are not being compiled in. Check the u-boot source code where find_mmc_device is defined and then look at the Makefile which option is needed.
petalinux -c u-boot
Is a safer way to add config options rather than manually adding .cfg files
Otto
