Visitor rustiq
PetaLinux 2018.3 fails to fetch files at build time
Could you give me some advice on this bug. I'm running out of ideas.
I was following this simple guide to build PetaLinux for the Ultra96 board. For some reason petalinux-build fails to fetch lots of packages. This was not mentioned in the guide, so I assume my build environment is what breaks petalinux-build. The environment is Debian testing, not a VM, not behind NAT or a proxy. I tested on individual files that petalinux-build failed to fetch from remote URLs and they were manually downloadable from those URLs without any problem.
Error messages look as follows:
WARNING: harfbuzz-1.4.8-r0 do_package_qa_setscene: Failed to fetch URL file://b0/sstate:harfbuzz:aarch64-xilinx-linux:1.4.8:r0:aarch64:3:b00de525c9d6f3547d1095022cd08b4a_package_qa.tgz;downloadfilename=b0/sstate:harfbuzz:aarch64-xilinx-linux:1.4.8:r0:aarch64:3:b00de525c9d6f3547d1095022cd08b4a_package_qa.tgz, attempting MIRRORS if available
ERROR: harfbuzz-1.4.8-r0 do_package_qa_setscene: Fetcher failure: Unable to find file file://b0/sstate:harfbuzz:aarch64-xilinx-linux:1.4.8:r0:aarch64:3:b00de525c9d6f3547d1095022cd08b4a_package_qa.tgz;downloadfilename=b0/sstate:harfbuzz:aarch64-xilinx-linux:1.4.8:r0:aarch64:3:b00de525c9d6f3547d1095022cd08b4a_package_qa.tgz anywhere. The paths that were searched were:
    /opt/Xilinx/projects/xilinx-ultra96-reva-2018.3/build/sstate-cache
ERROR: harfbuzz-1.4.8-r0 do_package_qa_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /opt/Xilinx/projects/xilinx-ultra96-reva-2018.3/build/tmp/work/aarch64-xilinx-linux/harfbuzz/1.4.8-r0/temp/log.do_package_qa_setscene.10034
WARNING: libpcap-1.8.1-r0 do_package_qa_setscene: Failed to fetch URL file://04/sstate:libpcap:aarch64-xilinx-linux:1.8.1:r0:aarch64:3:0473ec10eda82bcaf73423cbfe01054a_package_qa.tgz;downloadfilename=04/sstate:libpcap:aarch64-xilinx-linux:1.8.1:r0:aarch64:3:0473ec10eda82bcaf73423cbfe01054a_package_qa.tgz, attempting MIRRORS if available
ERROR: libpcap-1.8.1-r0 do_package_qa_setscene: Fetcher failure: Unable to find file file://04/sstate:libpcap:aarch64-xilinx-linux:1.8.1:r0:aarch64:3:0473ec10eda82bcaf73423cbfe01054a_package_qa.tgz;downloadfilename=04/sstate:libpcap:aarch64-xilinx-linux:1.8.1:r0:aarch64:3:0473ec10eda82bcaf73423cbfe01054a_package_qa.tgz anywhere. The paths that were searched were:
ERROR: libpcap-1.8.1-r0 do_package_qa_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /opt/Xilinx/projects/xilinx-ultra96-reva-2018.3/build/tmp/work/aarch64-xilinx-linux/libpcap/1.8.1-r0/temp/log.do_package_qa_setscene.10035
WARNING: Setscene task (/opt/Xilinx/petalinux/components/yocto/source/aarch64/layers/core/meta/recipes-graphics/harfbuzz/harfbuzz_1.4.8.bb:do_package_qa_setscene) failed with exit code '1' - real task will be run instead
First the errors are about failed fetches from the local file system. They are followed by failed fetches from the network.
In a post dated 2017 someone suggested to run petalinux -x mrproper before building. I tried that and that didn't change anything.
