PetaLinux Documentation Error UG1144 v2019.2 and v2020.1
I noticed what I believe is an error in UG1144 for v2019.2
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1144-petalinux-tools-reference-guide.pdf
On page 121 under the section "Creating and Adding Patches For Software Components within a PetaLinux Project" step #7 reads:
"Once you have finished working on the recipe, run devtool reset <recipe-name>. It will remove the source directory for the recipe from workspace."
I believe the correct PetaLinux command which invokes the underlying devtool command is actually:
petalinux-build -c <recipe-name> -x reset
It looks like this was also copied into v2020.1 as well on page 146
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug1144-petalinux-tools-reference-guide.pdf
Devtool could be used directly as described in v2020.1, however the flow of the steps that lead to the command above is not the same workflow.
Ken Sloat - Embedded Software Engineer
https://www.designlinxhs.com
You are right. That is how it should be invoked. It is listed correctly on Table 9 (v2020.1) but got missed on page 146. Will report this to the doc team. Thanks
