armendzh
PetaLinux -- Unable to read file uImage
I have AVNET Mini-ITX 7z100 board and I been trying to use PetaLinux to build a linux image.
I am, however, unable to boot the uImage... not from the uImage which I created myself from the BSP files for the same board nor from the pre-built BIN and uImage files provided by AVNET.
Here is an error which I am receiving when trying to boot from SDCARD with BOOT.BIN and image.ub:
U-Boot 2015.04 (Apr 06 2016 - 13:45:26)
DRAM:  ECC disabled 1 GiB
MMC:   zynq_sdhci: 0
SF: Detected S25FL128S_64K with page size 512 Bytes, erase size 128 KiB, total 32 MiB
In:    serial
Out:   serial
Err:   serial
Net:   Gem.e000b000
Hit any key to stop autoboot:  0
Device: zynq_sdhci
Manufacturer ID: 3
OEM: 5054
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 58.3 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading uimage
** Unable to read file uimage **
U-Boot-PetaLinux> run shboot
## Error: "shboot" not defined
U-Boot-PetaLinux> run sdboot
reading uImage
** Unable to read file uImage **
Unknown command '
setenv' - try 'help'
Unknown command 'softdog.nowayout=0' - try 'help'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Here are commands which I used ot package my BIN and uImage files (I used both and both failed to boot):
petalinux-package --boot --force --format BIN --fsbl images/linux/zynq_fsbl.elf --fpga images/linux/zynq_design_1_wrapper.bit --u-boot --kernel -o image.ub
I also have another issue of booting the system (both mine and prebuilt) through JTAG. However, I am not sure if both issues are related (booting via JTAG and via SDcard). Here is what I am getting when trying to boot via JTAG:
INFO: Append dtb - /home/adzh/SBIR_MITX/petalinuxProject/MITX_7100_ED/pre-built/linux/images/system.dtb and other options to boot zImage
INFO: Launching XSDB for file download and boot.
INFO: This may take a few minutes, depending on the size of your image.
rlwrap: warning: your $TERM is 'xterm' but rlwrap couldn't find it in the terminfo database. Expect some problems.: Inappropriate ioctl for device
INFO: Configuring the FPGA...
INFO: Downloading bitstream to the target.
INFO: The XSDB log is as follows
Got $XILINX_SDK: /home/dzhagaryanaa/opt/Xilinx/SDK/2015.2
attempting to launch hw_server
****** Xilinx hw_server v2015.2
  **** Build date : Jun 26 2015-16:42:45
    ** Copyright 1986-1999, 2001-2015 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
Error in startup script:
No supported FPGA device found
    invoked from within
"::tcf::eval -progress ::xsdb::print_progress {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {process_tcf_actions_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress [dict get $arg chan]  [list process_tcf_actions_cache_client $argvar] $progress"
    (procedure "process_tcf_actions" line 1)
    invoked from within
"process_tcf_actions $arg ::xsdb::print_progress"
    (procedure "fpga" line 350)
    invoked from within
"fpga "/home/adzh/SBIR_MITX/petalinuxProject/MITX_7100_ED/pre-built/linux/implementation/download.bit""
mengle
Hi,you can try this:
  petalinux-config -c u-boot
in Menu:  Boot images
disable the "Enable signature verificatioin of FIT uImages"
armendzh
I am using PetaLinux 2015.2. I don't think I have u-boot option for petalinux-config. I only have kernel and rootfs which I can specify with -c.
I also had a bit of progress, but it now fails at DTB. I have renamed image file (image.ub) to uImage, and it seemed to like it better. However, after it finish reading the uImage, it tries to read dtb and fails.
I also had to disable "Copy final images to tftpboot" since I do not have access to tftp package on my Ubuntu 14.04 workstation.
U-Boot 2015.04 (Apr 07 2016 - 16:06:35)
MMC:   zynq_sdhci: 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
reading uImage
9356720 bytes read in 803 ms (11.1 MiB/s)
reading dtb
** Unable to read file dtb **
Unknown command '
reading uImage
9356720 bytes read in 802 ms (11.1 MiB/s)
reading dtb
Unknown command '
armendzh
Here is another error I got before:
U-Boot 2015.04 (Nov 11 2015 - 09:19:43)
MMC:   zynq_sdhci: 0
In:    serial
Out:   serial
Err:   serial
Net:   Gem.e000b000
reading uImage
9342036 bytes read in 798 ms (11.2 MiB/s)
reading dtb
Unknown command '
## Loading kernel from FIT Image at 03000000 ...
   Using 'conf@1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@1' kernel subimage
     Description:  PetaLinux Kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x030000f0
     Data Size:    9325091 Bytes = 8.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    crc32
     Hash value:   5222a91e
   Verifying Hash Integrity ... crc32+ OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
