nlbutts
PetaLinux - Video Pipeline Device Tree
I've built an image pipeline with an AXIS-Broadcast block to split the image pipeline into two different paths:
One path goes through the normal image pipeline and gets written into main memory as YUV data. The second path goes into a histogram generation block and then gets dumped into main memory as an RGB8 image. How do I represent this in a device tree. Below is what I've tried, but I get the following error message:
ERROR (duplicate_label): Duplicate label 'vcap_csi_in' on /amba_pl@0/vcap_csi/ports/port@1/endpoint and /amba_pl@0/vcap_csi/ports/port@0/endpoint
ERROR: Input tree has errors, aborting (use -f to force output)
Device tree:
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Tue Mar  5 15:40:10 2019
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		generate_histogram_0: generate_histogram@a0120000 {
			clock-names = "ap_clk";
			clocks = <&misc_clk_0>;
			compatible = "xlnx,generate-histogram-2.5";
			interrupt-names = "interrupt";
			interrupt-parent = <&gic>;
			interrupts = <0 95 4>;
			reg = <0x0 0xa0120000 0x0 0x10000>;
			xlnx,s-axi-axilites-addr-width = <0xc>;
			xlnx,s-axi-axilites-data-width = <0x20>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <240000000>;
			compatible = "fixed-clock";
		mipi_csi2_rx_subsyst_0: mipi_csi2_rx_subsystem@a0100000 {
			clock-names = "lite_aclk", "dphy_clk_200M", "video_aclk";
			clocks = <&misc_clk_1>, <&misc_clk_2>, <&misc_clk_0>;
			compatible = "xlnx,mipi-csi2-rx-subsystem-4.0", "xlnx,mipi-csi2-rx-subsystem-3.0";
			interrupt-names = "csirxss_csi_irq";
			interrupts = <0 90 4>;
			reg = <0x0 0xa0100000 0x0 0x10000>;
			xlnx,axis-tdata-width = <32>;
			xlnx,cal-mode = "NONE";
			xlnx,clk-io-swap = "false";
			xlnx,clk-lane-io-position = <0x1a>;
			xlnx,clk-lp-io-swap = "false";
			xlnx,csi-en-activelanes = "true";
			xlnx,csi-en-crc = "true";
			xlnx,csi-filter-userdatatype = "true";
			xlnx,csi-opt1-regs = "false";
			xlnx,csi-pxl-format = "RAW10";
			xlnx,csi2rx-dbg = <0x0>;
			xlnx,data-lane0-io-position = <0x2d>;
			xlnx,data-lane1-io-position = <0x20>;
			xlnx,data-lane2-io-position = <0x11>;
			xlnx,data-lane3-io-position = <0x29>;
			xlnx,dl0-io-swap = "false";
			xlnx,dl0-lp-io-swap = "false";
			xlnx,dl1-io-swap = "false";
			xlnx,dl1-lp-io-swap = "false";
			xlnx,dl2-io-swap = "false";
			xlnx,dl2-lp-io-swap = "false";
			xlnx,dl3-io-swap = "false";
			xlnx,dl3-lp-io-swap = "false";
			xlnx,dphy-lanes = <0x4>;
			xlnx,dphy-mode = "SLAVE";
			xlnx,en-active-lanes ;
			xlnx,en-bg0-pin0 = "false";
			xlnx,en-bg0-pin6 = "false";
			xlnx,en-bg1-pin0 = "true";
			xlnx,en-bg1-pin6 = "false";
			xlnx,en-bg2-pin0 = "false";
			xlnx,en-bg2-pin6 = "false";
			xlnx,en-bg3-pin0 = "true";
			xlnx,en-bg3-pin6 = "false";
			xlnx,en-clk300m = "false";
			xlnx,en-csi-v2-0 = "false";
			xlnx,en-exdesigns = "false";
			xlnx,en-timeout-regs = "false";
			xlnx,en-vcx = "false";
			xlnx,esc-timeout = <0x6400>;
			xlnx,exdes-board = "ZCU102";
			xlnx,exdes-config = "MIPI_Video_Pipe_Camera_to_Display";
			xlnx,exdes-fmc = "LI-IMX274MIPI-FMC V1.0 Single Sensor";
			xlnx,fifo-rd-en-control = "true";
			xlnx,hs-line-rate = <0x5a0>;
			xlnx,hs-settle-ns = <0x8d>;
			xlnx,hs-timeout = <0x10005>;
			xlnx,idly-group-name = "mipi_csi2rx_idly_group";
			xlnx,idly-tap = <0x1>;
			xlnx,init = <0x186a0>;
			xlnx,is-7series = "false";
			xlnx,max-lanes = <4>;
			xlnx,mipi-slv-int = <0x0>;
			xlnx,ppc = <2>;
			xlnx,share-idlyctrl = "false";
			xlnx,vc = <4>;
			xlnx,vfb ;
			csiss_ports: ports {
				#address-cells = <1>;
				#size-cells = <0>;
				csiss_port0: port@0 {
					/* Fill cfa-pattern=rggb for raw data types, other fields video-format and video-width user needs to fill */
					reg = <0>;
					xlnx,cfa-pattern = "rggb";
					xlnx,video-format = <12>;
					xlnx,video-width = <8>;
					csiss_out: endpoint {
						remote-endpoint = <&demosaic_in>;
				csiss_port1: port@1 {
					/* Fill cfa-pattern=rggb for raw data types, other fields video-format,video-width user needs to fill */
					reg = <1>;
		            csiss_in: endpoint {
		                data-lanes = <1 2 3 4>;
		                remote-endpoint = <&sensor_out>;
		misc_clk_1: misc_clk_1 {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
		misc_clk_2: misc_clk_2 {
			#clock-cells = <0>;
			clock-frequency = <200000000>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
        sensor_iic: i2c@a0130000 {
            #size-cells = <0>;
            clock-names = "s_axi_aclk";
            clocks = <&misc_clk_1>;
            compatible = "xlnx,axi-iic-2.0", "xlnx,xps-iic-2.00.a";
            interrupt-names = "iic2intc_irpt";
            interrupts = <0 94 4>;
            reg = <0x0 0xa0130000 0x0 0x1000>;
		    imx274: sensor@1a{
		        compatible = "sony,imx274";
		        reg = <0x1a>;
		        #size-cells = <0>;
		        reset-gpios = <&gpio 90 0>;
		        port@0 {
		            reg = <0>;
		            sensor_out: endpoint {
		                remote-endpoint = <&csiss_in>;
		v_demosaic_0: v_demosaic@a0140000 {
			compatible = "xlnx,v-demosaic-1.0", "xlnx,v-demosaic";
			interrupts = <0 91 4>;
			reg = <0x0 0xa0140000 0x0 0x10000>;
			reset-gpios = <&gpio 85 1>;
			xlnx,max-height = <2160>;
			xlnx,max-width = <3840>;
			xlnx,s-axi-ctrl-addr-width = <6>;
			xlnx,s-axi-ctrl-data-width = <32>;
            demosaic_ports: ports {
                #size-cells = <0>;
                demosaic_port0: port@0 {
                    /* For cfa-pattern=rggb user needs to fill as per BAYER format */
                    reg = <0>;
                    demosaic_in: endpoint {
                        remote-endpoint = <&csiss_out>;
                demosaic_port1: port@1 {
                    reg = <1>;
                    demosaic_out: endpoint {
                        remote-endpoint = <&gamma_in>;
		v_frmbuf_wr_0: v_frmbuf_wr@a0150000 {
			#dma-cells = <1>;
			compatible = "xlnx,v-frmbuf-wr-2.1", "xlnx,axi-frmbuf-wr-v2.1";
			interrupts = <0 93 4>;
			reg = <0x0 0xa0150000 0x0 0x10000>;
			reset-gpios = <&gpio 80 1>;
			xlnx,dma-addr-width = <32>;
			xlnx,dma-align = <16>;
			xlnx,pixels-per-clock = <2>;
			xlnx,s-axi-ctrl-addr-width = <0x7>;
			xlnx,s-axi-ctrl-data-width = <0x20>;
			xlnx,vid-formats = "rgb888", "bgr888", "xbgr8888", "xrgb8888", "uyvy", "y8", "vuy888", "xvuy8888", "yuyv", "nv12", "nv16";
		v_frmbuf_wr_1: v_frmbuf_wr@a0170000 {
			#dma-cells = <1>;
			interrupts = <0 96 4>;
			reg = <0x0 0xa0170000 0x0 0x10000>;
			reset-gpios = <&gpio 81 1>;
			xlnx,vid-formats = "rgb888", "bgr888", "xbgr8888", "xrgb8888";
        v_gamma_lut_0: v_gamma_lut@a0160000 {
            compatible = "xlnx,v-gamma-lut-1.0", "xlnx,v-gamma-lut";
            interrupts = <0 92 4>;
            reg = <0x0 0xa0160000 0x0 0x10000>;
            reset-gpios = <&gpio 86 1>;
            xlnx,s-axi-ctrl-addr-width = <13>;
            gamma_ports: ports {
                #size-cells = <0>;
                gamma_port0: port@0 {
                    reg = <0>;
                    gamma_in: endpoint {
                        remote-endpoint = <&demosaic_out>;
                gamma_port1: port@1 {
                    reg = <1>;
                    gamma_out: endpoint {
                        remote-endpoint = <&csc_in>;
		v_proc_ss_csc: v_proc_ss@a0110000 {
			clock-names = "aclk";
		    compatible = "xlnx,v-vpss-csc";
			reg = <0x0 0xa0110000 0x0 0x10000>;
			reset-gpios = <&gpio 84 1>;
			xlnx,colorspace-support = <2>;
			xlnx,csc-enable-window = "false";
			xlnx,num-video-components = <3>;
			xlnx,samples-per-clk = <2>;
			xlnx,topology = <3>;
			xlnx,use-uram = <0>;
			csc_ports: ports {
				#size-cells = <0>;
				csc_port0: port@0 {
					/* For xlnx,video-format user needs to fill as per their requirement */
					reg = <0>;
					csc_in: endpoint {
						remote-endpoint = <&gamma_out>;
				csc_port1: port@1 {
					reg = <1>;
					csc_out: endpoint {
						remote-endpoint = <&scaler_in>;
		v_proc_ss_scaler: v_proc_ss@a0180000 {
			clock-names = "aclk_axis", "aclk_ctrl";
			clocks = <&misc_clk_0>, <&misc_clk_0>;
		    compatible = "xlnx,v-vpss-scaler";
			reg = <0x0 0xa0180000 0x0 0x40000>;
			reset-gpios = <&gpio 82 1>;
			xlnx,colorspace-support = <0>;
			xlnx,csc-enable-window = "true";
			xlnx,enable-csc = "true";
			xlnx,h-scaler-phases = <64>;
			xlnx,h-scaler-taps = <6>;
			xlnx,max-num-phases = <64>;
			xlnx,num-hori-taps = <6>;
			xlnx,num-vert-taps = <6>;
			xlnx,pix-per-clk = <2>;
			xlnx,scaler-algorithm = <2>;
			xlnx,topology = <0>;
			xlnx,use-uram = <1>;
			xlnx,v-scaler-phases = <64>;
			xlnx,v-scaler-taps = <6>;
			scaler_ports: ports {
				#size-cells = <0>;
				scaler_port0: port@0 {
					reg = <0>;
					scaler_in: endpoint {
						remote-endpoint = <&csc_out>;
				scaler_port1: port@1 {
					reg = <1>;
					scaler_out: endpoint {
						remote-endpoint = <&vcap_csi_in>;
		misc_clk_3: misc_clk_3 {
			#clock-cells = <0>;
			clock-frequency = <33329951>;
		vcap_csi {
			compatible = "xlnx,video";
			dma-names = "port0";
			dmas = <&v_frmbuf_wr_0 0>, <&v_frmbuf_wr_1 0>;
			vcap_ports: ports {
				#size-cells = <0>;
				vcap_port: port@0 {
					direction = "input";
					reg = <0>;
					vcap_csi_in: endpoint {
						remote-endpoint = <&scaler_out>;
				vcap2_port: port@1 {
					reg = <0>;
There must be a way to have two DMA blocks that write different types of data at the same time.
gsatish10
Looks like this issue is present in wrong community,
There is other community forum for Xiinx Embedded desgin forum, that makes more help for this as it is related to Custom design of Xilinx Vivado design
Thanks & Regards
Satish G
G Satish Kumar
hello @nlbutts ,
it is normal you have this error. you couldn't name two different port with the same name and point to them. it is confusing for device to to build it.
vcap_csi {
			vcap_ports: ports {
				#size-cells = <0>;
				vcap_port: port@0 {
					reg = <0>;
					reg = <0>;
you need to change the name. and you can just add two separate vcap one connected to demosaic an the other to scaler.
