ralphkw1
Petalinux 15.4 Add I2C support to u-boot
I am trying to add I2C support to an existing project that is currently using Petalinux 15.4 on the ZC706. I have searched and added the following to the project.
To <project>/subsystems/linux/configs/u-boot/config:
CONFIG_CMD_I2C=y
To <project>/subsystems/linux/configs/u-boot/platform-top.h:
/* Configure I2C support. */
#define CONFIG_SYS_I2C_ZYNQ
#if defined(CONFIG_SYS_I2C_ZYNQ)
/*# define CONFIG_CMD_I2C*/
# define CONFIG_SYS_I2C
# define CONFIG_SYS_I2C_ZYNQ_SPEED 100000
# define CONFIG_SYS_I2C_ZYNQ_SLAVE 0
#endif
Our device tree:
i2c0: i2c@e0004000 {
compatible = "cdns,i2c-r1p10";
status = "disabled";
clocks = <&clkc 38>;
interrupt-parent = <&intc>;
interrupts = <0 25 4>;
reg = <0xe0004000 0x1000>;
#address-cells = <1>;
#size-cells = <0>;
i2c1: i2c@e0005000 {
clocks = <&clkc 39>;
interrupts = <0 48 4>;
reg = <0xe0005000 0x1000>;
#size-cells = <0>;
&i2c0 {
clock-frequency = <400000>;
status = "okay";
I now get the I2C in the command set, but unfortunately when I boot, I get the following. I also get this when I try any u-boot i2c command on the u-boot command line.
U-Boot 2015.07 (May 03 2018 - 11:31:43 -0500)
I2C: Error, wrong i2c adapter 0 max 0 possible
ready
DRAM: ECC disabled 512 MiB
MMC: zynq_sdhci: 0
SF: Detected N25Q512A with page size 256 Bytes, erase size 4 KiB, total 64 MiB
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
U-Boot-PetaLinux> i2c md 0x70 0.0 1
Any suggestions on how to get u-boot to support I2C?
BR,
Ralph
ralphkw1
I debugged down to seeing the adapter is invalid, that's when I found I should be setting:
#define CONFIG_ZYNQ_I2C0
#define CONFIG_ZYNQ_I2C1
So now I don't get the initialization error anymore. Have not tested accessing the devices yet. That will be tomorrow :).
ralphkw1
