marcoventurini
Petalinux 2016.4 Kernel patch
I have  simple question about applying a patch to the linux kernel with Petalinux 2016 04.
according to this guide:
https://forums.xilinx.com/t5/Embedded-Linux/how-to-add-or-modify-petalinux-2016-4-yocto-kernel-source-or/td-p/742861
I should create the patch file and then modify the recipe inside
 <plnx-proj-root>/project-spec/meta-user/recipes-kernel/linux/
but this folder does not exist inside my project, the kernel recipe is here
 <plnx-proj-root>/project-spec/meta-plnx-generated/recipes-kernel/
... and it can't be modified because it's auto generated.
What am I doing wrong?
Marco
jovitac
All changes need to be made in the meta-user directory. You will need to create the  <plnx-proj-root>/project-spec/meta-user/recipes-kernel/linux/  if it is not present.
wiki section #Patching the Linux Kernel of a PetaLinux Project in link below
http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips
marcoventurini
I will look into it, for now i will just use the external sources.
