rgallic_incjet
Petalinux 2016.4 and ZCU102 BSP 2016.4 - Function failed: do_deploy
I have loaded Petalinux 2016.04, Vivado 2016.
Under Petalinux 2013.04 I was able to generate a BSP for petalinux using xsdk.
When I try to to the same with the 2016.04 version of XSDK, import the hdf file generated by Vivado 2016.03, I do not see any option to create a Petalinux bsp, only options are standalone or freertos.
Is it possible to build a petalinux BSP using xsdk 2016?
Is the hdf file generated by Vivado 2016.03 compatible with petalinux 2016.04?
What am I missing?
rgallic_incjet
Title should have been How Do I Generate a Petalinux BSP file, petalinux 2016.04.
