02-03-2017 02:44 PM
When I try to import the HW description from my Vivado project, I get segfault:
wzab@isw:~/petalinux/multi_eth1$ petalinux-config --get-hw-description=/home/wzab/test16.4/Xilinx-ZCU102-2016.2/Xilinx-ZCU102-2016.2.sdk/design_1_wrapper_hw_platform_0 INFO: Getting hardware description... [INFO] generating Kconfig for project [INFO] menuconfig project /home/wzab/petalinux/multi_eth1/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported /home/wzab/petalinux/multi_eth1/build/misc/config/Kconfig:546:warning: config symbol defined without type configuration written to /home/wzab/petalinux/multi_eth1/project-spec/configs/config *** End of the configuration. *** Execute 'make' to start the build or try 'make help'. [INFO] sourcing bitbake ERROR: Failed to source bitbake webtalk failed:Invalid tool in the statistics file:petalinux-yocto! webtalk failed:Failed to get PetaLinux usage statistics! ERROR: Failed to config project. ERROR: Get hw description Failed!. sh: line 1: 25922 Segmentation fault (core dumped) /home/xl/petalinux-2016.4/tools/webtalk/bin/unwrapped/lnx64.o/xilproxy > /home/wzab/petalinux/multi_eth1/.Xil/Webtalk-25918-isw/webtalk/xilproxy.log 2>&1
An attempt to analize the core file with gdb does not provide any useful information:
$ gdb --corefile=core gdb: unrecognized option '--corefile=core' Use `gdb --help' for a complete list of options. wzab@isw:~/petalinux/multi_eth1$ gdb --core=core GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.04) 7.11.1 Copyright (C) 2016 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word". [New LWP 25922] Core was generated by `/home/xl/petalinux-2016.4/tools/webtalk/bin/unwrapped/lnx64.o/xilproxy'. Program terminated with signal SIGSEGV, Segmentation fault. #0 0x0000000000000000 in ?? () (gdb) bt #0 0x0000000000000000 in ?? () #1 0x00007ff033950a1e in ?? () #2 0x00000000ac9f08a7 in ?? () #3 0x0000000000000000 in ?? () (gdb) #0 0x0000000000000000 in ?? () #1 0x00007ff033950a1e in ?? () #2 0x00000000ac9f08a7 in ?? () #3 0x0000000000000000 in ?? () (gdb)
Is there any solution known for that problem? Maybe the main problem is "ERROR: Failed to source bitbake"?
How to resolve that?
TIA & Regards,
Wojtek
02-04-2017 02:20 AM - edited 02-04-2017 03:30 AM
OK. It's my fault. I have attempted to install Petalinux for all users as root, and I have missed the following error message:
INFO: Checking installation environment requirements... INFO: Checking free disk space INFO: Checking installed tools INFO: Checking installed development libraries INFO: Checking network and other services INFO: Installing PetaLinux SDK to "/home/xl/petalinux-v2016.4/." INFO: Installing PetaLinux zynqMP Yocto SDK to "/home/xl/petalinux-v2016.4/./components/yocto/source/aarch64"... PetaLinux Extensible SDK installer version 2016.4 ================================================= ERROR: The extensible sdk cannot be installed as root. ********************************************* ERROR: Failed to install Yocto SDK for zynqMP. ********************************************* Please refer to the PetaLinux Tools Installation Guide. Check the troubleshooting guide at the end of that manual, and if you are unable to resolve the issue please contact customer support with file: /home/wzab/Downloads/petalinux_installation_log
I have reinstalled PetaLinux as a normal user, and it has solved the problem!
Wojtek
Wojtek
02-04-2017 03:40 AM - edited 02-04-2017 03:52 AM
Hmmm, in fact xilproxy still fails:
[INFO] generating petalinux-user-image.bb Generate petalinux-user-image bb file webtalk failed:Invalid tool in the statistics file:petalinux-yocto! webtalk failed:Failed to get PetaLinux usage statistics! sh: line 1: 15808 Segmentation fault (core dumped) /home/xl/petalinux-v2016.4/tools/webtalk/bin/unwrapped/lnx64.o/xilproxy > /home/wzab/petalinux/multi_eth1/.Xil/Webtalk-15804-isw/webtalk/xilproxy.log 2>&1
petalinux-yocto is available in tools/common/petalinux/utils , but it is not added to the PATH by sourcing of "settings.sh".
I have added it afterwards with:
export PATH=/home/xl/petalinux-v2016.4/tools/common/petalinux/utils:$PATH
The above eliminates complaints about "petalinux-yocto", but xilproxy still segfaults:
[INFO] generating petalinux-user-image.bb sh: line 1: 27703 Segmentation fault (core dumped) /home/xl/petalinux-v2016.4/tools/webtalk/bin/unwrapped/lnx64.o/xilproxy > /home/wzab/petalinux/multi_eth1/.Xil/Webtalk-27699-isw/webtalk/xilproxy.log 2>&1 [INFO] successfully configured rootfs
However, I can configure the system with different modes of "petalinux-config" and build the image with "petalinux-build", so I do not consider it to be an important problem.
Wojtek
05-15-2017 06:29 AM
Could you explan what other modes you used? Thank you
07-06-2017 11:17 AM
The segfault is being caused by webtalk. You can turn it off in your project by using the command:
petalinux-util --webtalk off
