[Petalinux 2017.2] Failed to source bitbake
I have just installed Petalinux in my home folder without using root. The directory where it is installed is /home/myuser/petalinux so I am also not using uppercase letters. The installation seems to be ok. I also created a folder in my home (without sudo) called petalinux_prjts. So, I went into the folder and executed `petalinux-create -t project -s ~/Downloads/avnet-digilent-zedboard-v2017.2-final.bsp`. This also seems to worked. But when I try to build it petalinux-build I get an error saying that it `Failed to source bitbake`and `Failed to build project`.
Checking other threads they recommend not to install petalinux with sudo, which is what I did the first time in /opt. After I read this, I deleted the folder /opt/Petalinux (with sudo rm -rf). Besides, now that it is installed in my home folder, I am also sourcing the settings.sh file from /home/myuser/petalinux/settings.sh.
What could be the issue that it cannot source bitbake?
Thank for the help.
Re: [Petalinux 2017.2] Failed to source bitbake
I have just testede version 2017.3 on a clean ubuntu installation and everything worked fine. I sourced:
/home/user/Xilinx/Petalinux/settings.sh
/home/user/Xilinx/Petalinux/components/yocto/source/aarch64/environment-setup-aarch64-xilinx-linux
Thanks for all the help / suggestions.
I did not get this correctly:-
Try changing its name to petalinux-prjts
Best Regards
Shabbir
Visitor uscmule
I have pretty much the same problem.
My petlinux is installed as a normal user in /opt
I created a project with:
petalinux-create --type project --template zynq -s /opt/bsps/xilinx-zc702-v2017.2-final.bsp --name petatest1
The config with:
petalinux-config --oldconfig
[INFO] generating Kconfig for project
[INFO] oldconfig project
[INFO] sourcing bitbake
ERROR: Failed to source bitbake
ERROR: Failed to config project.
petalinux-build produces the same output
Any help would be appreciated!
It seems that it is not a path naming issue. It does not matter how the folders are called, it is the same thing.
There might bi something wrong with bitbake as it cannot be sourced. Even if I type bitbake I get that it is an unknown command.
I saw that in petalinux's folder I should have components/yocto/source/aarch64/environment-setup-aarch64-xilinx-linux. I do not have the `environment-setup-aarch64-xilinx-linux` folder. Perhaps this is the reason? bitbake has not even been installed on my system.
I just tested petalinux 2016.4 and besides sourcing the setting.sh script, I also sourced /opt/pkg/petalinux/components/yocto/source/aarch64/environment-setup-aarch64-xilinx-linux and /opt/pkg/petalinux/components/yocto/source/arm/environment-setup-cortexa9hf-neon-xilinx-linux-gnueabi and I was able to build the project. Still, I could not reproduce this on petalinux 2017.2. Therefore, for now I should switch to 2016.4 until a solution is found.
Hopefully someone has been through the same issue and has solved it.
I have documented the flow I used to install Petalinux on my VM. This might be helpful
Visitor uscmule
You chown the /opt directory for a non-privileged user, but then note that the installer should be run as root.... why?
Visitor uscmule
I created an ubuntu 16.04 lts vm as your instructions describe, and am now able to build petalinux. So, thanks for the help.
It seems unreasonable that the same build did not work in debian stretch.
Is there anyway you guys can release a docker image of the petalinux install to avoid this type of "works on my machine" configuration issue?
I saw the same error message in my build today.  In my case, I ran petalinux-config to add a user layer and had a problem in the path.  I looked at the build.log file which pointed to the problem.  Once I fixed the problem, petalinux-build worked fine.  The error message is unfortunate because the problem is not really with "can not source bitbake".  In any case, take a look at your log file and fix any problems indicated in the file and see if your problem goes away.
It seems to be related to default version of python aliased by /usr/bin/python.  I'm on Ubuntu 17.10 and I started with this:
lukasz@workstation:~/projects/petalinux/first$ petalinux-build
[INFO] building project
ERROR: Failed to build project
when my default python was set to:
lukasz@workstation:~$ which python
/home/lukasz/anaconda3/bin/python
when switched to python 2, bitbake was successfully located and the build went on.
One of the ways to temporarily set python 2 as the default is described here - https://stackoverflow.com/a/7237949
Hi @lukaszlaszko,
We don't support Ubuntu-17.
Refer UG1144 pasge 8 for more details.
Also https://www.xilinx.com/support/answers/69372.html has package list you can install the sw packages.
Sandeep
Visitor venturezhao
Hi, guys. I also meet this problem and fixed it just now. The reason caused such problem is version mismatch of python. Please make sure your default python is 2.xx. Then the 'petalinux-config' works well.
Visitor venturezhao
Hello. Yes, I also find that it is the problem of default version of python. Moreover, it is not the link of '/usr/bin/python'. Instead it depends on the environment configuration of python.
For me, I use anaconda and virtualenv of conda. So it is no need to change the default version of python, just change the current shell into virtualenv of python=2.7. Then the petalinux works well.
I had this problem with Ubuntu 18.04, PetaLinux Tools 2018.2.
For me, the problem was related to an issue in the installer preventing the necessary software from being installed.
The shim from this post seemed to fix it for me. ("PetaLinux 2018.1 Install Fails on Debian Stretch"), however, I needed to leave it in place indefinitely.
Also, be careful moving the installation folder after you've installed petalinux. There are a few hard-coded paths in various folders that could get confused if you try, for example, moving petalinux from ~/ to /opt/.
Visitor philippos
Same error with Petalinux 2018.2 on Fedora Linux 28
The problem was related to a missing package and you can find this information by running devtool after sourcing
after i uninstall Anaconda it works.
i hope it worls also for you if you try it.
Observer eliezer
For me, I experienced this issue after migrating my petalinux project to a new user.
petalinux-build -x mrproper
this cleaned the project enough that when I tried petalinux-build again, the problem was solved.
Observer eliezer
Another thing that caused this was having incorrect characters in local.conf.
I had copy-pasted "
INHIBIT_PACKAGE_STRIP = “1”
from a document, and the quotation marks were fancy ones instead of the default quotation marks. The build process did not recognize those characters, so retyping in actual quotes fixed that.
