Visitor iainhunter
Petalinux 2017.2 build failure on docker
I originally posted this on zedboard.org but was advised to try this forum instead.
I am seeing a build error with go-native when I add docker to uz3eg_iocc_2017_2 project. The GO internal variable WORK does not seem to be being set. I am using petalinux 2017.2.
Error can be reproduced with following command
iain@iain-Precision-WorkStation-T3500:~/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2$ petalinux-build -c go-native -x compile
[INFO] building go-native
[INFO] sourcing bitbake
INFO: bitbake go-native -c compile
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:00
Loaded 3235 entries from dependency cache.
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:00:03
Parsing of 2448 .bb files complete (2414 cached, 34 parsed). 3238 targets, 224 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:01
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: go-native-1.4.3-r0 do_compile: Function failed: do_compile (log file is located at /home/iain/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2/build/tmp/work/x86_64-linux/go-native/1.4.3-r0/temp/log.do_compile.17991)
ERROR: Logfile of failure stored in: /home/iain/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2/build/tmp/work/x86_64-linux/go-native/1.4.3-r0/temp/log.do_compile.17991
Log data follows:
| DEBUG: Executing shell function do_compile
| # Building C bootstrap tool.
| cmd/dist
| # Building compilers and Go bootstrap tool for host, linux/amd64.
| ./cmd/dist/dist bootstrap -a  -v
| lib9
| gcc -isystem/home/iain/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -Wall -Wstrict-prototypes -Wextra -Wunused -Wno-sign-compare -Wno-missing-braces -Wno-parentheses -Wno-unknown-pragmas -Wno-switch -Wno-comment -Wno-missing-field-initializers -fno-common -ggdb -pipe -fmessage-length=0 -c -m64 -I /home/iain/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2/build/tmp/work/x86_64-linux/go-native/1.4.3-r0/go/include -DPLAN9PORT -I /home/iain/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2/build/tmp/work/x86_64-linux/go-native/1.4.3-r0/go/src/lib9 -o $WORK/_exits.o /home/iain/Desktop/work/XXXX/ultrazed-XXXX/petalinux/projects/uz3eg_iocc_2017_2/build/tmp/work/x86_64-linux/go-native/1.4.3-r0/go/src/lib9/_exits.c
| exec gcc: No such file or directory
The problem is that it is trying to set the output object file to be at $WORK/_exits.o
If I cut and paste the command line shown and replace $WORK by a valid path such as the build-tmp created by the go-native.inc yocto file then it works.
However, exporting WORK=$TMPDIR in go-native.inc does not help.
Does anyone have a solution?
Thanks, Iain
