Visitor ayazdi
Petalinux 2017.3 build problem for KC705
I'm trying to build a PetaLinux for a Microblaze + DDR3+ UART Light design on a KC705 (Kintex-7) board. I keep getting the following error message. I appreciate if someone could tell me what could be wrong:
RROR: [Common 17-55] 'get_property' expects at least one object.
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
ERROR: [Hsi 55-1545] Problem running tcl command swapp_mba_fs_boot::swapp_generate : ERROR: [Common 17-55] 'get_property' expects at least one object.
while executing
"common::get_property IP_NAME [get_cells $instance]"
(procedure "get_ipname" line 2)
invoked from within
"get_ipname $flash"
(procedure "get_flash_config" line 5)
invoked from within
"get_flash_config $fid"
(procedure "swapp_mba_fs_boot::swapp_generate" line 7)
invoked from within
ERROR: [Hsi 55-1438] Error running generate_app.
Failed to generate app mba_fs_boot
while executing
"error "Failed to generate app $params(app)""
invoked from within
"if { [catch {hsi generate_app -dir $project} res] } {
