Petalinux 2017.4 could not find the device-tree
Hi All:
I am a new users of Petalinux 2017.4, I just used the usual command to do the --get-hw-description as in the previous version of Petalinux 2015.2 to 2016.4  However, I couldn't find the system-top.dtsi or other device tree after the
petalinux-config --get-hw-description=<path to hdf file> command is finished.
I am wondering if there is a new step to run, or I just have problem finding the devicetree ?
CK
Re: Petalinux 2017.4 could not find the device-tree
From 2017.1, instead of system-top.dts, we have added system-user.dtsi to make user modifications.
Refer Page 74 of this UG guide:-https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
Thank  you Shabbir:
However, I have just found out that after I run petalinux-config --get-hw-description, I could not find any device tree. There may be some problem of compiling FSBL. As I see some error message on that.
I will start reading through p.74 and the related document now.
CK
