Visitor bhuelsen
Petalinux 2017.4 - "petalinux-build" fails on busybox-1.24.1-r0 do_patch: Command Error: 'quilt --quiltrc
I created a new Petalinux (2017.4) project with
petalinux-create --type project --template zynq --name petalinux_build
And initialized the project with the hardware-specific information from my Vivado project
petalinux-config --get-hw-description=<PATH_TO_HDF>
After that I executed
petalinux-build
to build the project. At this point the procedure fails as you can see in the underneath terminal output.
benjaminh@memory-lab-pc:~/embedded_development/microZed/microzed_test$ petalinux-create --type project --template zynq --name petalinux_build
INFO: Create project: petalinux_build
INFO: New project successfully created in /home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build
benjaminh@memory-lab-pc:~/embedded_development/microZed/microzed_test$ cd petalinux_build/
benjaminh@memory-lab-pc:~/embedded_development/microZed/microzed_test/petalinux_build$ petalinux-config --get-hw-description=/home/benjaminh/embedded_development/microZed/microzed_repo/FPGA/crater_nav_microzed/crater_nav_microzed.sdk/
INFO: Getting hardware description...
INFO: Rename microzed_top_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
[INFO] menuconfig project
/home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported
/home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build/build/misc/config/Kconfig:568:warning: config symbol defined without type
configuration written to /home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build/project-spec/configs/config
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
~/embedded_development/microZed/microzed_test/petalinux_build/build/misc/plnx-generated ~/embedded_development/microZed/microzed_test/petalinux_build
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
Generate rootfs kconfig
[INFO] oldconfig rootfs
[INFO] generating petalinux-user-image.bb
benjaminh@memory-lab-pc:~/embedded_development/microZed/microzed_test/petalinux_build$ petalinux-build
[INFO] building project
INFO: bitbake petalinux-user-image
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:01:08
Parsing of 2466 .bb files complete (0 cached, 2466 parsed). 3259 targets, 226 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:05
Checking sstate mirror object availability: 100% |###########################################################################################################################################| Time: 0:00:15
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: busybox-1.24.1-r0 do_patch: Command Error: 'quilt --quiltrc /home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build/build/tmp/sysroots/x86_64-linux/etc/quiltrc push' exited with 0  Output:
/home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build/build/tmp/sysroots/x86_64-linux/usr/bin/quilt: line 153: /home/benjaminh/bin/bash: cannot execute binary file: Exec format error
ERROR: busybox-1.24.1-r0 do_patch: Function failed: patch_do_patch
ERROR: Logfile of failure stored in: /home/benjaminh/embedded_development/microZed/microzed_test/petalinux_build/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/busybox/1.24.1-r0/temp/log.do_patch.31512
ERROR: Task (/home/benjaminh/petalinux_2017_4/components/yocto/source/arm/layers/core/meta/recipes-core/busybox/busybox_1.24.1.bb:do_patch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1248 tasks of which 1095 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
I already checked if all recommend packages and workstation environments are installed which are described in UG1144 table 1-3.
Any idea what went wrong? How can I fix that issue?
Tags (2)
Re: Petalinux 2017.4 - "petalinux-build" fails on busybox-1.24.1-r0 do_patch: Command Error: 'quilt --quiltrc
Hi @bhuelsen,
Are you trying to patch busybox ?
Sandeep
Visitor bhuelsen
Hi @sandeepg,
no I've not tried to patch busybox.
I left everything in the default setting. This means no changes on the project config, the kernel config and no changes on the config of the rootfs.
Do I have to patch busybox to bring up the system properly?
Benjamin
Hi @bhuelsen,
Can you run below command and see share the logs.
$ petalinux-build -x mrproper
$ petalinux-build
Sandeep
Visitor amclees
I am having the exact same problem and it just started happening last week. I had previously built many projects successfully on this machine, so I'm not sure what changed.
I ran
$ petalinux-build
I get
ERROR: busybox-1.24.1-r0 do_patch: Command Error: 'quilt --quiltrc /home/temporal/ultrazed/petalinux/build/tmp/sysroots/x86_64-linux/etc/quiltrc push' exited with 0  Output:
/home/temporal/ultrazed/petalinux/build/tmp/sysroots/x86_64-linux/usr/bin/quilt: line 153: /home/temporal/bin/bash: cannot execute binary file: Exec format error
ERROR: Logfile of failure stored in: /home/temporal/ultrazed/petalinux/build/tmp/work/aarch64-xilinx-linux/busybox/1.24.1-r0/temp/log.do_patch.22989
ERROR: Task (/opt/petalinux-v2017.4-final/components/yocto/source/aarch64/layers/core/meta/recipes-core/busybox/busybox_1.24.1.bb:do_patch) failed with exit code '1'
And here is log.do_patch.22989
DEBUG: Executing python function do_patch
DEBUG: Executing python function patch_do_patch
NOTE: Applying patch 'busybox-udhcpc-no_deconfig.patch' (/opt/petalinux-v2017.4-final/components/yocto/source/aarch64/layers/core/meta/recipes-core/busybox/busybox/busybox-udhcpc-no_deconfig.patch)
ERROR: Command Error: 'quilt --quiltrc /home/temporal/ultrazed/petalinux/build/tmp/sysroots/x86_64-linux/etc/quiltrc push' exited with 0  Output:
DEBUG: Python function patch_do_patch finished
DEBUG: Python function do_patch finished
ERROR: Function failed: patch_do_patch
Visitor amclees
I reinstalled PetaLinux but the problem persisted so I ended up reinstalling the OS and all Xilinx tools.
Not the most elegant fix but at least it works for now.
Observer shustik
I've just install Ubuntu 16.04.4 and petalinux 2018.1, and xilinx soft: Vivado & SDK. And I have problem with transaction. What can it be?
Failed:
  base-files.plnx_zynq7 3.0.14-r89
  busybox.cortexa9hf_neon 1.24.1-r0
  eudev.cortexa9hf_neon 3.2.2-r0
  initscripts-functions.cortexa9hf_neon 1.0-r155
  libblkid1.cortexa9hf_neon 2.30-r0
  libfdisk1.cortexa9hf_neon 2.30-r0
  libmount1.cortexa9hf_neon 2.30-r0
  libsmartcols1.cortexa9hf_neon 2.30-r0
  libudev1.cortexa9hf_neon 3.2.2-r0
  libuuid1.cortexa9hf_neon 2.30-r0
  shadow.cortexa9hf_neon 4.2.1-r0
  smartmontools.cortexa9hf_neon 6.5-r0
  util-linux.cortexa9hf_neon 2.30-r0
  util-linux-su.cortexa9hf_neon 2.30-r0
Error: Transaction failed
Any ideas?
