vanloc_tc1
Petalinux 2018.2 and Application
Hi Everyone,
I have a project with Ultra96 ,I am using Petalinux,Vivado,SDK 2018.2 , ubuntu 18.04 LTS ,
I have reasearch information about Petalinux,
This is my idea,
1) When I want to add a app/file/web to BOOT  to SD-Card, I am using petalinux-create -t apps or petalinux-image.bbappend.Because I can not using install tools on petalinux evironment in Sd-card,I am finding about dnf package manager to install tools.
Is that right ?
2)This is my project :
I want to use camera on Ultra96 and get video to load on Web Server use Nginx.
If you know the answer or idea,please tell me.
Thank You Very Much,
vanloc,
aravindb
HI @vanloc_tc1
Please use the SDK & create a BOOT.BIN file by adding your application in bif file.
below is the refenence bif file for zynqMP.
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
[fsbl_config]a53_x64
[bootloader]C:\project\Debug\test.elf
You can add this nginx utility in your rootfs by enabling & building it.
Please follow below steps to enable it.
vim project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
add below line
IMAGE_INSTALL_append = " nginx"
petalinux-config -c rootfs
user packages --> [*] nginx
petalinux-build
For your reference you will find this recipe at meta-openembedded/meta-webserver/recipes-httpd/ path.
Thanks & ergards
Aravind
vanloc_tc1
Hi Aravindb,
Thank your answer,
I really dont know the difference between petalinux-build(fsbl,pmufw,fpga) and using Export file Boot.bin,fsbl,pmu from SDK?
In this example, I am using petalinux-create -t apps :http://svenand.blogdrives.com/archive/195.html#.XMKfgej7TDf
At Question 2:
If I want to use OpenCV -->IMAGE_INSTALL_append = " OpenCV " , it is include " libary ,tool " ??
Thank you very much,
vanloc,
