boularesaziz
Petalinux 2018.2 installation error
I'm getting the following errors while installing Petalinux on my PC
the installation continues and finishes but i can't source Bitbake in project configuration or build.
Any help would be appreciated...
INFO: Checking installation environment requirements...
INFO: Checking free disk space
INFO: Checking installed tools
environment: line 281: ((: 10#15~1 > 10#3: syntax error in expression (error token is "~1 > 10#3")
environment: line 285: ((: 10#15~1 < 10#3: syntax error in expression (error token is "~1 < 10#3")
Azs11
aaron_b1
This appears to be related to Ubuntu 18+, which is unsupported, I believe.  According to official petalinux tools documentation, only Ubuntu 16.04.3 (64-bit) is supported.  Folks who've seen this report that it doesn't happen with 16.
