Petalinux 2018.2 openCV simple build app error.
I am new to petalinux, I am compiling simple code for testing opencv,
#include <stdio.h>
#include <stdlib.h>
#include <termios.h>
#include <unistd.h>
#include <stdarg.h>
#include <stdlib.h>
#include <opencv/cv.hpp>
#include <opencv/highgui.hpp>
using namespace std;
int main(int argc, char *argv[])
	cout << "ok compiling OPENCV (oh my good!!!) yes yes yes \n";
	cout << "cmdline args:\n";
	while(argc--)
		cout << *argv++ << endl;
	return 0;
It is the error:
Loading cache: 100% |########################| Time: 0:00:03
Loaded 3427 entries from dependency cache.
Parsing recipes: 100% |##################| Time: 0:00:20
Parsing of 2553 .bb files complete (2518 cached, 35 parsed). 3426 targets, 147 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: ########################| Time: 0:00:39
Checking sstate mirror object availability: 100% |###############################| Time: 0:00:43
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: vocalizer-1.0-r0 do_configure: oe_runmake failed
ERROR: vocalizer-1.0-r0 do_configure: Function failed: do_configure (log file is located at /opt/pkg/projetos/xilinx-zc702-2018.2/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/vocalizer/1.0-r0/temp/log.do_configure.17554)
ERROR: Logfile of failure stored in: /opt/pkg/projetos/xilinx-zc702-2018.2/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/vocalizer/1.0-r0/temp/log.do_configure.17554
Log data follows:
| DEBUG: Executing shell function do_configure
| NOTE: make clean
| make: *** No rule to make target 'clean'.  Stop.
| ERROR: oe_runmake failed
| WARNING: /opt/pkg/projetos/xilinx-zc702-2018.2/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/vocalizer/1.0-r0/temp/run.do_configure.17554:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_configure (log file is located at /opt/pkg/projetos/xilinx-zc702-2018.2/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/vocalizer/1.0-r0/temp/log.do_configure.17554)
ERROR: Task (/opt/pkg/projetos/xilinx-zc702-2018.2/project-spec/meta-user/recipes-apps/vocalizer/vocalizer.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 4850 tasks of which 4842 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
edjin@edjin:/opt/pkg/projetos/xilinx-zc702-2018.2$
I get these error messages, what can it be?
I'm using petalinux 2018.02 and QEMU simulation
Thanks for any reply !!!
Re: Petalinux 2018.2 openCV simple build app error.
Hi @edjin_petalinux,
I have attached the sample recipes to build opencv application. Basically you need to wire up the recipes with build dependencies.
Sandeep
hi @sandeepg
I have couple of questions with your code.
1. how did you fix above code? can you provide some tutorial to learn about that? when I just copy your code and in to a c++ project which has different name it didnt build. but when I created a c++ project with exact name "rotateimage" and copied the all files you have provide here it build well. are there any especial procedure to create c++ project which is going to use opencv libraries? I am using petalinux 2018.2
2. I am using zedboard. if I am going to implement your code in zedboard do I have to cross compile Qt for get a output from HDMI or VGA?
3. how can I include a sample image to usr/bin(this is the location of rotateimage code after the build process) when I build petalinux?
Petalinux is based on Yocto
I recommend you study how to write yocto recipe in details
http://book.yoctoprojectbook.com/page/code-chapter-8
Hi @1ymw1,
1. Refer Yocto Project docs https://www.yoctoproject.org/docs/current/dev-manual/dev-manual.html#new-recipe-writing-a-new-recipe https://www.yoctoproject.org/docs/1.8/bitbake-user-manual/bitbake-user-manual.html
2. Not really unless you use Qt plugins for OpenCV. Just framebuffer or X11 server should be enough. I used ZCU102 with DisplayPort.
3. You can use recipe to copy the binary to ${bindir}(rootfs/usr/bin) or you can use ROOTFS Post process commands just to just copy a binary to ${bindir}
Sandeep
hi @sandeepg Thank you so much for the reply .
I found xilinx tutorial for  framebuffer in zynq ultra scale socs. But I am using zedboard. can you tell me how to get a vga or hdmi output from zedboard?
