Petalinux 2018.3 kernel panic error exitcode=0x0000000b
Hello I'm working with petalinux 2018.3 and booting board from SD card I have Kernel panic error. I attach the UART output when I boot petalinux. Thanks for the help.
x Zynq MP First Stage Boot Loader
Release 2018.3   Apr 12 2019  -  10:46:13
NOTICE:  ATF running on XCZU7EV/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.5(release):xilinx-v2018.2-919-g08560c36
NOTICE:  BL31: Built : 09:06:56, Apr 15 2019
PMUFW:  v1.1
U-Boot 2018.01 (Apr 15 2019 - 09:08:30 +0000) Xilinx ZynqMP ZCU102 rev1.0
DRAM:  4 GiB
usb dr_mode not found
EL Level:       EL2
Chip ID:        zu7ev
MMC:   mmc@ff160000: 0 (eMMC), mmc@ff170000: 1 (SD)
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Board: Xilinx ZynqMP
Bootmode: SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for petaproj_SDI
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT !
Hit any key to stop autoboot:  0
Device: mmc@ff160000
Manufacturer ID: 13
OEM: 14e
Tran Speed: 200000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 4 MiB ENH
reading image.ub
15228724 bytes read in 1017 ms (14.3 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000104
     Data Size:    7081678 Bytes = 6.8 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   be339bf4d567943995bd113cd10747bf1a26f96f
   Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Data Start:   0x106ca080
     Data Size:    8108322 Bytes = 7.7 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   85d7c994835ee80a2ebc9064a2d8adf6c3c83f75
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x106c10d8
     Data Size:    36578 Bytes = 35.7 KiB
     Hash algo:    sha1
     Hash value:   490d5f44bc60a87a6625ce0f44f0df4e88a45cbe
   Booting using the fdt blob at 0x106c10d8
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 07844000, end 07fff922 ... OK
   Loading Device Tree to 0000000007838000, end 0000000007843ee1 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.3 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP Mon Apr 15 09:09:12 UTC 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: xlnx,zynqmp
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000006fc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff71000 s46488 r8192 d31336 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x6bc00000-0x6fc00000] (64MB) mapped at [ffffffc06bc00000-ffffffc06fbfffff]
[    0.000000] Memory: 3776392K/4193280K available (10108K kernel code, 664K rwdata, 3220K rodata, 512K init, 2167K bss, 154744K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a60000   ( 10112 KB)
[    0.000000]     .rodata : 0xffffff8008a60000 - 0xffffff8008d90000   (  3264 KB)
[    0.000000]       .init : 0xffffff8008d90000 - 0xffffff8008e10000   (   512 KB)
[    0.000000]       .data : 0xffffff8008e10000 - 0xffffff8008eb6200   (   665 KB)
[    0.000000]        .bss : 0xffffff8008eb6200 - 0xffffff80090d40b0   (  2168 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq-xilinx: /amba_pl@0/interrupt-controller@a0012000: num_irq=2, edge=0x0
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008292] Console: colour dummy device 80x25
[    0.012390] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.022755] pid_max: default: 32768 minimum: 301
[    0.027441] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.034010] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.041702] ASID allocator initialised with 65536 entries
[    0.046510] Hierarchical SRCU implementation.
[    0.051101] EFI services will not be available.
[    0.055300] zynqmp_plat_init Platform Management API v1.1
[    0.060644] zynqmp_plat_init Trustzone version v1.0
[    0.065589] smp: Bringing up secondary CPUs ...
[    0.070244] Detected VIPT I-cache on CPU1
[    0.070273] CPU1: Booted secondary processor [410fd034]
[    0.070561] Detected VIPT I-cache on CPU2
[    0.070580] CPU2: Booted secondary processor [410fd034]
[    0.070857] Detected VIPT I-cache on CPU3
[    0.070876] CPU3: Booted secondary processor [410fd034]
[    0.070920] smp: Brought up 1 node, 4 CPUs
[    0.101557] SMP: Total of 4 processors activated.
[    0.106230] CPU features: detected feature: 32-bit EL0 Support
[    0.112028] CPU: All CPU(s) started at EL2
[    0.116100] alternatives: patching kernel code
[    0.121216] devtmpfs: initialized
[    0.127578] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[    0.132524] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.142050] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.154116] xor: measuring software checksum speed
[    0.192344]    8regs     :  2111.000 MB/sec
[    0.232375]    8regs_prefetch:  1882.000 MB/sec
[    0.272407]    32regs    :  2594.000 MB/sec
[    0.312441]    32regs_prefetch:  2181.000 MB/sec
[    0.312470] xor: using function: 32regs (2594.000 MB/sec)
[    0.316841] pinctrl core: initialized pinctrl subsystem
[    0.316946] random: fast init done
[    0.325840] NET: Registered protocol family 16
[    0.330340] cpuidle: using governor menu
[    0.334067] vdso: 2 pages (1 code @ ffffff8008a66000, 1 data @ ffffff8008e14000)
[    0.341008] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.348217] DMA: preallocated 256 KiB pool for atomic allocations
[    0.376255] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.378237] ARM CCI_400_r1 PMU driver probed
[    0.383474] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.397364] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.466186] raid6: int64x1  gen()   368 MB/s
[    0.534213] raid6: int64x1  xor()   410 MB/s
[    0.602266] raid6: int64x2  gen()   630 MB/s
[    0.670344] raid6: int64x2  xor()   553 MB/s
[    0.738375] raid6: int64x4  gen()   956 MB/s
[    0.806410] raid6: int64x4  xor()   680 MB/s
[    0.874465] raid6: int64x8  gen()   898 MB/s
[    0.942515] raid6: int64x8  xor()   673 MB/s
[    1.010595] raid6: neonx1   gen()   666 MB/s
[    1.078663] raid6: neonx1   xor()   781 MB/s
[    1.146687] raid6: neonx2   gen()  1072 MB/s
[    1.214751] raid6: neonx2   xor()  1106 MB/s
[    1.282848] raid6: neonx4   gen()  1380 MB/s
[    1.350872] raid6: neonx4   xor()  1321 MB/s
[    1.418930] raid6: neonx8   gen()  1513 MB/s
[    1.486986] raid6: neonx8   xor()  1404 MB/s
[    1.487013] raid6: using algorithm neonx8 gen() 1513 MB/s
[    1.490976] raid6: .... xor() 1404 MB/s, rmw enabled
[    1.495907] raid6: using neon recovery algorithm
[    1.500981] XGpio: /amba_pl@0/gpio@a0010000: registered, base is 511
[    1.507625] SCSI subsystem initialized
[    1.510680] usbcore: registered new interface driver usbfs
[    1.516006] usbcore: registered new interface driver hub
[    1.521290] usbcore: registered new device driver usb
[    1.526325] media: Linux media interface: v0.10
[    1.530787] Linux video capture interface: v2.00
[    1.535385] pps_core: LinuxPPS API ver. 1 registered
[    1.540282] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.549375] PTP clock support registered
[    1.553273] EDAC MC: Ver: 3.0.0
[    1.556505] PLL: shutdown
[    1.558974] zynqmp_pll_disable() clock disable failed for iopll_int, ret = -13
[    1.566390] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.573190] FPGA manager framework
[    1.576455] fpga-region fpga-full: FPGA Region probed
[    1.581472] Advanced Linux Sound Architecture Driver Initialized.
[    1.587673] Bluetooth: Core ver 2.22
[    1.590985] NET: Registered protocol family 31
[    1.595385] Bluetooth: HCI device and connection manager initialized
[    1.601703] Bluetooth: HCI socket layer initialized
[    1.606544] Bluetooth: L2CAP socket layer initialized
[    1.611569] Bluetooth: SCO socket layer initialized
[    1.617061] clocksource: Switched to clocksource arch_sys_counter
[    1.622525] VFS: Disk quotas dquot_6.6.0
[    1.626392] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.637323] NET: Registered protocol family 2
[    1.637795] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.644910] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.651678] TCP: Hash tables configured (established 32768 bind 32768)
[    1.657815] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.663795] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.670268] NET: Registered protocol family 1
[    1.674637] RPC: Registered named UNIX socket transport module.
[    1.680334] RPC: Registered udp transport module.
[    1.685004] RPC: Registered tcp transport module.
[    1.689670] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.696173] Trying to unpack rootfs image as initramfs...
[    2.044570] Freeing initrd memory: 7916K
[    2.044961] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    2.050154] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.058378] audit: initializing netlink subsys (disabled)
[    2.063098] audit: type=2000 audit(1.984:1): state=initialized audit_enabled=0 res=1
[    2.063445] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    2.077799] NFS: Registering the id_resolver key type
[    2.082147] Key type id_resolver registered
[    2.086285] Key type id_legacy registered
[    2.090269] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.096937] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    2.131614] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.133364] io scheduler noop registered
[    2.137252] io scheduler deadline registered
[    2.141505] io scheduler cfq registered (default)
[    2.146162] io scheduler mq-deadline registered
[    2.150659] io scheduler kyber registered
[    2.155263] nwl-pcie fd0e0000.pcie: Link is DOWN
[    2.159264] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
[    2.164862] OF: PCI:   MEM 0xe0000000..0xefffffff -> 0xe0000000
[    2.170731] OF: PCI:   MEM 0x600000000..0x7ffffffff -> 0x600000000
[    2.176996] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[    2.183016] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.188462] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[    2.195295] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[    2.202996] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[    2.208857] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    3.214558] xilinx-vdma a0011000.dma: reset timeout, cr 10086, sr 10001
[    3.215524] xilinx-vdma a0011000.dma: Reset channel failed
[    3.221124] xilinx-vdma a0011000.dma: Xilinx AXI VDMA Engine Driver Probed!!
[    3.228234] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    3.235057] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    3.241969] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    3.248891] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    3.255820] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    3.262732] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    3.269653] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    3.276576] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    3.283548] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    3.290415] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    3.297334] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    3.304253] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    3.311175] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    3.318095] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    3.325012] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    3.331936] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    3.338933] xilinx-frmbuf a0050000.v_frmbuf_rd: Unable to locate reset property in dt
[    3.346501] xilinx-frmbuf: probe of a0050000.v_frmbuf_rd failed with error -2
[    3.380209] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.384565] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.391318] brd: module loaded
[    3.394781] loop: module loaded
[    3.395797] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    3.402043] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    3.412515] scsi host0: ahci-ceva
[    3.415123] scsi host1: ahci-ceva
[    3.418333] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 42
[    3.426080] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 42
[    3.434121] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.441358] m25p80 spi0.0: found n25q256a, expected n25q512a
[    3.446179] m25p80 spi0.0: n25q256a (65536 Kbytes)
[    3.450745] 3 ofpart partitions found on MTD device spi0.0
[    3.456173] Creating 3 MTD partitions on "spi0.0":
[    3.460934] 0x000000000000-0x000000100000 : "boot"
[    3.466134] 0x000000100000-0x000000140000 : "bootenv"
[    3.471115] 0x000000140000-0x000001740000 : "kernel"
[    3.476944] libphy: Fixed MDIO Bus: probed
[    3.480721] tun: Universal TUN/TAP device driver, 1.6
[    3.484843] CAN device driver interface
[    3.489183] macb ff0e0000.ethernet: Not enabling partial store and forward
[    3.495790] libphy: MACB_mii_bus: probed
[    3.573132] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:22:01)
[    3.577307] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
[    3.591862] usbcore: registered new interface driver asix
[    3.596551] usbcore: registered new interface driver ax88179_178a
[    3.602588] usbcore: registered new interface driver cdc_ether
[    3.608380] usbcore: registered new interface driver net1080
[    3.614002] usbcore: registered new interface driver cdc_subset
[    3.619883] usbcore: registered new interface driver zaurus
[    3.625429] usbcore: registered new interface driver cdc_ncm
[    3.631307] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    3.637657] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.643738] ehci-pci: EHCI PCI platform driver
[    3.648459] usbcore: registered new interface driver uas
[    3.653460] usbcore: registered new interface driver usb-storage
[    3.659898] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    3.666864] IR NEC protocol handler initialized
[    3.671070] IR RC5(x/sz) protocol handler initialized
[    3.676085] IR RC6 protocol handler initialized
[    3.680582] IR JVC protocol handler initialized
[    3.685080] IR Sony protocol handler initialized
[    3.689664] IR SANYO protocol handler initialized
[    3.694340] IR Sharp protocol handler initialized
[    3.699008] IR MCE Keyboard/mouse protocol handler initialized
[    3.704803] IR XMP protocol handler initialized
[    3.710601] xilinx-tpg a0030000.v_tpg: invalid number of ports 0
[    3.715281] xilinx-tpg: probe of a0030000.v_tpg failed with error -22
[    3.721961] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff800c890010
[    3.730845] Internal error: : 96000210 [#1] SMP
[    3.735332] Modules linked in:
[    3.738362] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.3 #1
[    3.745539] Hardware name: xlnx,zynqmp (DT)
[    3.749691] task: ffffffc87b848d00 task.stack: ffffff8008038000
[    3.755579] PC is at xvtc_probe+0x94/0x128
[    3.759640] LR is at xvtc_probe+0x84/0x128
[    3.763705] pc : [<ffffff8008736c0c>] lr : [<ffffff8008736bfc>] pstate: 60000045
[    3.771056] sp : ffffff800803bc30
[    3.774343] x29: ffffff800803bc30 x28: ffffff8008df8c60
[    3.779620] x27: 0000000000000007 x26: ffffff8008eba000
[    3.784896] x25: ffffff8008d90474 x24: 0000000000000000
[    3.790173] x23: 0000000000000000 x22: ffffff8008e7c688
[    3.795449] x21: ffffffc87fff0de8 x20: ffffffc87b0f7010
[    3.800726] x19: ffffffc87b3cf018 x18: 0000000000000001
[    3.806003] x17: ffffff800869dae8 x16: ffffff80086998d8
[    3.811279] x15: ffffffffffffffff x14: ffffffc879528d8a
[    3.816556] x13: ffffffc879528d89 x12: 0000000000000030
[    3.821832] x11: 0000000000000020 x10: 0101010101010101
[    3.827109] x9 : 0000000000000000 x8 : ffffffc879528900
[    3.832385] x7 : 0000000000000000 x6 : 000000000000003f
[    3.837662] x5 : 0000000000000000 x4 : ffffff8008ef55d0
[    3.842938] x3 : 0000000000000000 x2 : ffffff800c890010
[    3.848215] x1 : 0000000000000040 x0 : 0000000000000000
[    3.853492] Process swapper/0 (pid: 1, stack limit = 0xffffff8008038000)
[    3.860152] Call trace:
[    3.862576] Exception stack(0xffffff800803baf0 to 0xffffff800803bc30)
[    3.868977] bae0:                                   0000000000000000 0000000000000040
[    3.876763] bb00: ffffff800c890010 0000000000000000 ffffff8008ef55d0 0000000000000000
[    3.884548] bb20: 000000000000003f 0000000000000000 ffffffc879528900 0000000000000000
[    3.892333] bb40: 0101010101010101 0000000000000020 0000000000000030 ffffffc879528d89
[    3.900118] bb60: ffffffc879528d8a ffffffffffffffff ffffff80086998d8 ffffff800869dae8
[    3.907903] bb80: 0000000000000001 ffffffc87b3cf018 ffffffc87b0f7010 ffffffc87fff0de8
[    3.915688] bba0: ffffff8008e7c688 0000000000000000 0000000000000000 ffffff8008d90474
[    3.923473] bbc0: ffffff8008eba000 0000000000000007 ffffff8008df8c60 ffffff800803bc30
[    3.931258] bbe0: ffffff8008736bfc ffffff800803bc30 ffffff8008736c0c 0000000060000045
[    3.939044] bc00: ffffff800803bc10 ffffff8008724378 ffffffffffffffff ffffff8008736bfc
[    3.946827] bc20: ffffff800803bc30 ffffff8008736c0c
[    3.951673] [<ffffff8008736c0c>] xvtc_probe+0x94/0x128
[    3.956778] [<ffffff8008586368>] platform_drv_probe+0x58/0xb8
[    3.962487] [<ffffff800858474c>] driver_probe_device+0x22c/0x2d8
[    3.968455] [<ffffff80085848b4>] __driver_attach+0xbc/0xc0
[    3.973904] [<ffffff800858288c>] bus_for_each_dev+0x4c/0x98
[    3.979440] [<ffffff8008584048>] driver_attach+0x20/0x28
[    3.984716] [<ffffff8008583b98>] bus_add_driver+0x1b8/0x228
[    3.990252] [<ffffff8008585260>] driver_register+0x60/0xf8
[    3.995701] [<ffffff80085862b8>] __platform_driver_register+0x40/0x48
[    4.002105] [<ffffff8008db8e38>] xvtc_driver_init+0x1c/0x24
[    4.007640] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[    4.013175] [<ffffff8008d90cc4>] kernel_init_freeable+0x138/0x1d8
[    4.019231] [<ffffff8008a51c48>] kernel_init+0x10/0x100
[    4.024420] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    4.029698] Code: 37f80420 f940a262 f9004e93 91004042 (b9400042)
[    4.035754] ---[ end trace db5f33278c06bcc8 ]---
[    4.040355] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    4.040355]
[    4.044541] ata1: SATA link down (SStatus 0 SControl 330)
[    4.044578] ata2: SATA link down (SStatus 0 SControl 330)
[    4.060144] SMP: stopping secondary CPUs
[    4.064037] Kernel Offset: disabled
[    4.067496] CPU features: 0x002004
[    4.070868] Memory Limit: none
[    4.073898] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    4.073898]
Re: Petalinux 2018.3 kernel panic error exitcode=0x0000000b
Looking at messages maybe the most significant to understand the cause of the error are:
and
and
Is there anyone who knows how to solve these problems?
Thank you very much.
Can you share the DT?
Hi @stephenm,
thank for the help. Sorry I'm not very experienced with petalinux. Which .dtsi  file are you interested in?
Mentor
Mentor
Hi @pierlum
Would you make sure setting of each IP's clock in device tree ?
Also, would you make sure clock structure of your design ?
Hi @watari,
sorry for my english but I can't understand your questions. Could you explain them with other words? Thanks.
Mentor
Mentor
Hi @pierlum
It seems that clock is not stable, in other words, clock is unstable or pll is unlock.
So, I suggest you to make sure the description of clock setting in device tree blob file.
If you can shre the following dtb file, I can help you by using device-tree-compiler.
conf@system-top.dtb
Thank you very much @watari
I attached the file you asked me.
Mentor
Mentor
Hi @pierlum
Make sure the following clock settings.
- "axi_clk" on DMA
- "dp_vtc_pixel_clk_in" on DP Rx IP
- fclk0/1/2/3 on ZynqMP
  => I suspect them. Are these settings correct ? or Is this structure suitable for your design ?
- clock frequency of video clock
  => It seems fixed "27MHz". But I guess it is not suitable for your design (SDI Rx and DP Tx design).
- ap_clk on v_frmbuf_rd
- ap_clk on vtpg
Also, I suggest you to make sure reset tree and polarity of reset port.
Would you do them ?
Hi @watari,
sorry I sent you wrong system-top.dtb. Could you kindly please analyze this one?
When you ask me to check clock settings where you ask me to check them? In Vivado design or somewhere else?
Edit: I noticed that video clock was uncostrained and I don't know where it found the 27 MHz constraint. Now I constrained it to 148.5MHz and Vivado is running.
In other way to solve the kernel panic is when there is no information from back trace
use gnu tools
arm-linux-gnueabi-addr2line -e -f <pc> vmlinux
this gives issue from which file, which function & line no.
so that we can directly debug/resove  the issue in single step.
from log attached above
#  arm-linux-gnueabi-addr2line -e -f ffffff8008736c0c vmlinux
gives you proper file name + function name+ line no, fix the issue in that line
Thanks & regards
Satish G
G Satish Kumar
Hi @gsatish10
To install gnu tools in petalinux i need to include them when I build it?
While compiling linux kernel might, you have used  "arm-xilinx- linux-gnueabi- *****  "
find the path from where arm-xilinx-linux-gnueabi-  gcc/gdb/ar/addr2line is present
go to that path & provide the following cmd
here vmlinux is generated for zimage which is loaded in ZC702/Zc706 board
# arm-xilinx-linux-gnueabi-addr2line -e -f <pc> vmlinux
Thanks & regards
Satish G
G Satish Kumar
Hi @gsatish10 ,
Sorry I can't find the path that you said me. Is it in the petalinux project path where I built petalinux? Thanks and sorry.
Mentor
Mentor
Hi @pierlum
Would you refer the following directory ? You can find @gsatish10  mentioned tool.
<petalinux install directory>/tools/linux-i386/gcc-arm-linux-gnueabi/bin
Hi @watari thank you. I found the tool. But launching it from this path I don't understand how to use it. Sorry I'm very inexperienced. Thanks.
Mentor
Mentor
Hi @pierlum
I confirmed your posted system_top.dtb file, again.
- Make sure clock frequency about misc_clk_1 as 300MHz and misc_clk_2 as 100MHz
- Make sure the setting of fclk0/fclk1/fclk2/fclk3. It is disabled.
- Make sure clock structure. What frequency do you use for AXI4 lite ?
- Make sure the polarity of reset. Especially, ex. AXI interconnect and so on.
- Make sure the setting of DP on PS side. It seems a little strenge.
Also, I attached dis-compiled device tree source file.
Would you compare your target setting and this file, too ?
Mentor
Mentor
Hi @pierlum
Would you refer @gsatish10 's post ?
He already mentioned how to use this tool.
Hi @watari,
Thanks for your advices. fclk0/fclk1/fclk2 (not fclk3) are enabled in Vivado and infact these clocks work with baremetal code and SDK. It seems to be a petalinux bug that in some cases they are disabled. I read here about this problem https://forums.xilinx.com/t5/Embedded-Linux/Enabling-PL-Clocks-in-Zynq-MPSoC/td-p/824893
This is probably the cause of kernel panic error and I have to understand how to solve it. Thanks.
Mentor
Mentor
Hi @pierlum
I suggest you the following flow.
1) Modify fclkX setting with my uploaded dts file. (Change status from disable to ok)
2) Rebuild dtb file by petalinux or device-tree-compiler.
3) Rebuild FIT file.
Would you try it ?
Hi @watari
I'll do what you suggested me. What is FIT file?
Mentor
Mentor
Hi @pierlum
Refer the following message. You already used FIT Image file for booting Linux kernel.
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    sha1
     Type:         RAMDisk Image
     OS:           Linux
     Hash algo:    sha1
     Hash algo:    sha1
FIT image file means "Flatten Image Tree" file and it includes linux kernel, device tree blob file and ramdisk image.
"mkimage" in u-boot tools can build FIT image file. Of cause, petalinux supports it, too.
Hi @watari
I think I did what you suggested:
1) modified system-top.dts writing "ok" for fclk0,fclk1,fclk2
2)Compiled dts to obtain dtb using command:
dtc -I dts -O dtb -o system-top.dtb system-top.dts
3) I replaced the old system-top.dtb with the new one in petalinux project directory (I found 2 system-top.dtb and I replaced them both)
4) I built petalinux project using
petalinux-build
petalinux-build --sdk
petalinux-package --sysroot
cd images/linux
petalinux-package --boot --fsbl zynqmp_fsbl.elf --u-boot u-boot.elf --pmufw pmufw.elf --fpga system.bit
5)I replaced BOOT.BIN and image.ub in the SD card with the new one (image.ub seems not to be changed) and I boot the board
I have again kernel panic errors.
I did something wrong in the procedure?
Mentor
Mentor
Hi @pierlum
Could you share log file ?
Also, perhaps, there is the route cause in HW design, too.
If yes, would you share block diagram, too ?
Hi @watari
this is the log:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.3   Apr 17 2019  -  10:17:45
NOTICE:  BL31: Built : 10:15:17, Apr 17 2019
PMUFW:  v1.1
U-Boot 2018.01 (Apr 17 2019 - 10:16:25 +0000) Xilinx ZynqMP ZCU102 rev1.0
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu7ev
MMC:   sdhci_send_command: MMC: 1 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 1 busy timeout.
mmc_init: -70, time 7439
mmc@ff170000 - probe failed: -70
In:    serial@ff000000
Bootmode: SD_MODE1
U-BOOT for projSDIVCU
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete..................                         ....................... TIMEOUT !
Manufacturer ID: 13
OEM: 14e
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 4-bit
reading image.ub
15231584 bytes read in 1018 ms (14.3 MiB/s)
     Type:         Kernel Image
     Data Size:    7083891 Bytes = 6.8 MiB
     OS:           Linux
     Hash algo:    sha1
     Hash value:   1b51a3b28a1cbe25cf3337328cf70c6bb75bb447
     Type:         RAMDisk Image
     Data Start:   0x106cad18
     Data Size:    8107957 Bytes = 7.7 MiB
     OS:           Linux
     Hash algo:    sha1
     Hash value:   3d9478d3eb4140d3629e35bf8cd747b61084a673
     Data Start:   0x106c197c
     Data Size:    37590 Bytes = 36.7 KiB
     Hash algo:    sha1
     Hash value:   6c72ddd6f1ebfdab31bc9f8280fe9c0b1fee0772
   Booting using the fdt blob at 0x106c197c
   Loading Ramdisk to 07844000, end 07fff7b5 ... OK
   Loading Device Tree to 0000000007837000, end 00000000078432d5 ... OK
Starting kernel ...
[    0.000000] Linux version 4.14.0-xilinx-v2018.3 (oe-user@oe-host) (gcc versio                         n 7.3.0 (GCC)) #1 SMP Tue Apr 16 16:19:46 UTC 2019
[    0.000000] cma: Reserved 1000 MiB at 0x0000000041400000
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff70000 s46488 r8192 d313                         36 u86016
[    0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_un                         used
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes                         )
[    0.000000] software IO TLB [mem 0x3d400000-0x41400000] (64MB) mapped at [fff                         fffc03d400000-ffffffc0413fffff]
[    0.000000] Memory: 3014528K/4193280K available (10108K kernel code, 664K rwd                         ata, 3224K rodata, 512K init, 2167K bss, 154752K reserved, 1024000K cma-reserved                         )
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 M                         B)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 G                         B)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a60000   ( 10112 K                         B)
[    0.000000]     .rodata : 0xffffff8008a60000 - 0xffffff8008d90000   (  3264 K                         B)
[    0.000000]       .init : 0xffffff8008d90000 - 0xffffff8008e10000   (   512 K                         B)
[    0.000000]       .data : 0xffffff8008e10000 - 0xffffff8008eb6200   (   665 K                         B)
[    0.000000]        .bss : 0xffffff8008eb6200 - 0xffffff80090d40b0   (  2168 K                         B)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 K                         B)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 M                         B)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 G                         B maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 M                         B actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 M                         B)
[    0.000000] irq-xilinx: /amba_pl@0/interrupt-controller@a0012000: num_irq=8,                          edge=0x0
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 43980                         46511101ns
[    0.008281] Console: colour dummy device 80x25
[    0.012389] Calibrating delay loop (skipped), value calculated using timer fr                         equency.. 199.99 BogoMIPS (lpj=399996)
[    0.041706] ASID allocator initialised with 65536 entries
[    0.046509] Hierarchical SRCU implementation.
[    0.051089] EFI services will not be available.
[    0.055299] zynqmp_plat_init Platform Management API v1.1
[    0.060643] zynqmp_plat_init Trustzone version v1.0
[    0.070240] Detected VIPT I-cache on CPU1
[    0.070269] CPU1: Booted secondary processor [410fd034]
[    0.070555] Detected VIPT I-cache on CPU2
[    0.070574] CPU2: Booted secondary processor [410fd034]
[    0.070849] Detected VIPT I-cache on CPU3
[    0.070869] CPU3: Booted secondary processor [410fd034]
[    0.070914] smp: Brought up 1 node, 4 CPUs
[    0.101556] SMP: Total of 4 processors activated.
[    0.106229] CPU features: detected feature: 32-bit EL0 Support
[    0.112027] CPU: All CPU(s) started at EL2
[    0.116099] alternatives: patching kernel code
[    0.121214] devtmpfs: initialized
[    0.127613] random: get_random_u32 called from bucket_table_alloc+0x108/0x260                          with crng_init=0
[    0.132524] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                         x_idle_ns: 7645041785100000 ns
[    0.142049] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.170652] xor: measuring software checksum speed
[    0.208406]    8regs     :  2111.000 MB/sec
[    0.248438]    8regs_prefetch:  1882.000 MB/sec
[    0.288470]    32regs    :  2594.000 MB/sec
[    0.328504]    32regs_prefetch:  2181.000 MB/sec
[    0.328533] xor: using function: 32regs (2594.000 MB/sec)
[    0.332903] pinctrl core: initialized pinctrl subsystem
[    0.333030] random: fast init done
[    0.341897] NET: Registered protocol family 16
[    0.346425] cpuidle: using governor menu
[    0.350102] vdso: 2 pages (1 code @ ffffff8008a66000, 1 data @ ffffff8008e140                         00)
[    0.357070] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.364283] DMA: preallocated 256 KiB pool for atomic allocations
[    0.392559] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.394513] ARM CCI_400_r1 PMU driver probed
[    0.399731] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.413827] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.482264] raid6: int64x1  gen()   368 MB/s
[    0.550244] raid6: int64x1  xor()   409 MB/s
[    0.618330] raid6: int64x2  gen()   630 MB/s
[    0.686378] raid6: int64x2  xor()   553 MB/s
[    0.754423] raid6: int64x4  gen()   956 MB/s
[    0.822472] raid6: int64x4  xor()   680 MB/s
[    0.890536] raid6: int64x8  gen()   898 MB/s
[    0.958585] raid6: int64x8  xor()   683 MB/s
[    1.026709] raid6: neonx1   gen()   666 MB/s
[    1.094721] raid6: neonx1   xor()   781 MB/s
[    1.162761] raid6: neonx2   gen()  1072 MB/s
[    1.230825] raid6: neonx2   xor()  1106 MB/s
[    1.298864] raid6: neonx4   gen()  1380 MB/s
[    1.366938] raid6: neonx4   xor()  1321 MB/s
[    1.434986] raid6: neonx8   gen()  1513 MB/s
[    1.503051] raid6: neonx8   xor()  1404 MB/s
[    1.503078] raid6: using algorithm neonx8 gen() 1513 MB/s
[    1.507048] raid6: .... xor() 1404 MB/s, rmw enabled
[    1.511978] raid6: using neon recovery algorithm
[    1.517047] XGpio: /amba_pl@0/gpio@a0010000: registered, base is 511
[    1.523665] SCSI subsystem initialized
[    1.526762] usbcore: registered new interface driver usbfs
[    1.532081] usbcore: registered new interface driver hub
[    1.537359] usbcore: registered new device driver usb
[    1.542397] media: Linux media interface: v0.10
[    1.546858] Linux video capture interface: v2.00
[    1.551454] pps_core: LinuxPPS API ver. 1 registered
[    1.556354] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome                         tti <giometti@linux.it>
[    1.565447] PTP clock support registered
[    1.569343] EDAC MC: Ver: 3.0.0
[    1.572575] PLL: shutdown
[    1.575045] zynqmp_pll_disable() clock disable failed for iopll_int, ret = -1                         3
[    1.582460] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.589310] FPGA manager framework
[    1.592523] fpga-region fpga-full: FPGA Region probed
[    1.597540] Advanced Linux Sound Architecture Driver Initialized.
[    1.603741] Bluetooth: Core ver 2.22
[    1.607056] NET: Registered protocol family 31
[    1.611457] Bluetooth: HCI device and connection manager initialized
[    1.617774] Bluetooth: HCI socket layer initialized
[    1.622615] Bluetooth: L2CAP socket layer initialized
[    1.627641] Bluetooth: SCO socket layer initialized
[    1.633076] clocksource: Switched to clocksource arch_sys_counter
[    1.638596] VFS: Disk quotas dquot_6.6.0
[    1.642465] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.653380] NET: Registered protocol family 2
[    1.653863] TCP established hash table entries: 32768 (order: 6, 262144 bytes                         )
[    1.660981] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.667750] TCP: Hash tables configured (established 32768 bind 32768)
[    1.673885] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.679867] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.686340] NET: Registered protocol family 1
[    1.690708] RPC: Registered named UNIX socket transport module.
[    1.696406] RPC: Registered udp transport module.
[    1.701076] RPC: Registered tcp transport module.
[    1.705742] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.712244] Trying to unpack rootfs image as initramfs...
[    2.060446] Freeing initrd memory: 7916K
[    2.060836] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    2.066024] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av                         ailable
[    2.074240] audit: initializing netlink subsys (disabled)
[    2.078970] audit: type=2000 audit(2.000:1): state=initialized audit_enabled=                         0 res=1
[    2.079319] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    2.093692] NFS: Registering the id_resolver key type
[    2.098024] Key type id_resolver registered
[    2.102159] Key type id_legacy registered
[    2.106143] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.112811] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    2.147618] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                         47)
[    2.149377] io scheduler noop registered
[    2.153263] io scheduler deadline registered
[    2.157514] io scheduler cfq registered (default)
[    2.162172] io scheduler mq-deadline registered
[    2.166670] io scheduler kyber registered
[    2.171265] nwl-pcie fd0e0000.pcie: Link is DOWN
[    2.175275] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
[    2.180870] OF: PCI:   MEM 0xe0000000..0xefffffff -> 0xe0000000
[    2.186742] OF: PCI:   MEM 0x600000000..0x7ffffffff -> 0x600000000
[    2.193003] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[    2.199027] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.204473] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[    2.211306] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff p                         ref]
[    2.219006] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[    2.224838] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    3.230558] xilinx-vdma a0011000.dma: reset timeout, cr 10086, sr 10001
[    3.231518] xilinx-vdma a0011000.dma: Reset channel failed
[    3.237113] xilinx-vdma a0011000.dma: Xilinx AXI VDMA Engine Driver Probed!!
[    3.244228] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    3.251047] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    3.257966] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    3.264888] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    3.271806] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    3.278728] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    3.285645] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    3.292567] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    3.299540] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    3.306404] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    3.313325] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    3.320245] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    3.327165] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    3.334087] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    3.341005] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    3.347935] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    3.354912] xilinx-frmbuf a0050000.v_frmbuf_rd: Unable to locate reset proper                         ty in dt
[    3.362495] xilinx-frmbuf: probe of a0050000.v_frmbuf_rd failed with error -2
[    3.396083] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.400135] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.407225] brd: module loaded
[    3.410695] loop: module loaded
[    3.411670] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0                         x3 impl platform mode
[    3.417921] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fb                         s pio slum part ccc sds apst
[    3.428404] scsi host0: ahci-ceva
[    3.431002] scsi host1: ahci-ceva
[    3.434197] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x1                         00 irq 42
[    3.441953] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x1                         80 irq 42
[    3.450014] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.457196] m25p80 spi0.0: found n25q256a, expected n25q512a
[    3.462084] m25p80 spi0.0: n25q256a (65536 Kbytes)
[    3.466617] 3 ofpart partitions found on MTD device spi0.0
[    3.472047] Creating 3 MTD partitions on "spi0.0":
[    3.476815] 0x000000000000-0x000000100000 : "boot"
[    3.482028] 0x000000100000-0x000000140000 : "bootenv"
[    3.486969] 0x000000140000-0x000001740000 : "kernel"
[    3.492801] libphy: Fixed MDIO Bus: probed
[    3.496530] tun: Universal TUN/TAP device driver, 1.6
[    3.500714] CAN device driver interface
[    3.505008] macb ff0e0000.ethernet: Not enabling partial store and forward
[    3.511667] libphy: MACB_mii_bus: probed
[    3.589148] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e                         0000 irq 30 (00:0a:35:00:22:01)
[    3.593327] Marvell 88E1510 ff0e0000.ethernet-ffffffff:00: attached PHY drive                         r [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:00, irq=POLL)
[    3.607835] usbcore: registered new interface driver asix
[    3.612569] usbcore: registered new interface driver ax88179_178a
[    3.618605] usbcore: registered new interface driver cdc_ether
[    3.624398] usbcore: registered new interface driver net1080
[    3.630021] usbcore: registered new interface driver cdc_subset
[    3.635905] usbcore: registered new interface driver zaurus
[    3.641449] usbcore: registered new interface driver cdc_ncm
[    3.647320] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    3.653652] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.659756] ehci-pci: EHCI PCI platform driver
[    3.664455] usbcore: registered new interface driver uas
[    3.669476] usbcore: registered new interface driver usb-storage
[    3.675909] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc                         0
[    3.682646] i2c /dev entries driver
[    3.686298] IR NEC protocol handler initialized
[    3.690550] IR RC5(x/sz) protocol handler initialized
[    3.695565] IR RC6 protocol handler initialized
[    3.700062] IR JVC protocol handler initialized
[    3.704560] IR Sony protocol handler initialized
[    3.709149] IR SANYO protocol handler initialized
[    3.713817] IR Sharp protocol handler initialized
[    3.718487] IR MCE Keyboard/mouse protocol handler initialized
[    3.724283] IR XMP protocol handler initialized
[    3.730048] xilinx-tpg a0030000.v_tpg: invalid number of ports 0
[    3.734760] xilinx-tpg: probe of a0030000.v_tpg failed with error -22
[    3.741441] Synchronous External Abort: synchronous external abort (0x9600021                         0) at 0xffffff800c8a0010
[    3.750325] Internal error: : 96000210 [#1] SMP
[    3.754812] Modules linked in:
[    3.757842] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.3 #                         1
[    3.765018] Hardware name: xlnx,zynqmp (DT)
[    3.769171] task: ffffffc87b848d00 task.stack: ffffff8008038000
[    3.775059] PC is at xvtc_probe+0x94/0x128
[    3.779120] LR is at xvtc_probe+0x84/0x128
[    3.783184] pc : [<ffffff8008737b4c>] lr : [<ffffff8008737b3c>] pstate: 60000                         045
[    3.790536] sp : ffffff800803bc30
[    3.793823] x29: ffffff800803bc30 x28: ffffff8008df8c68
[    3.799100] x27: 0000000000000007 x26: ffffff8008eba000
[    3.804376] x25: ffffff8008d90474 x24: 0000000000000000
[    3.809653] x23: 0000000000000000 x22: ffffff8008e7c6f0
[    3.814929] x21: ffffffc87ffefc00 x20: ffffffc87b0f6410
[    3.820206] x19: ffffffc87afa5e18 x18: 0000000000000001
[    3.825482] x17: ffffff800869dae8 x16: ffffff80086998d8
[    3.830759] x15: ffffffffffffffff x14: ffffffc87b18730a
[    3.836035] x13: ffffffc87b187309 x12: 0000000000000000
[    3.841312] x11: 0000000000000020 x10: 0101010101010101
[    3.846589] x9 : 0000000000000000 x8 : ffffffc87b187180
[    3.851865] x7 : 0000000000000000 x6 : 000000000000003f
[    3.857142] x5 : 0000000000000000 x4 : ffffff8008ef55d0
[    3.862418] x3 : 0000000000000000 x2 : ffffff800c8a0010
[    3.867695] x1 : 0000000000000040 x0 : 0000000000000000
[    3.872972] Process swapper/0 (pid: 1, stack limit = 0xffffff8008038000)
[    3.879632] Call trace:
[    3.882056] Exception stack(0xffffff800803baf0 to 0xffffff800803bc30)
[    3.888457] bae0:                                   0000000000000000 00000000                         00000040
[    3.896243] bb00: ffffff800c8a0010 0000000000000000 ffffff8008ef55d0 00000000                         00000000
[    3.904028] bb20: 000000000000003f 0000000000000000 ffffffc87b187180 00000000                         00000000
[    3.911813] bb40: 0101010101010101 0000000000000020 0000000000000000 ffffffc8                         7b187309
[    3.919598] bb60: ffffffc87b18730a ffffffffffffffff ffffff80086998d8 ffffff80                         0869dae8
[    3.927383] bb80: 0000000000000001 ffffffc87afa5e18 ffffffc87b0f6410 ffffffc8                         7ffefc00
[    3.935168] bba0: ffffff8008e7c6f0 0000000000000000 0000000000000000 ffffff80                         08d90474
[    3.942953] bbc0: ffffff8008eba000 0000000000000007 ffffff8008df8c68 ffffff80                         0803bc30
[    3.950738] bbe0: ffffff8008737b3c ffffff800803bc30 ffffff8008737b4c 00000000                         60000045
[    3.958523] bc00: ffffff800803bc10 ffffff80087252b8 ffffffffffffffff ffffff80                         08737b3c
[    3.966307] bc20: ffffff800803bc30 ffffff8008737b4c
[    3.971153] [<ffffff8008737b4c>] xvtc_probe+0x94/0x128
[    3.976258] [<ffffff8008586368>] platform_drv_probe+0x58/0xb8
[    3.981967] [<ffffff800858474c>] driver_probe_device+0x22c/0x2d8
[    3.987935] [<ffffff80085848b4>] __driver_attach+0xbc/0xc0
[    3.993384] [<ffffff800858288c>] bus_for_each_dev+0x4c/0x98
[    3.998920] [<ffffff8008584048>] driver_attach+0x20/0x28
[    4.004196] [<ffffff8008583b98>] bus_add_driver+0x1b8/0x228
[    4.009731] [<ffffff8008585260>] driver_register+0x60/0xf8
[    4.015181] [<ffffff80085862b8>] __platform_driver_register+0x40/0x48
[    4.021585] [<ffffff8008db8f44>] xvtc_driver_init+0x1c/0x24
[    4.027120] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[    4.032655] [<ffffff8008d90cc4>] kernel_init_freeable+0x138/0x1d8
[    4.038710] [<ffffff8008a51b48>] kernel_init+0x10/0x100
[    4.043899] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    4.049177] Code: 37f80420 f940a262 f9004e93 91004042 (b9400042)
[    4.055233] ---[ end trace 17f40a419256245c ]---
[    4.059835] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00                         00000b
[    4.059835]
[    4.061613] ata2: SATA link down (SStatus 0 SControl 330)
[    4.061650] ata1: SATA link down (SStatus 0 SControl 330)
[    4.079624] SMP: stopping secondary CPUs
[    4.083517] Kernel Offset: disabled
[    4.086976] CPU features: 0x002004
[    4.090348] Memory Limit: none
[    4.093378] ---[ end Kernel panic - not syncing: Attempted to kill init! exit                         code=0x0000000b
[    4.093378]
Hi @watari
I attached the .tcl to generate my design. Vivado 2018.3.
Product part is: Avnet UltraZed-7EV Carrier Card (xczu7ev-fbvb900-1-i)
Edit: .tcl seems not be working. I'm uploading the archived project and then I'll sent you the link
Edit2: Here the link to download the archived project https://mega.nz/#!p5cxzCLY!Eqd7tl1GNeP_78B_SEmWw1eRxuCe6jF_Lm6MNczwryg
Edit3: Here you can find Avnet board definition files https://github.com/Avnet/bdf
Hi @watari
Do you need others files or informations?
Thank you very much for your support.
Hey @pierlum and @watari .
I am seeing a very similar issue trying to run the boot-time VDMA-Test driver on ZynqMP platform (ZCU104 board). Here are my boot logs
[    0.000000] Linux version 4.14.0-xilinx-v2018.3 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP Sat Apr 20 17:03:01 UTC 2019
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc07fe75000 s46488 r8192 d31336 u86016
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516867
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1776952K/2096128K available (10108K kernel code, 664K rwdata, 3224K rodata, 512K init, 2168K bss, 57032K reserved, 262144K cma-reserved)
[    0.000000]        .bss : 0xffffff8008eb6200 - 0xffffff80090d42b0   (  2169 KB)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01bfc800   (    27 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc07ff00000   (  2047 MB)
[    0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[    0.000003] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008352] Console: colour dummy device 80x25
[    0.012474] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[    0.022840] pid_max: default: 32768 minimum: 301
[    0.027517] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.034091] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.041779] ASID allocator initialised with 65536 entries
[    0.046591] Hierarchical SRCU implementation.
[    0.051157] EFI services will not be available.
[    0.055383] zynqmp_plat_init Platform Management API v1.1
[    0.060729] zynqmp_plat_init Trustzone version v1.0
[    0.065665] smp: Bringing up secondary CPUs ...
[    0.070309] Detected VIPT I-cache on CPU1
[    0.070339] CPU1: Booted secondary processor [410fd034]
[    0.070605] Detected VIPT I-cache on CPU2
[    0.070623] CPU2: Booted secondary processor [410fd034]
[    0.070880] Detected VIPT I-cache on CPU3
[    0.070897] CPU3: Booted secondary processor [410fd034]
[    0.070938] smp: Brought up 1 node, 4 CPUs
[    0.101642] SMP: Total of 4 processors activated.
[    0.106315] CPU features: detected feature: 32-bit EL0 Support
[    0.112112] CPU: All CPU(s) started at EL2
[    0.116184] alternatives: patching kernel code
[    0.121280] devtmpfs: initialized
[    0.127157] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[    0.132599] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.142132] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.153236] xor: measuring software checksum speed
[    0.192424]    8regs     :  2303.000 MB/sec
[    0.232454]    8regs_prefetch:  2053.000 MB/sec
[    0.272484]    32regs    :  2830.000 MB/sec
[    0.312516]    32regs_prefetch:  2379.000 MB/sec
[    0.312545] xor: using function: 32regs (2830.000 MB/sec)
[    0.316916] pinctrl core: initialized pinctrl subsystem
[    0.317048] random: fast init done
[    0.325899] NET: Registered protocol family 16
[    0.330414] cpuidle: using governor menu
[    0.334101] vdso: 2 pages (1 code @ ffffff8008a66000, 1 data @ ffffff8008e14000)
[    0.341081] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.348385] DMA: preallocated 256 KiB pool for atomic allocations
[    0.374629] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.376648] ARM CCI_400_r1 PMU driver probed
[    0.381232] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.394963] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.462307] raid6: int64x1  gen()   402 MB/s
[    0.530290] raid6: int64x1  xor()   446 MB/s
[    0.598300] raid6: int64x2  gen()   687 MB/s
[    0.666352] raid6: int64x2  xor()   603 MB/s
[    0.734413] raid6: int64x4  gen()  1042 MB/s
[    0.802444] raid6: int64x4  xor()   742 MB/s
[    0.870516] raid6: int64x8  gen()   980 MB/s
[    0.938570] raid6: int64x8  xor()   744 MB/s
[    1.006610] raid6: neonx1   gen()   725 MB/s
[    1.074650] raid6: neonx1   xor()   853 MB/s
[    1.142689] raid6: neonx2   gen()  1166 MB/s
[    1.210729] raid6: neonx2   xor()  1202 MB/s
[    1.278779] raid6: neonx4   gen()  1503 MB/s
[    1.346824] raid6: neonx4   xor()  1437 MB/s
[    1.414898] raid6: neonx8   gen()  1650 MB/s
[    1.482927] raid6: neonx8   xor()  1526 MB/s
[    1.482954] raid6: using algorithm neonx8 gen() 1650 MB/s
[    1.486921] raid6: .... xor() 1526 MB/s, rmw enabled
[    1.491851] raid6: using neon recovery algorithm
[    1.497314] SCSI subsystem initialized
[    1.500307] usbcore: registered new interface driver usbfs
[    1.505634] usbcore: registered new interface driver hub
[    1.510908] usbcore: registered new device driver usb
[    1.515950] media: Linux media interface: v0.10
[    1.520417] Linux video capture interface: v2.00
[    1.525014] pps_core: LinuxPPS API ver. 1 registered
[    1.529912] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.539003] PTP clock support registered
[    1.542901] EDAC MC: Ver: 3.0.0
[    1.546343] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.553045] FPGA manager framework
[    1.556322] fpga-region fpga-full: FPGA Region probed
[    1.561317] Advanced Linux Sound Architecture Driver Initialized.
[    1.567520] Bluetooth: Core ver 2.22
[    1.570843] NET: Registered protocol family 31
[    1.575239] Bluetooth: HCI device and connection manager initialized
[    1.581555] Bluetooth: HCI socket layer initialized
[    1.586397] Bluetooth: L2CAP socket layer initialized
[    1.591423] Bluetooth: SCO socket layer initialized
[    1.596749] clocksource: Switched to clocksource arch_sys_counter
[    1.602387] VFS: Disk quotas dquot_6.6.0
[    1.606244] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.616884] NET: Registered protocol family 2
[    1.617637] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.624647] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.631324] TCP: Hash tables configured (established 16384 bind 16384)
[    1.637665] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.643608] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.650083] NET: Registered protocol family 1
[    1.654474] RPC: Registered named UNIX socket transport module.
[    1.660184] RPC: Registered udp transport module.
[    1.664853] RPC: Registered tcp transport module.
[    1.669523] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.676028] Trying to unpack rootfs image as initramfs...
[    1.997721] Freeing initrd memory: 7920K
[    1.998117] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    2.003263] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.011452] audit: initializing netlink subsys (disabled)
[    2.016425] audit: type=2000 audit(1.956:1): state=initialized audit_enabled=0 res=1
[    2.016754] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    2.030886] NFS: Registering the id_resolver key type
[    2.035304] Key type id_resolver registered
[    2.039434] Key type id_legacy registered
[    2.043417] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.050085] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    2.082665] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.084410] io scheduler noop registered
[    2.088310] io scheduler deadline registered
[    2.092559] io scheduler cfq registered (default)
[    2.097216] io scheduler mq-deadline registered
[    2.101713] io scheduler kyber registered
[    2.106573] Unable to handle kernel NULL pointer dereference at virtual address 00000018
[    2.113744] Mem abort info:
[    2.116499]   Exception class = DABT (current EL), IL = 32 bits
[    2.122390]   SET = 0, FnV = 0
[    2.125413]   EA = 0, S1PTW = 0
[    2.128521] Data abort info:
[    2.131381]   ISV = 0, ISS = 0x00000005
[    2.135187]   CM = 0, WnR = 0
[    2.138129] [0000000000000018] user address but active_mm is swapper
[    2.144444] Internal error: Oops: 96000005 [#1] SMP
[    2.149282] Modules linked in:
[    2.152313] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-v2018.3 #1
[    2.159489] Hardware name: xlnx,zynqmp (DT)
[    2.163642] task: ffffffc06d846d00 task.stack: ffffff8008038000
[    2.169531] PC is at xilinx_vdmatest_probe+0x19c/0x430
[    2.174628] LR is at xilinx_vdmatest_probe+0x184/0x430
[    2.179730] pc : [<ffffff80084c0c34>] lr : [<ffffff80084c0c1c>] pstate: 40000045
[    2.187082] sp : ffffff800803bbd0
[    2.190369] x29: ffffff800803bbd0 x28: ffffff8008df83a0
[    2.195645] x27: ffffffc06ccfd818 x26: ffffffc06ccfd798
[    2.200922] x25: ffffffc06ccfd780 x24: ffffffc06ccfd800
[    2.206199] x23: ffffff80090b8000 x22: 0000000000000000
[    2.211475] x21: 0000000000000000 x20: ffffffc06d06c410
[    2.216752] x19: ffffffc06ccfd700 x18: 0000000000000001
[    2.222028] x17: 0000000000000001 x16: 0000000000000019
[    2.227304] x15: ffffffffffffffff x14: ffffffffffffffff
[    2.232581] x13: 0000000000000038 x12: 0101010101010101
[    2.237857] x11: 0000000000000028 x10: 0101010101010101
[    2.243134] x9 : 0000000000000000 x8 : ffffffc06ccfd780
[    2.248410] x7 : 0000000000000000 x6 : 000000000000003f
[    2.253687] x5 : 0000000000000040 x4 : 0000000000000000
[    2.258964] x3 : ffffffc06ccfd700 x2 : 0000000000000000
[    2.264240] x1 : 0000000000000000 x0 : 000000000000000b
[    2.269517] Process swapper/0 (pid: 1, stack limit = 0xffffff8008038000)
[    2.276177] Call trace:
[    2.278601] Exception stack(0xffffff800803ba90 to 0xffffff800803bbd0)
[    2.285002] ba80:                                   000000000000000b 0000000000000000
[    2.292787] baa0: 0000000000000000 ffffffc06ccfd700 0000000000000000 0000000000000040
[    2.300572] bac0: 000000000000003f 0000000000000000 ffffffc06ccfd780 0000000000000000
[    2.308357] bae0: 0101010101010101 0000000000000028 0101010101010101 0000000000000038
[    2.316142] bb00: ffffffffffffffff ffffffffffffffff 0000000000000019 0000000000000001
[    2.323927] bb20: 0000000000000001 ffffffc06ccfd700 ffffffc06d06c410 0000000000000000
[    2.331712] bb40: 0000000000000000 ffffff80090b8000 ffffffc06ccfd800 ffffffc06ccfd780
[    2.339497] bb60: ffffffc06ccfd798 ffffffc06ccfd818 ffffff8008df83a0 ffffff800803bbd0
[    2.347282] bb80: ffffff80084c0c1c ffffff800803bbd0 ffffff80084c0c34 0000000040000045
[    2.355067] bba0: ffffff800803bbd0 ffffff80084c0c1c ffffffffffffffff ffffffc06d06c410
[    2.362851] bbc0: ffffff800803bbd0 ffffff80084c0c34
[    2.367698] [<ffffff80084c0c34>] xilinx_vdmatest_probe+0x19c/0x430
[    2.373839] [<ffffff80085875d0>] platform_drv_probe+0x58/0xb8
[    2.379548] [<ffffff80085859b4>] driver_probe_device+0x22c/0x2d8
[    2.385516] [<ffffff8008585b1c>] __driver_attach+0xbc/0xc0
[    2.390965] [<ffffff8008583af4>] bus_for_each_dev+0x4c/0x98
[    2.396501] [<ffffff80085852b0>] driver_attach+0x20/0x28
[    2.401778] [<ffffff8008584e00>] bus_add_driver+0x1b8/0x228
[    2.407313] [<ffffff80085864c8>] driver_register+0x60/0xf8
[    2.412762] [<ffffff8008587520>] __platform_driver_register+0x40/0x48
[    2.419166] [<ffffff8008db0a8c>] xilinx_vdmatest_driver_init+0x18/0x20
[    2.425653] [<ffffff8008083980>] do_one_initcall+0x38/0x128
[    2.431188] [<ffffff8008d90cc4>] kernel_init_freeable+0x138/0x1d8
[    2.437242] [<ffffff8008a54dc8>] kernel_init+0x10/0x100
[    2.442432] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[    2.447710] Code: 52800160 a901d676 b9003a60 d5033abf (f9400ec0)
[    2.453765] ---[ end trace 19914c5ef98eca3d ]---
[    2.458364] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    2.458364]
[    2.467430] SMP: stopping secondary CPUs
[    2.471323] Kernel Offset: disabled
[    2.474782] CPU features: 0x002004
[    2.478155] Memory Limit: none
[    2.481185] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    2.481185]
Here are my VDMA configurations
And here are my configurations for device tree for VDMA.
axi_vdma_0: dma@a0000000 {
			#dma-cells = <1>;
			clock-names = "s_axi_lite_aclk", "m_axi_mm2s_aclk", "m_axis_mm2s_aclk", "m_axi_s2mm_aclk", "s_axis_s2mm_aclk";
			clocks = <&clk 71>, <&clk 71>, <&clk 71>, <&clk 71>, <&clk 71>;
			compatible = "xlnx,axi-vdma-6.3", "xlnx,axi-vdma-1.00.a";
			interrupt-names = "mm2s_introut", "s2mm_introut";
			interrupt-parent = <&gic>;
			interrupts = <0 89 4 0 90 4>;
			reg = <0x0 0xa0000000 0x0 0x1000>;
			xlnx,addrwidth = <0x20>;
			xlnx,flush-fsync = <0x1>;
			xlnx,num-fstores = <0x1>;
			dma-channel@a0000000 {
				compatible = "xlnx,axi-vdma-mm2s-channel";
				interrupts = <0 89 4>;
				xlnx,datawidth = <0x20>;
				xlnx,device-id = <0x0>;
				xlnx,genlock-mode ;
			dma-channel@a0000030 {
				compatible = "xlnx,axi-vdma-s2mm-channel";
				interrupts = <0 90 4>;
				xlnx,genlock-mode ;
Mentor
Mentor
Hi @pierlum
Sorry for my late reply.
I have one question.
How do you decide this reset architecture ?
I guess you might be change reset architecture.
Especially, I will change the connection reset port and ext_reset_in.
- Cut reset signal from reset port.
- Cut ext_reset_in. (Because at least you need control pl_reset0 by software.)
- Connect reset signal from reset port to ext_reset_in.
Mentor
Mentor
Hi @johnfrye11
I suggest you to make sure reset architecture in your HW design and clock setting in device tree blob, if you use linux.
