Petalinux 2019.2 : Linux DMA from user space
I'm trying to run the Linux DMA from user space from wiki page here
However when petalinux-build fails with the following error :
dma-proxy.c:42:10: fatal error: linux/dmaengine.h: No such file or directory
Am I missing some step? Can you please help?
   Mariano
indeed it was my mistake because I had created the driver with petalinux-create -t apps and not petalinux-create -t modules.
    Mariano
Hi @mariano_severi
I suggest you to prepare nad use linux kernel header file when you build this application.
If you want to know detail, would you share your build log ?
Best regards,
    Mariano
