Petalinux 2019.2 kernel configuration issues
I'm having some trouble changing the kernel configuration and having it generate the .cfg files that (in 2019.1) were put into project-spec/meta-user/recipes-kernel/linux/linux-xlnx.
It looks like this workflow was changed and I cannot find out how to do this properly in UG1144.
I used to be able to just do petalinux-config -c kernel and all this was automatic. Now it seems to do things in a tmp directory and this directory is not version controlled.
Anyone know the new, correct approach?
Re: Petalinux 2019.2 kernel configuration issues
this workaround should help:
run "petalinux-build -c kernel -x finish" or "petalinux-build -c kernel -x finish -f" after you has changed kernel config, this will generate "project-spec/meta-user/recipes-kernel/linux/linux-xlnx/devtool-fragment.cfg" with your settings. the same must be done when you change u-boot config (petalinux-build -c u-boot -x finish -f).
br
John
