dlorych
Petalinux 2020.1 not packaging / building Xen correctly
I have upgraded a project using Xen from Petalinux 2019.2 to 2020.1 and since then Xen is not working correctly anymore. I am using the steps for building Xen from the wiki, so I am not sure what could be wrong (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/384663561/Building+Xen+Hypervisor+with+Petalinux+2020.1).
During boot of the dom0 (host) i get those errors:
[FAILED] Failed to start The Xen xenstore.
See 'systemctl status xenstored.service' for details.
[DEPEND] Dependency failed for Xenc…guest consoles and hypervisor.
[DEPEND] Dependency failed for xen-…des, JSON configuration stub).
[DEPEND] Dependency failed for qemu for xen dom0 disk backend.
[DEPEND] Dependency failed for Xend…p guests on boot and shutdown.
And xenstored could not get started because of a missing gnttab, but /usr/lib/libxengnttab.so.1 is in the file system, I dont know why it cant find it there:
* xenstored.service - The Xen xenstore
Loaded: loaded (/lib/systemd/system/xenstored.service; enabled; vendor preset: enabled)
Active: failed (Result: protocol) since Thu 2020-11-19 09:51:59 UTC; 1min 53s ago
Process: 210 ExecStartPre=/bin/grep -q control_d /proc/xen/capabilities (code=exited, status=0/SUCCESS)
Process: 215 ExecStart=/etc/xen/scripts/launch-xenstore (code=exited, status=0/SUCCESS)
Main PID: 215 (code=exited, status=0/SUCCESS)
Nov 19 09:51:58 xilinx-zcu104-20201 systemd[1]: Starting The Xen xenstore...
Nov 19 09:51:59 xilinx-zcu104-20201 launch-xenstore[215]: Starting /usr/sbin/xenstored...FATAL: Failed to open connection to gnttab: No such file or directory
Nov 19 09:51:59 xilinx-zcu104-20201 systemd[1]: xenstored.service: Failed with result 'protocol'.
Nov 19 09:51:59 xilinx-zcu104-20201 systemd[1]: Failed to start The Xen xenstore.
Does anyone have an idea why Xen is not working anymore under 2020.1?
Thankes.
dlorych
The underlying problem was that the packagegroup for xen forces the kernel config option 'CONFIG_XEN_GNTDEV' to be used as a module, while it needs to be enabled statically (see https://wiki.xenproject.org/wiki/Mainline_Linux_Kernel_Configs ). I enabled the option and created a packagegroup-petalinux-xen.bbappend which removes the condition for 'kernel-module-xen-gntdev', now it works like it should.
@Mods: I suggest notifying the devs that the xen-packagegroup is incorrect.
dlorych
After the problem still persisted in Petalinux 2020.2, I investigated the problem a bit more this time. I am still not sure why Xenstored is failing to find gnttab because it is included in the rootfs, but if i just run '/usr/sbin/xenstored' after booting then it works. So it seems like Xenstored can't find the library during boot, but can find it after the boot is complete.
dlorych
