zer0c00l
Petalinux ADC Drivers
I have a design which consists of the AXI Quad SPI IP which is connected to an AD7193 ADC. I have petalinux 2015.2 running and I can communicate with the ADC using spidev.h driver in linux. I found that there is also a builtin driver (found here) in Petalinux specifically for AD719x series of ADC which can be enabled while building the kernel. My question is that can those drivers be used with ADC connected through AXI Quad SPI IP or will they only work with the PS SPI.
Tags (3)
balkris
check drivers here
http://www.wiki.xilinx.com/Linux+Drivers
https://wiki.analog.com/resources/fpga/xilinx/pmod/ad7193
Thanks and Regards
Balkrishan
pvenugo
This driver looks to be supported for PS SPI only.
Praveen
zer0c00l
so that means spidev is the only way to use AXI SPI under Linux?
pvenugo
There is a correction.
These driver works for both QSPI and PS SPI.
Praveen
