Petalinux Boot Failure: "can't open '/dev/tty1'"
I downloaded the latest BSP for the zc702 board from the Xilinx website. The prebuilt image works fine, but when I tried building my own, I received errors and was never able to get to the point where I could login. Before building, I modified system-top.dts and xparameters.h to make the highest address value allocated to the Linux Kernel 0x10000000 instead of 0x40000000. The output I got from the FPGA board is below. Any ideas? Thanks!
Zynq> bootm 0x30000000
## Loading kernel from FIT Image at 30000000 ...
   Using 'conf@1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x300000d4
     Data Size:    3750272 Bytes = 3.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   d86880e708503e2080bee684a7c8d66ce65f708f
   Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 30000000 ...
   Trying 'ramdisk@0' ramdisk subimage
     Description:  ramdisk
     Type:         RAMDisk Image
     Data Start:   0x30398b3c
     Data Size:    5674400 Bytes = 5.4 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   294e24d558cf6245a403a9e1a038b49d4d22d557
## Loading fdt from FIT Image at 30000000 ...
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x30393b48
     Data Size:    20291 Bytes = 19.8 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   79ac6704024cae804d2b76f40f3c37d3cc50f86f
   Booting using the fdt blob at 0x30393b48
   Loading Kernel Image ... OK
   Loading Ramdisk to 07a96000, end 07fff5a0 ... OK
   Loading Device Tree to 07a8e000, end 07a95f42 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 4.9.0-xilinx-v2017.4 (ethan@ethan-Surface-Pro-4) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Fri Feb 16 15:31:29 CST 2018
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: Zynq ZC702 Development Board
bootconsole [earlycon0] enabled
cma: Reserved 16 MiB at 0x3f000000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @ef7cc000 s25932 r8192 d23220 u57344
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Kernel command line: console=ttyPS0,115200 earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1007292K/1048576K available (6144K kernel code, 200K rwdata, 1464K rodata, 1024K init, 229K bss, 24900K reserved, 16384K cma-reserved, 245760K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0700000   (7136 kB)
      .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      .data : 0xc0a00000 - 0xc0a32040   ( 201 kB)
       .bss : 0xc0a32040 - 0xc0a6b6d8   ( 230 kB)
Preemptible hierarchical RCU implementation.
	Build-time adjustment of leaf fanout to 32.
	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to f0802000
slcr mapped to f0804000
L2C: platform modifies aux control register: 0x02060000 -> 0x32460000
L2C: DT/platform modifies aux control register: 0x02060000 -> 0x32460000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x46460001
zynq_clock_init: clkc starts at f0804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080c000, irq=17
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100058
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 27, base_baud = 3125000) is a xuartps
`¬Ëk½±•�[ttyPS0] enabled
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
GPIO IRQ not connected
XGpio: /amba_pl/gpio@41200000: registered, base is 1020
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 5544K (c7a96000 - c8000000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=30 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0904000
[drm] Initialized
brd: module loaded
loop: module loaded
m25p80 spi0.0: found n25q128a11, expected n25q512a
m25p80 spi0.0: n25q128a11 (16384 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000001000000 : "spare"
libphy: Fixed MDIO Bus: probed
CAN device driver interface
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 29 (00:0a:35:00:1e:53)
Marvell 88E1116R e000b000.etherne:07: attached PHY driver [Marvell 88E1116R] (mii_bus:phy_addr=e000b000.etherne:07, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 24
si570 1-005d: registered, current frequency 148500000 Hz
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
rtc rtc0: invalid alarm value: 2018-1-12 42:62:0
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
ucd9200 8-0034: Device ID UCD9248-80|5.8.0.11400|091112
ucd9200 8-0034: 4 rails configured
random: fast init done
ucd9200 8-0035: Device ID UCD9248-80|5.8.0.11400|091112
ucd9200 8-0035: 4 rails configured
ucd9200 8-0036: Device ID UCD9248-80|5.8.0.11400|091112
ucd9200 8-0036: 2 rails configured
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at f09a8000 with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
Registering SWP/SWPB emulation handler
input: gpio-keys as /devices/soc0/gpio-keys/input/input0
rtc-pcf8563 5-0051: setting system clock to 2017-12-14 20:09:08 UTC (1513282148)
of_cfs_init
of_cfs_init: OK
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 1024K (c0900000 - c0a00000)
INIT: version 2.88 booting
/etc/init.d/rcS: line 17: mount: command not found
/etc/rcS.d/S02sysfs.sh: line 14: mount: command not found
grep: /proc/filesystems: No such file or directory
/etc/rcS.d/S06checkroot.sh: line 142: mount: command not found
bootlogd: cannot find console device 253:0 under /dev
/etc/rcS.d/S37populate-volatile.sh: line 205: /proc/cmdline: No such file or directory
/etc/rcS.d/S38dmesg.sh: line 17: /var/log/dmesg: No such file or directory
hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Feb 16 21:40:32 UTC 2018
Starting internet superserver: inetd.
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... /etc/rc5.d/S10dropbear: line 32: /proc/mounts: No such file or directory
Starting Dropbear SSH server: Exited: Failure reading random device /dev/urandom
Starting syslogd/klogd: Feb 16 21:40:32 xilinx-zc702-2017_4 syslog.info syslogd started: BusyBox v1.24.1
done
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel: klogd started: BusyBox v1.24.1 (2018-02-16 15:23:55 CST)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Booting Linux on physical CPU 0x0
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel: Linux version 4.9.0-xilinx-v2017.4 (ethan@ethan-Surface-Pro-4) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Fri Feb 16 15:31:29 CST 2018
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: OF: fdt:Machine model: Zynq ZC702 Development Board
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: bootconsole [earlycon0] enabled
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: cma: Reserved 16 MiB at 0x3f000000
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Memory policy: Data cache writealloc
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel: On node 0 totalpages: 262144
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel: free_area_init_node: node 0, pgdat c0a31440, node_mem_map ef7f7000
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel:   Normal zone: 1536 pages used for memmap
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel:   Normal zone: 0 pages reserved
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel:   Normal zone: 196608 pages, LIFO batch:31
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel:   HighMem zone: 65536 pages, LIFO batch:15
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: percpu: Embedded 14 pages/cpu @ef7cc000 s25932 r8192 d23220 u57344
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel: pcpu-alloc: s25932 r8192 d23220 u57344 alloc=14*4096
Feb 16 21:40:32 xilinx-zc702-2017_4 user.debug kernel: pcpu-alloc: [0] 0 [0] 1
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel: Kernel command line: console=ttyPS0,115200 earlyprintk
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Memory: 1007292K/1048576K available (6144K kernel code, 200K rwdata, 1464K rodata, 1024K init, 229K bss, 24900K reserved, 16384K cma-reserved, 245760K highmem)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel: Virtual kernel memory layout:
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:       .text : 0xc0008000 - 0xc0700000   (7136 kB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:       .data : 0xc0a00000 - 0xc0a32040   ( 201 kB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.notice kernel:        .bss : 0xc0a32040 - 0xc0a6b6d8   ( 230 kB)
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: Preemptible hierarchical RCU implementation.
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: 	Build-time adjustment of leaf fanout to 32.
Feb 16 21:40:32 xilinx-zc702-2017_4 user.info kernel: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Feb 16Feb FebFeFebFeFebFeFebFeb FebFebFebFebFeb FebFebFebFeb 1FeFeFeFeFeb 1FeFeFeFeb 16FFeFeFeFeFeb 16 FeFebFeFeFeFeb 16FeFeFeFeFeb 16 FeFeFeFeFeb 16 FeFeFeFeFeFeb 16 21:4Feb Feb FebFeb Feb 1Feb Feb Feb 1FebFeFeb 1FebFeb FebFeFeb FeFeFeb FeFeFeb Feb Feb FebFFFeFeFeFeStarting tcf-agent: OK
touch: /var/lock/subsys/tcf-agent: No such file or directory
Feb 16 21:40:32 xilinx-zc702-2017_4 auth.err getty[828]: can't open '/dev/tty1': No such file or directory^M
INIT: Feb 16 21:40:32 xilinx-zc702-2017_4 daemon.info init: Id "PS0" respawning too fast: disabled for 5 minutes
Feb 16 21:40:42 xilinx-zc702-2017_4 auth.err getty[838]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:40:52 xilinx-zc702-2017_4 auth.err getty[839]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:41:02 xilinx-zc702-2017_4 auth.err getty[840]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:41:12 xilinx-zc702-2017_4 auth.err getty[841]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:41:22 xilinx-zc702-2017_4 auth.err getty[842]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:41:32 xilinx-zc702-2017_4 auth.err getty[843]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:41:42 xilinx-zc702-2017_4 auth.err getty[844]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:41:52 xilinx-zc702-2017_4 auth.err getty[845]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:42:02 xilinx-zc702-2017_4 auth.err getty[846]: can't open '/dev/tty1': No such file or directory^M
INIT: Id "1" respawning too fast: disabled for 5 minutes
INIT: Feb 16 21:42:12 xilinx-zc702-2017_4 daemon.info init: no more processes left in this runlevel
INIT: Feb 16 21:45:33 xilinx-zc702-2017_4 daemon.info init: Id "PS0" respawning too fast: disabled for 5 minutes
Feb 16 21:47:13 xilinx-zc702-2017_4 auth.err getty[857]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:47:23 xilinx-zc702-2017_4 auth.err getty[858]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:47:33 xilinx-zc702-2017_4 auth.err getty[859]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:47:43 xilinx-zc702-2017_4 auth.err getty[860]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:47:53 xilinx-zc702-2017_4 auth.err getty[861]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:48:03 xilinx-zc702-2017_4 auth.err getty[862]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:48:13 xilinx-zc702-2017_4 auth.err getty[863]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:48:23 xilinx-zc702-2017_4 auth.err getty[864]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:48:33 xilinx-zc702-2017_4 auth.err getty[865]: can't open '/dev/tty1': No such file or directory^M
Feb 16 21:48:43 xilinx-zc702-2017_4 auth.err getty[866]: can't open '/dev/tty1': No such file or directory^M
INIT: Feb 16 21:50:38 xilinx-zc702-2017_4 daemon.info init: Id "PS0" respawning too fast: disabled for 5 minutes
hi @enivium ,
Is there any solution you got to escape from this...
I am also getting the same error when i try to boot the zcu102 after modifying the cpio file.
I have some knowledge that the permissions are changing while we are mounting and unmounting the file.
If there is any solution plz let me know
Could you provide the contents of your system-top.dts and xparameters.h that you modified?
Hi @e.friel,
Actually i am using Linux not peta-linux to boot the Board.the contents of the system-top.bit I can share with you but i am not added any xparameters.h file to this,
This is my dts file that i am using to compile and boot
Hlo @e.friel,
could you please tell me the solution for this,i provided the dts file that i am using.
Hi @vijaydhoki
You said you modified your cpio file not your dts. I'm assuming your modifying your root file system?
Hi @e.friel,
yeah i am modifying cpio,But you actually asked dts and sparameter.h file.
So I shared those files with you
please give me a clarity that which one i need to share with you.
Thank you,
Vijay
