sirishy2k
Petalinux Build errors
Hello ppl,
I am working on rebuild the kernel using the
$make menuconfig
I have the following errors.
[INFO ] Saving previous build.log
[INFO ] Building ucfront tool
[INFO ] Building kernel
[INFO ] Building kernel modules
[INFO ] Building include
[INFO ] Building lib
[INFO ]  Building lib:lzo
[00:00] / [: 1: libssl: unexpected operator
[: 1: 0: unexpected operator
[INFO ]  Building lib:zlib
[00:03] / /bin/sh: pushd: not found
/bin/sh: popd: not found
make[1]: *** [all] Error 127
make: *** [subdirs] Error 1
Please find my build log here http://www.box.net/shared/3fp4r7ev5hpdgay7h5aa
pafisep
You are using a Linux variant where /bin/sh is not the bash shell....
The issue is on this Makefile:
$PETALINUX/software/petalinux-dist/lib/Makefile
This makefile uses pushd and popd ( bash extensions ) and /bin/sh ( on Ubuntu and others distros ) is not bash.
The fast and easy way of solving the problem, is addding to the beginning of the makefile the line:
SHELL=/bin/bash
After that the kernel compiles ok.
Rant monde on:
Some guys assume that /bin/sh is bash. PLEASE DON'T DO THAT !
If you want to use bash extensions on your scripts, use /bin/bash !
/bin/sh is the plain simple Bourne shell. Ok?
If you don't know the difference between sh and bash, PLEASE ASK SOMEONE WHO DOES, or don't do shell scripts !
Rant mode off.
I feel much better now ! :smileyhappy:
Best regards
Paulo Ferreira
mamisadegh3
Thanks for the above post.
I was tryin to build PetaLinux for the ZCU102 board. My platform is a 16.04 64Bits ubuntu and i am using vivado 2016.4.
As usual instructions of Xilinx for building reference design does not work.
(http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Software+Acceleration+TRD+2016.1#Building)
I mean at least on this ubuntu it didn't work.
I came across the above post, indeed sh was the problem.
I removed the sh and made a symbolic link from bash to sh.
