gdg
Petalinux - Error: Multiple FPGA devices found, please use targets command to select one
I use Petalinux to generate my Linux image for a ZynqMP. I would like to boot it via JTAG. I may use the petalinux-boot command but I have a host with two FPGAs connected (ZCU102, ZC706). How can I solve the issue?
See the error message:
$ petalinux-boot --jtag --prebuilt 3
INFO: Launching XSDB for file download and boot.
INFO: This may take a few minutes, depending on the size of your image.
INFO: Configuring the FPGA...
INFO: Downloading bitstream to the target.
Multiple FPGA devices found, please use targets command to select one of: 4, 5
    invoked from within
"::tcf::eval -progress ::xsdb::print_progress {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {process_tcf_actions_cache_client ::tcfclient#0::arg}}}"
    (procedure "::tcf::cache_eval_with_progress" line 2)
    invoked from within
"::tcf::cache_eval_with_progress [dict get $arg chan]  [list process_tcf_actions_cache_client $argvar] $progress"
    (procedure "process_tcf_actions" line 1)
    invoked from within
"process_tcf_actions $arg ::xsdb::print_progress"
    (procedure "fpga" line 429)
    invoked from within
gdg
A colleague in my lab found a good solution. It is possible to associate a JTAG cable (a specific FPGA) to a hw_server on a specific port:
hw_server -s tcp::3122 -e "set set jtag-port-filter <CABLE ID>"
This works great!
No need to have multiple FPGAs on the same hw_server.
hpoetzl
Voyager
Voyager
Hey @gdg,
Check out AR# 66943 on how to reach multiple boards.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
gdg
@hpoetzl, thank you. That seems to work when I use XSDB, but problems arise when I run Vivado Ip Integrator and Vivado SDK.
Is there a way to turn-off / detach all of the boards connected to an hw_server except one?
I cannot physically detach the JTAG cables and they are driving me crazy.
Thank you
hpoetzl
Voyager
Voyager
Hey @gdg,
You can use close_hw_target to close a specified hardware target in TCL.
For example ...
close_hw_target [lindex [get_hw_targets] 0]
... will close the first hardware target.
Hope this helps,
Herbert
gdg
This works great!
hpoetzl
Voyager
Voyager
Hey @gdg,
This works great!
Glad that it could be resolved!
Not sure how that differs from AR# 66943 I suggested some time ago.
Anyway, let's wrap it up and mark this thread as solved.
All the best,
Herbert
gdg
You are right indeed.
Thank you for your help!
hpoetzl
Voyager
Voyager
No problem!
Have fun,
Herbert
sm7ed
While the existing replies and the AR# 66943 were helpful, getting things working on my system wasn't a walk in the park in the end. I definitely learned a lot about the hardware server on the way. Here is what worked for me in a simple format:
- run 'xsdb' (Xilinx System Debugger) then 'connect' and then 'targets' and you get a list of the available targets preceded by a number ID.
$ xsdb
xsdb% connect
xsdb% targets
Look for the ID of the device you want to use. Next, use this ID in petalinux-boot. For me ID=14.
petalinux-boot --jtag --kernel --fpga --xsdb-conn "connect; targets 14" -v
I hope this is helpful! Cheers!
