Observer dpizzitolo
Petalinux SDK Errors when building Petalinux for Microblaze
Guys,
                    I'm trying to build Petalinux for the microblaze using the Petalinux SDK. I get the following errors when I run petalinux-build:
| aarch64-xilinx-linux-gcc: error: unrecognized command line option '-mno-xl-soft-mul'
| aarch64-xilinx-linux-gcc: error: unrecognized command line option '-mno-xl-soft-div'
| aarch64-xilinx-linux-gcc: error: unrecognized command line option '-mxl-barrel-shift'
                   I know this is because the petalinux-build utility is not cross compiling for the right architecture. I tried the following commands:
source settings.sh
export CROSS_COMPILE=microblazeel-xilinx-linux-gnu-
export ARCH=microblazeel
                But petalinux-build is still trying to compile for the ARM. I also tried specifing
                In the petalinux-config -c kernel options. I'm at a loss as how to force the tool to cross compile against the correct device, any help will be appreciated.
Observer dpizzitolo
Re: Petalinux SDK Errors when building Petalinux for Microblaze
This is what is making me think it is an issue of the tools failing to obey the CROSS_COMPILE env var that I set:
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 32 CROSS_COMPILE=aarch64-xilinx-linux- CC=aarch64-xilinx-linux-gcc
Shouldn't be compiling against aarch64 for microblaze
Observer dpizzitolo
Just as an update, I tried Petalinux 18.2 on Ubuntu 16.04 and it yields the same error. I noticed this tutorial here that used Petalinux SDK 17.4:
http://www.fpgadeveloper.com/2017/11/petalinux-for-artix-7-arty-base-project.html
So I tried the exact same instructions with 17.4 on a separate machine and still get the same error. I don't know what I'm doing that is causing the petalinux-build tool to insist on building against the wrong architecture.
Wish someone from Xilinx could help out on this, this is getting way harder than it needs to be.
I'll try to continue playing with flag overrides in the meantime.
Observer dpizzitolo
So I eventually gave up trying Petalinux SDK and built from the linux_xlnx.git repository for the kernel and the device-tree.git repository. I even had some tcl script errors in the device-tree build that I had to patch myself.
It is worth noting that I had the exact same errors with the manual kernel build process also, but was able to easily fix them using the CROSS_COMPILE override.
It would've been nice to get the petalinux SDK tools working since it is more time consuming building everything from scratch. However, it was a valuable learning experience.
