Petalinux SSH login always fails the first time
When I ssh into a Zynq device running Petalinux, the first password attempt always fails, and subsequent attempts always succeed. This occurs with every ssh login or scp transfer. This occurs with multiple devices, including ZynqMP and RFSoC devices.
I'm not sure which specific version of Petalinux introduced this issue and have not done a lot to debug the issue, yet.
I just wanted to see if this is widespread and whether it is a known issue before I continue trying to debug it. Thanks!
Your problem is due to the default option(-w) of dropbear which disables root logins
The solution is https://forums.xilinx.com/t5/Embedded-Linux/dropbear-root-login-petalinux-2019-1/td-p/979852
Hi @jeffsimpson ,
You to enable debug-tweaks in build to connect via ssh for the first time.
$ petalinux-config ---> Yocto Settings ---> [*] Enable Debug Tweaks
Note: Enabling Debug tweaks also enables autologin.
Sandeep
Could the first prompt actually be for a passphrase (on a local ssh key) rather than for a password? You can try using "ssh -v" to enable verbose mode.
Hi All,
As I mentioned earlier debug-tweaks is the right way to do it from PetaLinux or Yocto (alternatively allow-empty-password option) See below commit for Purdie.
https://github.com/openembedded/openembedded-core/commit/d3e69fa2fef83015658aa5fa1442bab5a8c3edaa#diff-874bf0754858c24b4a7511e08ef887b9
Sandeep
I thought you said that enabling Debug Tweaks would also enable auto-login? Is there a way to fix the ssh issue without enabling auto-login?
