Visitor mark_8
Petalinux - Unable to read file uImage
I tried to boot my vivado project by SD card U-boot petalinux. I have load my Boot.bin and image.ub files into fat32/SD card, and boot into the console and loading the Linux kernel uImage by following:
U-Boot-PetaLinux> fatload mmc 0 0x3000000 uImage
reading uImage
** Unable to read file uImage **
I have included the "image.ub" file in the SD card and why I cannot load the kernal? How can I load the kernal image properly?
I created "image.ub" file by petalinux 2014.4 and "Boot.bin" by SDK 2015.2
Re: Petalinux - Unable to read file uImage
Maybe the filename needs to be "uImage" instead of "image.ub"?
@mark_8
If you are using Petalinux 2014.4 or later versions you need not use SDK to create the BOOT.bin file.
Once the hardware is exported , you can generate all the required files to boot using Petalinux commands.
Refer to UG1157 for Petalinux commands: http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_4/ug1157-petalinux-tools-command-line-guide.pdf
After creating the image.ub using petalinux-build command, you can use the command petalinux-package command to generate boot.bin.
Command details:
Example Usage of the petalinux-package --boot Workflow
The following examples demonstrate proper usage of the petalinux-package --boot workflow.
 1.Create a BOOT.BIN file for a Zynq AP SoC device.
$ petalinux-package --boot --format BIN --fsbl --u-boot -o <PATH-TO-OUTPUT>
2. Create a BOOT.BIN file for a Zynq AP SoC device that includes a PL bitstream and FIT image.
$ petalinux-package --boot --format BIN --fsbl --u-boot --fpga <PATH-TO-BITSTREAM>
--kernel -o <PATH-TO-OUTPUT>
3. Create a x8 SMAP PROM MCS file for a MicroBlaze design.
$ petalinux-package --boot --format MCS --fsbl --u-boot --fpga <PATH-TO-BITSTREAM>
--flash-size <SIZE> --flash-intf SMAPx8 -o <PATH-TO-OUTPUT>
You can copy the BOOT.BIN and image.ub files to SD card to boot linux.
If you want to stop during u-boot and later boot the kernel, use run sdboot at u-boot stage.
hope this helps.
-Achutha
