jorisbolsens
Petalinux XLNK compile error
I am trying to compile petalinux for SDSoC as stated here (UG1146) but am getting a compile error building the xlnx kernel with xlnk. I am running Ubuntu 16.04 and I am able to petalinux-build just fine with the xilinx drivers turned off.
| ERROR: "xlnk_init_config" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xlnk_get_config" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xlnk_set_config" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xlnk_config_clear_block" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xlnk_config_dma_type" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xdma_wait" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xdma_submit" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xdma_release_all_channels" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xdma_release_channel" [drivers/staging/apf/xlnk.ko] undefined!
| ERROR: "xdma_request_channel" [drivers/staging/apf/xlnk.ko] undefined!
| make[3]: *** [/home/joris/zedboard/build/tmp/work-shared/zedboard-zynq7/kernel-source/scripts/Makefile.modpost:92: __modpost] Error 1
| make[2]: *** [/home/joris/zedboard/build/tmp/work-shared/zedboard-zynq7/kernel-source/Makefile:1213: modules] Error 2
| make[1]: *** [Makefile:146: sub-make] Error 2
| make: *** [Makefile:24: __sub-make] Error 2
| make: Leaving directory '/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/linux-zedboard_zynq7-standard-build'
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile_kernelmodules (log file is located at /home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/temp/log.do_compile_kernelmodules.33063)
Full output:
joris@ubuntu:~/zedboard$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |############################################| Time: 0:00:00
Loaded 3423 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:04
Parsing of 2552 .bb files complete (2514 cached, 38 parsed). 3425 targets, 148 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:20
Checking sstate mirror object availability: 100% |###############| Time: 0:00:20
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: fsbl: compiling from external source tree /opt/Xilinx/peta/tools/hsm/data/embeddedsw
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_compile_kernelmodules: oe_runmake failed
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_compile_kernelmodules: Function failed: do_compile_kernelmodules (log file is located at /home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/temp/log.do_compile_kernelmodules.33063)
ERROR: Logfile of failure stored in: /home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/temp/log.do_compile_kernelmodules.33063
Log data follows:
| DEBUG: Executing shell function do_compile_kernelmodules
| NOTE: make HOSTCC=gcc  -isystem/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/lib -L/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/lib -Wl,-rpath-link,/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/lib -Wl,-O1 HOSTCPP=gcc  -E -C /home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/linux-zedboard_zynq7-standard-build -j 8 modules CC=arm-xilinx-linux-gnueabi-gcc  -mno-thumb-interwork -marm -fuse-ld=bfd -ffile-prefix-map=/home/joris/zedboard/build/tmp/work-shared/zedboard-zynq7/kernel-source=/kernel-source/  LD=arm-xilinx-linux-gnueabi-ld.bfd   UIMAGE_LOADADDR=0x8000
| make: Entering directory '/home/joris/zedboard/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/linux-zedboard_zynq7-standard-build'
|   CHK     include/config/kernel.release
|   GEN     ./Makefile
|   CHK     include/generated/uapi/linux/version.h
|   CHK     include/generated/utsrelease.h
|   Using /home/joris/zedboard/build/tmp/work-shared/zedboard-zynq7/kernel-source as source for kernel
|   CC      scripts/mod/empty.o
|   CC      scripts/mod/devicetable-offsets.s
|   MKELF   scripts/mod/elfconfig.h
|   CHK     scripts/mod/devicetable-offsets.h
|   HOSTCC  scripts/mod/modpost.o
|   HOSTCC  scripts/mod/file2alias.o
|   CHK     include/generated/timeconst.h
|   CHK     include/generated/bounds.h
|   CHK     include/generated/asm-offsets.h
|   CALL    /home/joris/zedboard/build/tmp/work-shared/zedboard-zynq7/kernel-source/scripts/checksyscalls.sh
|   HOSTCC  scripts/mod/sumversion.o
|   HOSTLD  scripts/mod/modpost
|   CC [M]  net/802/p8022.o
|   CC [M]  crypto/crypto_engine.o
|   CC [M]  crypto/echainiv.o
|   CC [M]  crypto/hmac.o
|   CC [M]  crypto/sha256_generic.o
|   CC [M]  net/802/psnap.o
|   CC [M]  drivers/crypto/virtio/virtio_crypto_algs.o
|   CC [M]  drivers/crypto/virtio/virtio_crypto_mgr.o
|   CC [M]  crypto/authenc.o
|   CC [M]  net/8021q/vlan.o
|   CC [M]  net/8021q/vlan_dev.o
|   CC [M]  drivers/crypto/virtio/virtio_crypto_core.o
|   CC [M]  net/8021q/vlan_netlink.o
|   CC [M]  net/802/stp.o
|   CC [M]  crypto/authencesn.o
|   CC [M]  crypto/drbg.o
|   CC [M]  net/8021q/vlanproc.o
|   LD [M]  drivers/crypto/virtio/virtio_crypto.o
|   CC [M]  crypto/jitterentropy.o
|   CC [M]  net/bridge/br.o
|   CC [M]  crypto/jitterentropy-kcapi.o
|   CC [M]  net/bridge/br_device.o
|   CC [M]  net/bridge/br_fdb.o
|   CC [M]  net/bridge/br_forward.o
|   LD [M]  net/8021q/8021q.o
|   LD [M]  crypto/jitterentropy_rng.o
|   CC [M]  net/llc/llc_core.o
|   CC [M]  net/bridge/br_if.o
|   CC [M]  net/ipv4/ipip.o
|   CC [M]  net/bridge/br_input.o
|   CC [M]  net/bridge/br_ioctl.o
|   CC [M]  net/bridge/br_stp.o
|   CC [M]  net/bridge/br_stp_bpdu.o
|   CC [M]  net/llc/llc_input.o
|   CC [M]  net/bridge/br_stp_if.o
|   CC [M]  net/bridge/br_stp_timer.o
|   CC [M]  net/bridge/br_netlink.o
|   CC [M]  net/bridge/br_netlink_tunnel.o
|   CC [M]  net/bridge/br_sysfs_if.o
|   CC [M]  net/bridge/br_sysfs_br.o
|   CC [M]  net/llc/llc_output.o
|   CC [M]  net/bridge/br_multicast.o
|   CC [M]  net/bridge/br_mdb.o
|   LD [M]  net/llc/llc.o
|   CC [M]  drivers/rpmsg/rpmsg_core.o
|   CC [M]  drivers/remoteproc/zynq_remoteproc.o
|   CC [M]  drivers/rpmsg/virtio_rpmsg_bus.o
|   CC [M]  drivers/staging/apf/xlnk-config.o
|   CC [M]  drivers/staging/apf/xlnk.o
|   CC [M]  drivers/staging/apf/xlnk-eng.o
|   CC [M]  drivers/uio/uio_pdrv_genirq.o
|   CC [M]  drivers/usb/gadget/usbstring.o
|   CC [M]  drivers/usb/gadget/config.o
|   CC [M]  drivers/usb/gadget/epautoconf.o
|   CC [M]  drivers/usb/gadget/composite.o
|   CC [M]  drivers/usb/gadget/functions.o
|   CC [M]  drivers/usb/gadget/configfs.o
|   CC [M]  drivers/usb/gadget/u_f.o
|   CC [M]  drivers/usb/gadget/function/f_loopback.o
|   LD [M]  net/bridge/bridge.o
|   CC [M]  drivers/usb/gadget/legacy/zero.o
|   CC [M]  drivers/usb/gadget/function/f_sourcesink.o
|   CC [M]  drivers/usb/gadget/function/f_mass_storage.o
|   CC [M]  drivers/usb/gadget/function/storage_common.o
|   LD [M]  drivers/usb/gadget/legacy/g_zero.o
|   LD [M]  drivers/usb/gadget/libcomposite.o
|   LD [M]  drivers/usb/gadget/function/usb_f_ss_lb.o
|   LD [M]  drivers/usb/gadget/function/usb_f_mass_storage.o
|   Building modules, stage 2.
|   MODPOST 27 modules
ERROR: Task (/opt/Xilinx/peta/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.2.bb:do_compile_kernelmodules) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6793 tasks of which 5194 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
radheys
See if the error goes away by making xlnk module part of linux kernel i.e CONFIG_XILINX_APF=y (instead of module 'm').
Radhey
radheys
Radhey
jorisbolsens
that seems to have fixed it!
santosh_ts
Where should i make CONFIG_XILINX_APF=y ?
Which command i need to use ?
yoshi_mori
Hi , I have had the same issue, has been solved.
The command is
petalinux-config -c kernel
And Do the following
Device Drivers → Staging drivers → Xilinx APF Accelerator driver (*)
                                                           → Xilinx APF DMA engines support (*)
