dupont_francois
Petalinux ZCU102 : PMU-FW is not running
I tried since few days to use petalinux upon ZCU102 board but I get the following message when I boot the board : "PMU-FW is not running".
  • I have downloaded xilinx-zcu102-v2018.3-final.bsp
  • I have installed Petalinux with petalinux-v2018.3-final-installer.run
  • petalinux-create -t project -s xilinx-zcu102-v2018.3-final.bsp
  • petalinux-config --get-hw-description=hardware/xilinx-zcu102-2018.3/xilinx-zcu102-2018.3.sdk
  • petalinux-build
  • petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --u-boot images/linux/u-boot.elf --pmufw images/linux/pmufw.elf
  • I properly created partions in my SD card and copied BOOT.BIN and image.ub in boot partition
  • Then, when I power on the board I get the PMU message...
What did I do wrong ?
Best regards,
Dupont François
jovitac
What message do you get? Could you please post your console log?
dupont_francois
This is my console log when I power on the board :
Xilinx Zynq MP First Stage Boot Loader
Release 2018.3 Nov 8 2018 - 19:16:37
PMU-FW is not running, certain applications may not be supported.
jovitac
Could you please post the log of your package command? It should list all the image files being included. Please see example below.
As a test, please also try the BOOT.bin and image.ub from the prebuilt directory an see if that boots.
$ petalinux-package --boot --format BIN --fsbl images/linux/zynqmp_fsbl.elf --fpga images/linux/system.bit --u-boot images/linux/u-boot.elf --pmufw images/linux/pmufw.elf --force
INFO: File in BOOT BIN: "/plnx-proj/images/linux/zynqmp_fsbl.elf"
INFO: File in BOOT BIN: "/plnx-proj/images/linux/pmufw.elf"
INFO: File in BOOT BIN: "/plnx-proj/images/linux/system.bit"
INFO: File in BOOT BIN: "/plnx-proj/images/linux/bl31.elf"
INFO: File in BOOT BIN: "/plnx-proj/images/linux/u-boot.elf"
INFO: Generating ZynqMP binary package BOOT.BIN...
dupont_francois
I tried with your command and even with pre-build BOOT.bin and I still get the same message :-/
I do not know that can I try now...
INFO: File in BOOT BIN: "/home/dupont/Desktop/petalinux_2018.3/xilinx-zcu102-2018.3/pre-built/linux/images/zynqmp_fsbl.elf"
INFO: File in BOOT BIN: "/home/dupont/Desktop/petalinux_2018.3/xilinx-zcu102-2018.3/pre-built/linux/images/pmufw.elf"
INFO: File in BOOT BIN: "/home/dupont/Desktop/petalinux_2018.3/xilinx-zcu102-2018.3/pre-built/linux/images/system.bit"
INFO: File in BOOT BIN: "/home/dupont/Desktop/petalinux_2018.3/xilinx-zcu102-2018.3/images/linux/bl31.elf"
INFO: File in BOOT BIN: "/home/dupont/Desktop/petalinux_2018.3/xilinx-zcu102-2018.3/pre-built/linux/images/u-boot.elf"
****** Xilinx Bootgen v2018.3
**** Build date : Nov 15 2018-19:22:29
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: Binary is ready.
WARNING: Unable to access the TFTPBOOT folder /tftpboot!!!
WARNING: Skip file copy to TFTPBOOT folder!!!
Thanks for helping me
I follow https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/130973731/PetaLinux+Build+Tutorial+for+2019.1 to build image for ZCU111 release 2019.1 and also have this problem.
Console stops at "PMU-FW is not running, certain applications may not be supported.\n\r" and PetaLinux does not boot up.
According to xfsbl_misc_drivers.c, it seems to be this line of code which output the error message
if ((XFsbl_In32(PMU_GLOBAL_GLOBAL_CNTRL) &
    PMU_GLOBAL_GLOBAL_CNTRL_FW_IS_PRESENT_MASK) !=
    PMU_GLOBAL_GLOBAL_CNTRL_FW_IS_PRESENT_MASK) {
    XFsbl_Printf(DEBUG_PRINT_ALWAYS,"PMU-FW is not running, certain applications may not be supported.\n\r");
    UStatus = XFSBL_SUCCESS;
    goto END;
And this flag PMU_GLOBAL_GLOBAL_CNTRL_FW_IS_PRESENT_MASK seems to be set at xpfw_core.c
XStatus XPfw_CoreConfigure(void)
    u32 Idx;
    XStatus Status;
    if (CorePtr != NULL) {
       XPfw_InterruptStart();
       /* Set the FW_IS_PRESENT bit to flag that PMUFW is up and ready */
       XPfw_RMW32(PMU_GLOBAL_GLOBAL_CNTRL, PMU_GLOBAL_GLOBAL_CNTRL_FW_IS_PRESENT_MASK,
                   PMU_GLOBAL_GLOBAL_CNTRL_FW_IS_PRESENT_MASK);
       Status = XST_SUCCESS;
    } else {
       Status = XST_FAILURE;
    return Status;
But I have no clue that why it does not set properly.
dreaguns
Try this resource: PMU Firmware blog post!
