Visitor mainvoid
Petalinux and device tree memory node problem
Hi all,
New to the Petalinux framework. Got the following issue.
HDF maps a region of PL DDR into the PS address space:
We want to be able to read this memory from the PS for debugging purposes.
The problem is, when using this HDF the petalinux build generates device tree where the mapped region is used as the main system memory window:
memory {
    device_type = "memory";
    reg = <0xa8000000 0x8000000>;
Which is not we want as u-boot and linux start using it.
My workaround so fas has been to override the memory node in
PROJECT_ROOT/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
The platform is UltraScale+ MPSoC. With 64-bit APU default memory node looks like this
memory {
   reg = <0x0 0x0 0x0 0x80000000 0x8 0x0 0x0 0x80000000>;
Can anyone suggest why Petalinux overrides it with the HDF region and how to avoid this?
Many thanks!
Re: Petalinux and device tree memory node problem
Currently there is no support to load/boot u-boot and Linux from High memory(64-bit). U-boot has to load from low memory(32-bit DDR address).
Best Regards
Kranthi
Visitor mainvoid
Sorry, how is this related to the build framework overriding system memory layout?
