12-02-2020 11:06 AM
I just have a look at the command line reference guide UG 1157. I guess both the following commands download the respective image on the physical board using JTAG. What is the difference between downloading u-boot image and kernel image ?
$ petalinux-boot --jtag --u-boot
$ petalinux-boot --jtag --kernel
12-02-2020 11:55 AM
Hi @peterjohn
The --u-boot version only downloads the bootloader, leaving it up to you to load the kernel through other means (i.e. TFTP or from flash). The --kernel switch loads both, the bootloader and the kernel over JTAG, and then runs them.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
12-02-2020 01:24 PM
@patocarr is correct. if you want to see the difference just use the --tcl script.tcl and you will see the difference
12-03-2020 08:59 AM
This command "$ petalinux-boot --jtag --u-boot" downloads the following in ZYNQ.
- fsbl images/linux/zynq_fsbl.elf
- U-Boot images/linux/u-boot.elf
Similarly this command "$ $ petalinux-boot --jtag --kernel" downloads the following in ZYNQ.
- DTB images/linux/system.dtb
- kernel images/linux/zImage
I am wondering what is included in these files ? I mean which file contains bit file ? and what is included in zImage ?
12-03-2020 09:56 AM
Hi @peterjohn
It doesn't look like the --kernel option is loading the U-Boot as I pointed out above. Perhaps for Zynq is different than for ZynqMP. The zImage contains the kernel image and rootfs. The bitstream is loaded through the "fpga" command; you didn't see it in the .tcl output?
-Pat
12-04-2020 02:02 AM
Thanks for reply. This is what I was wondering that --kernel does not download u-boot for ZYNQ. If we need to download u-boot that it has to be loaded through --u-boot. Both commands --kernel and --u-boot does not download FPGA bitstream. The FPGA bitstream has to be loaded through --fpga command.
I also have looked at level 2 and level 3 prebuilt commands for ZYNQ. They actually does all what we need to run an application physically on the board.
$ petalinux-boot --jtag --prebuilt 2
The level 2 command downloads FPGA bitstream, FSBL and U-boot.
$ petalinux-boot --jtag --prebuilt 3
The level 3 command downloads FPGA bitstream, FSBL, U-boot and Kernel on target board.
