Newbie fkluger
Petalinux boot from QSPI flash without SD card on TE0720 (Zynq 7020)
I have a TE0720 (with a Zynq 7020 SoC) that is connected to a custom (though designed/made not by myself) carrier board that does not support an SD card. JTAG, UART and USB are the only peripheral connections available at the moment. Thus, I'm trying to bring Petalinux onto the TE0720's onboard SPI flash via JTAG.
I followed the Petalinux Board Bringup Guide (UG980), changed all "image storage media" options from "primary sd" to "primary flash" and --- after building the system image with petalinux-build --- created a boot image with:
petalinux-package --boot --fsbl /path/to/petalinux-project/images/linux/zynq_fsbl.elf --uboot --kernel
Then I programmed the resulting BOOT.BIN file onto the TE0720's flash via JTAG with the Xilinx SDK (Xilinx Tools --> Program Flash).
When I restart the board afterwards, I get the following output on the serial console:
U-Boot 2014.07 (May 28 2015 - 11:35:44)
DRAM:  ECC disabled 1 GiB
MMC:   zynq_sdhci: 0
SF: Detected W25Q256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   Gem.e000b000
U-BOOT for HelloLinux
Gem.e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Gem.e000b000: No link.
Hit any key to stop autoboot:  0
SF: 11010048 bytes @ 0x520000 Read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot-PetaLinux>
From here on, I'm kinda lost. It seems that the kernel image is either broken or loaded from an incorrect position but I don't know why and where to start troubleshooting.
Most of the advice I found so far was targeted at people trying to boot the kernel image from an SD card, which is not an option here unfortunately.
Can anybody help me? Thanks in advance!
(Using Petalinux 2014.4 and Xilinx SDK/Vivado 2014.4 on CentOS 6.6 32-bit)
Newbie fkluger
Re: Petalinux boot from QSPI flash without SD card on TE0720 (Zynq 7020)
I figured out a solution by myself:
The Kernel image was not read from the correct position in the QSPI flash. In order to find out which is the correct address to read from, I modified the .bif-file (./build/bootgen.bif)  that was generated by petalinux-package:
the_ROM_image:
	[bootloader] ./images/linux/zynq_fsbl.elf
	./images/linux/u-boot.elf
	./images/linux/image.ub
Then I executed:
bootgen -image newbif.bif -o test.bin -debug -w
The -debug is important here. This gave me:
*** After Link
-- Dump of Binary cache ----
00000000 Len: 000008a0 Res: 00000000 "BootHeader"
000008c0 Len: 00000014 Res: 00000000 "ImageHeaderTable"
00000900 Len: 00000024 Res: 00000000 "ImageHeader zynq_fsbl.elf"
00000940 Len: 00000020 Res: 00000000 "ImageHeader u-boot.elf"
00000980 Len: 00000020 Res: 00000300 "ImageHeader image.ub"
00000c80 Len: 00000040 Res: 00000000 "PartitionHeader zynq_fsbl.elf.0"
00000cc0 Len: 00000040 Res: 00000000 "PartitionHeader u-boot.elf.0"
00000d00 Len: 00000040 Res: 00000000 "PartitionHeader image.ub.0"
00000d40 Len: 00000040 Res: 000009c0 "PartitionHeader Null"
00001700 Len: 0001800c Res: 00000000 "zynq_fsbl.elf.0"
00019740 Len: 00043054 Res: 00000000 "u-boot.elf.0"
0005c7c0 Len: 00691ac0 Res: 00000000 "image.ub.0"
-- End of Dump
Here we see that the Kernel image is to be found at an offset of 0x0005c7c0 and has a length of 0x00691ac0.
The image can therefore be booted in u-boot by doing:
U-Boot-PetaLinux> sf read $netstart 0005c7c0 00691ac0
SF: 6888128 bytes @ 0x5c7c0 Read: OK
U-Boot-PetaLinux> bootm $netstart
This loads and successfully boots the kernel, finally presenting me a login prompt.
Hope this helps someone in the future.
Newbie fkluger
the_ROM_image:
Then I executed:
*** After Link
-- End of Dump
Observer engll
Yes, it sure does! I ran into the same problem on a different board and your solution also works for me!  Thanks!
Visitor hoople
Can you explain in more detail what you did for this:  "changed all "image storage media" options from "primary sd" to "primary flash""?
It's in the "petalinux-config" command that sets up the project.
to better add:
petalinux-config
then go to:
 subsystem auto hardware settings
then
 advanced bootable images storage settings
Visitor assiro
Hi bkamen,
can you explain what better config you mean? the partitions address?
this is the menu
thanks a lot
Visitor assiro
Hi bkamen,
thankyou
I wasn't talking about address -- I was talking about changing the project from using microSD or QSPI Flash.
It sounds like you are asking a different question.
 -Ben
Observer icyman
At first time, when you want to make the mcs file with using petalinux-package, as below
petalinux-package --force --format MCS --flash-size 256 --flash-intf SPIx4 --boot --fpga ~/project/wrapper.bit --u-boot --kernel
you can be faced to the error of Flash Boot Partition Size.
You need to change the size of the partition of the flash set in the menuconfig as below.
petalinux-config
Subsystem AUTO Hardware Settings --->, Flash Settings --->
There is partition size option.
Newbie bikashbag
I am new to xilinx development platform.
Can anyone please help me that how can I flash my compiled images along with rootfs to the board, the board has nand only.
You don't really need to do the -debug option with bootgen to tell you the partition offsets.. you can actually specify them yourself in the .bif file.
It's a bit of an artform getting the QSPI flash sorted. Other questions give example .bif files and give hints.
https://forums.xilinx.com/t5/Embedded-Linux/change-u-boot-on-flash-mtd-with-flashcp/td-p/344895
And this one is important too:
https://forums.xilinx.com/t5/Embedded-Linux/Where-does-U-Boot-saveenv-to/m-p/556802#M11041
Visitor cheng6
I'm having the same problem with petalinux 2015.4 and XSDK 2015.4.
It seems petalinux-package doesn't follow build/bootgen.bif created by itself. My bootgen.bif is a little different from fkluger's:
[, load=0x520000, partition_owner=uboot] /tmp/tmp.ESaD9pXOcu/image.ub
The offset 0x520000 matches the settings of petalinux-config and platform-auto.h. However, the "bootgen -image newbif.bif -o test.bin -debug -w" command shows a different offset for image.ub, e.g. 0x5c7c0. I tried adding an option "--offset 0x520000" for the kernel in petalinux-package command, but it doesn't change anything.
My current workaround is: Find out kernel's offset with fkluger's solution, then run petalinux-config and change the size of boot partition, so I can get a correct "kernelstart=0x5c7c0\0" in platform-auto.h. Then rebuild u-boot and run petalinux-package again. In this way I get a BOOT.BIN which can automatically load the kernel. It's inconvenient, but fortunately I don't have to do it often.
Thank you fkluger for sharing your solution. It really helps.
It's not entirely clear to me what you're trying to do.. (and part of that is from me not being familiar with petalinux).
Anyway, you've specified a "load" parameter, which says that partition should be loaded into memory at that address. Did you mean to specify "offset", which says that partition should have that particular offset within the BOOT.bin image?
There's a list of BIF file parameters here on page 57:
http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf
Also, here are some examples of loading using FSBL and loading using U-Boot.
http://www.wiki.xilinx.com/Prepare+boot+image
Visitor cheng6
Thanks to sam_jaeschke, finally I have a decent solution. The two links you posted are very useful.
I suspect petalinux-package somehow doesn't create the bin file properly, so I created my own bootgen.bif and use bootgen to create the image, and it fixed the problem.
Still there is something tricky: If I use "offset=xx", bootgen puts it exactly at the address instructed. But if I use "load=xx", bootgen still tries to "pack" it, and I always get a much smaller address. I'm now using "offset=xx" for dtb, and "load=xx" for kernel. To prevent bootgen from moving the kernel around, I put kernel partition at a nice aligned address and use "alignment=" in bootgen.bif for kernel.
Visitor kmadhu85
Even I am using same technique to work on our custom board.
But I having problem with loading rootfs.jffs2 which is flashed on nand. I don't want initramfs which comes along kernel.
I get error when kernel try to mount rootfs from nand and it  hangs.
Please find the attached log.
Note : I removed ramfs from image.ub.
using : petalinux v2016.4
xilinx SDK v2016.4 for program_flash utility.
Visitor ray110
Hi, I have a similar issue, I am trying to boot from a squash fs from flash, but the kernel is not picking it up and it leads to a kernel panic.
Anyone knows what the bootargs should be? root=/dev/mtd4?
Thanks for your time, I'm really struggling with that one.
Visitor patholden
I'm trying to follow the directions in "http://www.wiki.xilinx.com/Prepare+boot+image" using 2016.4, in particular the section for generating Linux BIF file:
image :
[bootloader]Zynq_FSBL1.elf
topblock_wrapper.bit
u-boot.elf
[offset=<dt_offset>]system.dtb
[offset=<ramdisk_offset>]rootfs.cpio.gz
[offset=<umige_offset>]mage.ub
When I run "bootgen -image MY-PROJ.bif -o BOOT.BIN", I get BOOTGEN syntax errors for dt-offset, ramdisk-offset, and uimage-offset.  I tried using "-" instead of "_" for offset names, got same BOOTGEN syntax errors.  Also with 2016.4, it doesn't seem that PetaLinux creates the ramdisk image, but does create the rootfs file, so I added that instead of the uramdisk.image.gz that is in this WIKI.  Is there a new way to use the default offsets for 2016.4 PetaLinux & XSDK?
As a side-note, is there any way that application notes can be updated to reflect the newer versions of SDK, Vivado, and PetaLinux?
I'll try it.
I want to boot petalinux from qspi.
Participant nturner
I'm having a similar problem as fkluger, except when I can't connect over serial at all after flashing.
I followed UG980, up until creating the boot image, where I used the command fkluger used. I'm still trying to get familiar with the process and tools, so the hw files I'm using are just from the TE test_board reference design. All the Xilinx tools I'm using are 2016.4 on Ubuntu 16.04 and the TE0720 is connected using a TE0701.
Since I'm still learning a lot of the ropes I suspect I'm missing an obvious step that just wasn't made explicit anywhere, or that was explicit and I just overlooked because I didn't recognize its significance.
EDIT: I forgot to add that the LED pattern on the TE0720 indicates that it is still trying to boot from SPI (Red blinking fast, near green off, far green on).
