Observer hariharan
Petalinux boot hangs in custom board - PLL Shutdown
I wanted to load Petalinux in a custom hardware, Attached is the  Boot log.
The kernel boot hangs in PPL Shutdown.
I followed the instructions said in this AR too.
https://www.xilinx.com/support/answers/69764.html
Still i am getting PLL Shutdown.
Kindly help me to resolve this issue.
Re: Petalinux boot hangs in custom board - PLL Shutdown
Hi @hariharan,
Can you try booting Linux along with bitstream included in your boot image?
Kranthi
Kindly mark this post as accepted solutions if provided information is helpful
Give a Kudos if you are satisfied with the Post.
Best Regards
Kranthi
Observer hariharan
Hi @gudishak,
The project is without any PL content should i go with a bit file?
Hi @hariharan,
I have encountered the same problem.
Is there a solution?
