shmadoge
Petalinux build on u-boot with "undefined reference to `ioremap_nocache'"
I'm trying to build linux distro for custom board with zynq and after configuring sw project i'm getting this error:
drivers/net/built-in.o: In function `emaclite_ofdata_to_platdata':
| /home/e_rush/work/test_boot/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2018.01-xilinx-v2018.2+gitAUTOINC+21812b5fd3-r0/git/drivers/net/xilinx_emaclite.c:602: undefined reference to `ioremap_nocache'
Manually changing line in xilinx_emaclite.c from:
emaclite->regs = (struct emaclite_regs *)ioremap_nocache(pdata->iobase,
0x10000);
to:
emaclite->regs = (struct emaclite_regs *)pdata->iobase;
lets me build but I don't think that is valid solution.
Do you guys have any idea how to prevent this?
Vivado and Petalinux version is 2018.2.
Tags (2)
shabbirk
It looks to me that uboot emaclite driver has not been updated being a legacy IP. I would suggest to disable the uboot driver and keep linux emaclite driver enabled. You can disable uboot driver using this step: petalinux-config -c u-boot -> Device  drivers -> Network device support -> emaclite
shabbirk
May I what changes have you done with ethernet in your design?
shmadoge
I don't think there is a problem with design(here it is https://drive.google.com/open?id=15GvklzztV2NUtktcJscMqIqp4rdOLh-i ), since I checked source code of xilinx u-boot and there is no function ioremap_nocache (which is called from emaclight driver) in arm/asm/io, it was deleted couple of years ago.
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/net/xilinx_emaclite.c
https://github.com/Xilinx/u-boot-xlnx/blob/master/arch/arm/include/asm/io.h
shabbirk
Is it possible to share your HDF?
Best Regards
Shabbir
shmadoge
shabbirk
stephenm
I seen this issue too. Seems like a bug. I patched driver same as you and has been working fine for me
kelemixx
+1 for same issue.
