Voyager
Voyager
Petalinux driver for AXI Interrupt Controller core
is there example code or guide on how to implement petalinux interrupt.  I have a custom ip that's using axi_lite connect to ARM-Zynq.  it can read register in polling mode but how do I send interrupt from my custom ip to ARM when my internal register updated from my other FPGA cores?  so the CPU doesn't need loop to check its register status, and only do so when register is changed.
Re: Petalinux driver for AXI Interrupt Controller core
Petalinux is a build system so has nothing to do with the interrupt. You need to connect the interrupt out to the IRQ_F2P port on the ARM. The ARM can only handle one interrupt so you have to use a concat block if you have multiple interrupt sources already.
Voyager
Voyager
I mean the c code application to use that IRQ port that I connected in FPGA
Voyager
Voyager
also the IRQ signal how long the FPGA has to hold high for IRQ to pass through 1 clk, or longer?
To see the interrupt in userspace without writing a kernel driver you will need to enable UIO in the kernel and change the compat string for you IP in the devicetree. Then you can write a C app in userspace to get the interrupt.
Voyager
Voyager
any example of such C app?
