Observer jwmurray
Petalinux hanging just as login prompt appears
I am running petalinux 2017.4 on custom hardware with a Zynq Ultrascale+, SOC, ZynqMP.  As petalinux comes up, it hangs, just about the time that the login prompt is issued.  Sometimes I am able to login for about 5 seconds.  Sometimes, not at all.
My bootlog is shown at the end of the post.
I have read through the other posts that are similar, but have not been able to see which one will help.
Any suggestions would be greatly appreciated.
Thank you!
John
Log:
john
Xilinx Zynq MP First Stage Boot Loader
Release 2017.4   May  1 2018  -  06:35:06
NOTICE:  ATF running on XCZU7CG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):47af34b
NOTICE:  BL31: Built : 13:19:31, May  1 2018
U-Boot 2017.01 (May 01 2018 - 07:20:21 -0600) Xilinx ZynqMP ZCU102 revB
I2C:   ready
DRAM:  1 GiB
EL Level:       EL2
Chip ID:        xczu7cg
MMC:   sdhci@ff160000: 0 (eMMC)
zynqmp_qspi_ofdata_to_platdata: CLK 300000000
SF: Detected n25q512a with page size 256 Bytes, erase size 64 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Bootmode: QSPI_MODE
Net:   ZYNQ GEM: ff0b0000, phyaddr ffffffff, interface moca
eth0: ethernet@ff0b0000ZYNQ GEM: ff0c0000, phyaddr ffffffff, interface moca
Warning: ethernet@ff0c0000 (eth1) using random MAC address - 2a:9e:cc:95:e3:b2
, eth1: ethernet@ff0c0000
U-BOOT for project_petalinux
Size exceeds partition or device limit
sf - SPI flash sub-system
Usage:
sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus
                                  and chip select
sf read addr offset|partition len       - read `len' bytes starting at
                                          `offset' or from start of mtd
                                          `partition'to memory at `addr'
sf write addr offset|partition len      - write `len' bytes from memory
                                          at `addr' to flash at `offset'
                                          or to start of mtd `partition'
sf erase offset|partition [+]len        - erase `len' bytes from `offset'
                                          or from start of mtd `partition'
                                         `+len' round up `len' to block size
sf update addr offset|partition len     - erase and write `len' bytes from memory
sf protect lock/unlock sector len       - protect/unprotect 'len' bytes starting
                                          at address 'sector'
U-Boot> tftpboot ssm_image.ub
Using ethernet@ff0b0000 device
TFTP from server 128.170.11.93; our IP address is 10.224.2.124; sending through gateway 10.224.0.1
Filename 'ssm_image.ub'.
Load address: 0x10000000
Loading: #################################################################
         2.4 MiB/s
done
Bytes transferred = 19319124 (126c954 hex)
U-Boot> bootm
   Using 'conf@1' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d8
     Data Size:    13378048 Bytes = 12.8 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   f703bedea89c0e378cabf4f36bf6fc204aa56001
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@0' ramdisk subimage
     Description:  ramdisk
     Type:         RAMDisk Image
     Data Start:   0x10cc9ce8
     Data Size:    5908598 Bytes = 5.6 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   d38e2ad489e4f24e64ed989765fa124be0ef6bca
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10cc23d0
     Data Size:    30819 Bytes = 30.1 KiB
     Hash algo:    sha1
     Hash value:   dc2ae5e48c9c9bc5d49fb8b3aa158d74af1b4f82
   Booting using the fdt blob at 0x10cc23d0
   Loading Kernel Image ... OK
   Loading Ramdisk to 07a5d000, end 07fff876 ... OK
   Loading Device Tree to 0000000007a52000, end 0000000007a5c862 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0-xilinx-v2017.4 (jwmurray@slvmctl13.csw.l-3com.com) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Tue May 1 07:24:47 MDT 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000030000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc02ffa7000 s48536 r8192 d29288 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258560
[    0.000000] Kernel command line: earlycon clk_ignore_unused
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 750892K/1048576K available (9084K kernel code, 584K rwdata, 2832K rodata, 512K init, 396K bss, 35540K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008960000   (  9088 KB)
[    0.000000]     .rodata : 0xffffff8008960000 - 0xffffff8008c30000   (  2880 KB)
[    0.000000]       .init : 0xffffff8008c30000 - 0xffffff8008cb0000   (   512 KB)
[    0.000000]       .data : 0xffffff8008cb0000 - 0xffffff8008d42200   (   585 KB)
[    0.000000]        .bss : 0xffffff8008d42200 - 0xffffff8008da55b4   (   397 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf00e00000   (    14 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=2
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 50.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
[    0.000003] sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns
[    0.008267] Console: colour dummy device 80x25
[    0.012525] console [tty0] enabled
[    0.015888] bootconsole [cdns0] disabled
[    0.019801] Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=200000)
[    0.019821] pid_max: default: 32768 minimum: 301
[    0.019936] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.019949] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.020627] ASID allocator initialised with 65536 entries
[    0.052010] zynqmp_plat_init Power management API v0.3
[    0.052129] EFI services will not be available.
[    0.274667] Detected VIPT I-cache on CPU1
[    0.274702] CPU1: Booted secondary processor [410fd034]
[    0.274757] Brought up 2 CPUs
[    0.274783] SMP: Total of 2 processors activated.
[    0.274797] CPU features: detected feature: 32-bit EL0 Support
[    0.274814] CPU: All CPU(s) started at EL2
[    0.274835] alternatives: patching kernel code
[    0.275469] devtmpfs: initialized
[    0.281282] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.287188] xor: measuring software checksum speed
[    0.324291]    8regs     :  2302.000 MB/sec
[    0.364300]    8regs_prefetch:  2052.000 MB/sec
[    0.404339]    32regs    :  2830.000 MB/sec
[    0.444382]    32regs_prefetch:  2379.000 MB/sec
[    0.444401] xor: using function: 32regs (2830.000 MB/sec)
[    0.444645] pinctrl core: initialized pinctrl subsystem
[    0.445606] NET: Registered protocol family 16
[    0.464416] cpuidle: using governor menu
[    0.464718] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.464861] vdso: 2 pages (1 code @ ffffff8008967000, 1 data @ ffffff8008cb4000)
[    0.464893] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.465861] DMA: preallocated 256 KiB pool for atomic allocations
[    0.480203] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.481319] ARM CCI_400_r1 PMU driver probed
[    0.487342] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.520874] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.596673] raid6: int64x1  gen()   406 MB/s
[    0.664749] raid6: int64x1  xor()   441 MB/s
[    0.732915] raid6: int64x2  gen()   676 MB/s
[    0.800974] raid6: int64x2  xor()   599 MB/s
[    0.869016] raid6: int64x4  gen()   984 MB/s
[    0.937114] raid6: int64x4  xor()   740 MB/s
[    1.005209] raid6: int64x8  gen()  1145 MB/s
[    1.073292] raid6: int64x8  xor()   746 MB/s
[    1.141378] raid6: neonx1   gen()   720 MB/s
[    1.209494] raid6: neonx1   xor()   758 MB/s
[    1.277596] raid6: neonx2   gen()  1166 MB/s
[    1.345658] raid6: neonx2   xor()  1031 MB/s
[    1.413758] raid6: neonx4   gen()  1501 MB/s
[    1.481834] raid6: neonx4   xor()  1179 MB/s
[    1.549937] raid6: neonx8   gen()  1584 MB/s
[    1.617997] raid6: neonx8   xor()  1217 MB/s
[    1.618014] raid6: using algorithm neonx8 gen() 1584 MB/s
[    1.618031] raid6: .... xor() 1217 MB/s, rmw enabled
[    1.618048] raid6: using intx1 recovery algorithm
[    1.619742] SCSI subsystem initialized
[    1.620275] usbcore: registered new interface driver usbfs
[    1.620368] usbcore: registered new interface driver hub
[    1.620460] usbcore: registered new device driver usb
[    1.620680] media: Linux media interface: v0.10
[    1.620757] Linux video capture interface: v2.00
[    1.620862] pps_core: LinuxPPS API ver. 1 registered
[    1.620881] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.620949] PTP clock support registered
[    1.621051] EDAC MC: Ver: 3.0.0
[    1.621644] FPGA manager framework
[    1.621961] fpga-region fpga-full: FPGA Region probed
[    1.622188] Advanced Linux Sound Architecture Driver Initialized.
[    1.622745] Bluetooth: Core ver 2.22
[    1.622817] NET: Registered protocol family 31
[    1.622834] Bluetooth: HCI device and connection manager initialized
[    1.622860] Bluetooth: HCI socket layer initialized
[    1.622883] Bluetooth: L2CAP socket layer initialized
[    1.622930] Bluetooth: SCO socket layer initialized
[    1.632084] clocksource: Switched to clocksource arch_sys_counter
[    1.632202] VFS: Disk quotas dquot_6.6.0
[    1.632266] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.640433] NET: Registered protocol family 2
[    1.640941] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    1.641015] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    1.641184] TCP: Hash tables configured (established 8192 bind 8192)
[    1.641261] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.641298] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.641454] NET: Registered protocol family 1
[    1.645754] RPC: Registered named UNIX socket transport module.
[    1.645771] RPC: Registered udp transport module.
[    1.645786] RPC: Registered tcp transport module.
[    1.645800] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.645979] Trying to unpack rootfs image as initramfs...
[    1.892673] Freeing initrd memory: 5768K (ffffffc007a5d000 - ffffffc007fff000)
[    1.893045] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.894313] futex hash table entries: 512 (order: 4, 65536 bytes)
[    1.894385] audit: initializing netlink subsys (disabled)
[    1.894455] audit: type=2000 audit(1.880:1): initialized
[    1.895350] workingset: timestamp_bits=62 max_order=18 bucket_order=0
[    1.900177] NFS: Registering the id_resolver key type
[    1.900215] Key type id_resolver registered
[    1.900232] Key type id_legacy registered
[    1.900257] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.900297] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.909762] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.909803] io scheduler noop registered
[    1.909820] io scheduler deadline registered
[    1.909843] io scheduler cfq registered (default)
[    1.911410] Write failed gate address:1000f02
[    1.911616] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.911838] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.912051] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.912280] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.912488] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.912696] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.912911] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.913118] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.913403] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.913610] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.913822] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.914029] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.914237] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.914442] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.914651] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.914856] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.915133] zynqmp_pm firmware: Power management API v0.3
[    1.915316] xenfs: not registering filesystem on non-xen platform
[    1.958356] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.959971] [drm] Initialized
[    1.960502] Unable to detect cache hierarchy from DT for CPU 0
[    2.032003] brd: module loaded
[    2.036113] loop: module loaded
[    2.037118] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.037908] zynqmp-qspi ff0f0000.spi: rx bus width not found
[    2.038887] m25p80 spi0.0: n25q512a (65536 Kbytes)
[    2.038934] 3 ofpart partitions found on MTD device spi0.0
[    2.038953] Creating 3 MTD partitions on "spi0.0":
[    2.038974] 0x000000000000-0x000001600000 : "boot"
[    2.043747] 0x000001600000-0x000001640000 : "bootenv"
[    2.048487] 0x000001640000-0x000003640000 : "kernel"
[    2.054411] libphy: Fixed MDIO Bus: probed
[    2.055980] tun: Universal TUN/TAP device driver, 1.6
[    2.056000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.056282] CAN device driver interface
[    2.057011] macb ff0b0000.ethernet: Not enabling partial store and forward
[    2.061270] libphy: MACB_mii_bus: probed
[    2.061308] mdio_bus ff0b0000.etherne: /amba/ethernet@ff0b0000/fixed-link has invalid PHY address
[    2.061340] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 0
[    2.063332] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 1
[    2.065176] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 2
[    2.066909] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 3
[    2.068778] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 4
[    2.070530] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 5
[    2.072289] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 6
[    2.074050] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 7
[    2.075764] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 8
[    2.078100] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 9
[    2.079871] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 10
[    2.081691] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 11
[    2.083403] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 12
[    2.085240] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 13
[    2.087002] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 14
[    2.088767] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 15
[    2.090498] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 16
[    2.092271] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 17
[    2.094033] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 18
[    2.095747] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 19
[    2.097525] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 20
[    2.099250] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 21
[    2.101095] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 22
[    2.102835] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 23
[    2.104590] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 24
[    2.106315] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 25
[    2.108018] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 26
[    2.109794] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 27
[    2.111495] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 28
[    2.113272] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 29
[    2.115010] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 30
[    2.116848] mdio_bus ff0b0000.etherne: scan phy fixed-link at address 31
[    2.188108] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 29 (00:0a:35:00:22:01)
[    2.188143] Generic PHY fixed-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=fixed-0:00, irq=-1)
[    2.188506] macb ff0c0000.ethernet: Not enabling partial store and forward
[    2.191038] libphy: MACB_mii_bus: probed
[    2.191065] mdio_bus ff0c0000.etherne: /amba/ethernet@ff0c0000/fixed-link has invalid PHY address
[    2.191095] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 0
[    2.191214] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 1
[    2.191326] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 2
[    2.191437] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 3
[    2.191549] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 4
[    2.191660] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 5
[    2.191771] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 6
[    2.191883] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 7
[    2.191994] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 8
[    2.192108] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 9
[    2.192221] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 10
[    2.192332] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 11
[    2.192444] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 12
[    2.192555] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 13
[    2.192667] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 14
[    2.192778] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 15
[    2.192889] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 16
[    2.193001] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 17
[    2.193112] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 18
[    2.193223] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 19
[    2.193334] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 20
[    2.193446] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 21
[    2.193557] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 22
[    2.193668] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 23
[    2.193780] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 24
[    2.193891] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 25
[    2.194002] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 26
[    2.194113] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 27
[    2.194225] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 28
[    2.194336] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 29
[    2.194447] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 30
[    2.194558] mdio_bus ff0c0000.etherne: scan phy fixed-link at address 31
[    2.268104] macb ff0c0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0c0000 irq 30 (2a:9e:cc:95:e3:b2)
[    2.268135] Generic PHY fixed-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=fixed-0:01, irq=-1)
[    2.268912] usbcore: registered new interface driver asix
[    2.268999] usbcore: registered new interface driver ax88179_178a
[    2.269052] usbcore: registered new interface driver cdc_ether
[    2.269104] usbcore: registered new interface driver net1080
[    2.269158] usbcore: registered new interface driver cdc_subset
[    2.269210] usbcore: registered new interface driver zaurus
[    2.269279] usbcore: registered new interface driver cdc_ncm
[    2.269978] usbcore: registered new interface driver uas
[    2.270045] usbcore: registered new interface driver usb-storage
[    2.270494] mousedev: PS/2 mouse device common for all mice
[    2.271196] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.271263] i2c /dev entries driver
[    2.271597] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    2.273353] usbcore: registered new interface driver uvcvideo
[    2.273371] USB Video Class driver (1.1.1)
[    2.273985] Bluetooth: HCI UART driver ver 2.3
[    2.274005] Bluetooth: HCI UART protocol H4 registered
[    2.274022] Bluetooth: HCI UART protocol BCSP registered
[    2.274040] Bluetooth: HCI UART protocol LL registered
[    2.274057] Bluetooth: HCI UART protocol ATH3K registered
[    2.274075] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.274156] Bluetooth: HCI UART protocol Intel registered
[    2.274235] Bluetooth: HCI UART protocol Broadcom registered
[    2.274253] Bluetooth: HCI UART protocol QCA registered
[    2.274315] usbcore: registered new interface driver bcm203x
[    2.274380] usbcore: registered new interface driver bpa10x
[    2.274442] usbcore: registered new interface driver bfusb
[    2.274505] usbcore: registered new interface driver btusb
[    2.274523] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.274614] usbcore: registered new interface driver ath3k
[    2.274828] EDAC MC: ECC not enabled
[    2.275089] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.275930] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1200000 KHz
[    2.275970] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1200000000 (-34)
[    2.276054] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    2.277009] sdhci: Secure Digital Host Controller Interface driver
[    2.277047] sdhci: Copyright(c) Pierre Ossman
[    2.277079] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.324128] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    2.326793] ledtrig-cpu: registered to indicate activity on CPUs
[    2.333391] usbcore: registered new interface driver usbhid
[    2.333429] usbhid: USB HID core driver
[    2.339870] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    2.342482] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.343588] Netfilter messages via NETLINK v0.30.
[    2.343860] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.343980] Initializing XFRM netlink socket
[    2.345816] NET: Registered protocol family 10
[    2.352919] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.353033] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.354125] NET: Registered protocol family 17
[    2.354185] NET: Registered protocol family 15
[    2.354242] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.354302] Ebtables v2.0 registered
[    2.354396] can: controller area network core (rev 20120528 abi 9)
[    2.354517] NET: Registered protocol family 29
[    2.354553] can: raw protocol (rev 20120528)
[    2.354586] can: broadcast manager protocol (rev 20161123 t)
[    2.354629] can: netlink gateway (rev 20130117) max_hops=1
[    2.355302] Bluetooth: RFCOMM TTY layer initialized
[    2.355348] Bluetooth: RFCOMM socket layer initialized
[    2.355403] Bluetooth: RFCOMM ver 1.11
[    2.355447] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.355481] Bluetooth: BNEP filters: protocol multicast
[    2.355525] Bluetooth: BNEP socket layer initialized
[    2.355559] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.355603] Bluetooth: HIDP socket layer initialized
[    2.356030] 9pnet: Installing 9P2000 support
[    2.356127] Key type dns_resolver registered
[    2.360242] registered taskstats version 1
[    2.364193] Btrfs loaded, crc32c=crc32c-generic
[    2.385414] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 38, base_baud = 6250000) is a xuartps
[    2.440142] mmc0: new HS200 MMC card at address 0001
[    2.449386] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    2.453692] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    2.457997] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    2.462288] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    4.359312] console [ttyPS0] enabled
[    4.536013] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:23 UTC (23)
[    4.544393] clk: Not disabling unused clocks
[    4.548657] ALSA device list:
[    4.551560]   No soundcards found.
[    4.556404] Freeing unused kernel memory: 512K (ffffffc000c30000 - ffffffc000cb0000)
INIT: version 2.88 booting
Starting udev
[    4.760389] udevd[1629]: starting version 3.2
[    4.765558] random: udevd: uninitialized urandom read (16 bytes read)
[    4.772130] random: udevd: uninitialized urandom read (16 bytes read)
[    4.778684] random: udevd: uninitialized urandom read (16 bytes read)
[    4.785174] random: udevd: uninitialized urandom read (16 bytes read)
[    4.799857] udevd[1630]: starting eudev-3.2
[    4.911875] random: udevd: uninitialized urandom read (16 bytes read)
[    5.202615] random: fast init done
Populating dev cache
Tue May  1 14:15:23 UTC 2018
Starting internet superserver: inetd.
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... [    6.856912] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting Dropbear SSH server: Generating key, this may take a while...
[    7.884147] macb ff0b0000.ethernet eth0: link up (1000/Full)
[    7.889819] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCEaz0EEpqk+dx+C/grrLki5zYUHUyJCDNNxC4oL0Q27WYNrhZCnNBo9RxguPtFadttJ03jDuz04vizKsgzvChYe+znL5vA5bsNvASMtrftArbBfkWejK5Zbv3UlGhrRxB5gbLnxquSgyuTL1P1j6ySSYRCJCbtr7BcS6m8IVcWdXaFwYNzTs9PS4DniTuHIaX5QLE2LEB6Ljt7LS0R2lcmwQIcuuNkzrHOkjBHlWOdEQqZ9jlGAMH6GD0ouWGLtjGj4Sa7k7YGf9oLFPGanmUCChL80je3UzUFKNbKc6ZyD3zivRhdOjXtZDS+FKcoYSbL8wR4Ww1pmzU7ffR5nOp3 root@project_petalinux
Fingerprint: md5 e2:1d:de:49:61:3b:11:21:b3:db:ea:14:64:b2:26:91
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2017.4 project_petalinux /dev/ttyPS0
project_petalinux login:
Re: Petalinux hanging just as login prompt appears
The reason I asked was the JTAG connected is because there is a known issue here:
https://www.xilinx.com/support/answers/69143.html
From the sounds of your issue, this could be your problem
Can you make sure you have no jtag cable open?
Observer jwmurray
I have been loading the images over jtag.  I have also tested helloworld and memory tests using jtag.
The run that you see is from a BOOT.BIN that was programmed into flash over jtag and then Linux loaded into memory using tftpboot followed by a bootm command.  So the actual run does  not include jtag.
However, I have repeated this sequence 30 times going back and forth with jtag and flash and tftpboot.
With that being said, I am not sure what else to look for to see if jtag is not connected.  I have not disconnected it.
Thank you for your suggestions.  Let me know if I need to approach the jtag issue differently.
john
Observer jwmurray
This is looking promising.  I am still testing it.  Thank you!  I will re-post if this fixes the issue.
Currently, I have only been able to configure the bootargs from u-boot.  The fix as a petalinux-config did not work, but I am not sure if that has something to do with my tree.
Was this the issue?
Observer jwmurray
Yes.  Thank you!!!
Observer jwmurray
This solved the problem.  I am confused why the code would work on our evaluation board but then fail on a custom-built board.  Does this indicate that our hardware design could be corrected in order to avoid this bug?
I found this other post to be helpful:
https://forums.xilinx.com/t5/Embedded-Linux/Embedded-linux-system-are-not-stable/td-p/774093
Thank you,
John
Observer sjmjk429
I am seeing a very similar problem on my Zynq7000 based board -- the Linux will boot all the way to the login prompt and then lock up, and this happens on every boot-up.
I tried some of the solutions given in this post with no success (I understand that these solutions apply to a zynqMP board and not zynq7000, but I thought I'd try anyway):
- Disabling CPU_IDLE in the kernel,
- Booting with the following added to bootargs: clk_ignore_unused cpuidle.off=1,
- and booting with the JTAG disconnected
Has anyone experienced this problem on a Zynq7000 board, or have any other suggestions I can try to get passed this issue?
I'm suspecting the problem has something to do with my custom .hdf and bitstream, but I've used this bitstream successfully with SDK to run FreeRTOS applications.
Here are the steps I took to build Linux. I am building with PetaLinux 2018.1.
% petalinux-create -t project --template zynq --name petalinux-proj
% petalinux-config --get-hw-description <directory of my .hdf>
- boot size in Flash Settings increased to 0xc00000 to accomodate bitstream
- MACHINE_NAME set to zc702
% petalinux-config -c kernel
- set to CONFIG_DEBUG_ZYNQ_UART0 instead of UART1 (on my board ps_uart0 is used instead of ps_uart1)
I then created a BOOT.BIN and flashed to my board:
% petalinux-build
% petalinux-package --boot --format BIN --fsbl --fpga <my bitstream> --u-boot --kernel
U-boot appears to work fine, including tftpboot. Here is my kernel boot output:
Zynq> tftpboot 0x10000000 solo4/image.ub
Using ethernet@e000b000 device
TFTP from server 192.168.118.189; our IP address is 192.168.118.123
Filename 'solo4/image.ub'.
7.2 MiB/s
done
Bytes transferred = 10018276 (98dde4 hex)
Zynq> setenv bootargs 'console=ttyPS0,115200n8 earlycon clk_ignore_unused cpuidle.off=1'
Zynq> bootm
Using 'conf@system-top.dtb' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x10000104
Data Size: 3963585 Bytes = 3.8 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: c9996457045e261626ef1d8c7e1342fee06656da
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Data Start: 0x103d0554
Data Size: 6017795 Bytes = 5.7 MiB
Architecture: ARM
OS: Linux
Hash algo: sha1
Hash value: 1aa779c37c64dd597e63f0cb6d02da54cc6f17a1
Trying 'fdt@system-top.dtb' fdt subimage
Data Start: 0x103c7cc8
Data Size: 34761 Bytes = 33.9 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 061bfc425857a6ce7d9e2247359bc456561c68e0
Booting using the fdt blob at 0x103c7cc8
Uncompressing Kernel Image ... OK
Loading Ramdisk to 07a42000, end 07fff303 ... OK
Loading Device Tree to 07a36000, end 07a417c8 ... OK
Starting kernel ...
Linux version 4.14.0-xilinx-v2018.1 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP PREEMPT Tue Aug 7 09:45:52 CDT 2018
OF: fdt: Machine model: Zynq ZC702 Development Board
earlycon: cdns0 at MMIO 0xe0000000 (options '115200n8')
Memory policy: Data cache writealloc
cma: Reserved 16 MiB at 0x1f000000
percpu: Embedded 16 pages/cpu @debb9000 s34764 r8192 d22580 u65536
Built 1 zonelists, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyPS0,115200n8 earlycon clk_ignore_unused cpuidle.off=1
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 487096K/524288K available (6144K kernel code, 243K rwdata, 1584K rodata, 1024K init, 154K bss, 20808K reserved, 16384K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0700000 (7136 kB)
.init : 0xc0900000 - 0xc0a00000 (1024 kB)
.data : 0xc0a00000 - 0xc0a3ce60 ( 244 kB)
.bss : 0xc0a3ce60 - 0xc0a639c4 ( 155 kB)
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Tasks RCU enabled.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to e0800000
slcr mapped to e0802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at e0802100
Zynq clock init
sched_clock: 64 bits at 199MHz, resolution 5ns, wraps every 4398046511102ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x2e2049cb99, max_idle_ns: 440795211806 ns
Switching to timer-based delay loop, resolution 5ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 597261305 ns
timer #0 at e080a000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 399.99 BogoMIPS (lpj=1999999)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x100000 - 0x100060
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (799.99 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
DMA: preallocated 256 KiB pool for atomic coherent allocations
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0840000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
console [ttyPS0] enabledat MMIO 0xe0000000 (irq = 27, base_baud = 6249999) is a xuartps
e0001000.serial: ttyPS1 at MMIO 0xe0001000 (irq = 28, base_baud = 6249999) is a xuartps
vgaarb: loaded
EDAC MC: Ver: 3.0.0
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Freeing initrd memory: 5880K
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=17 bucket_order=0
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 83000000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83000000.dma failed with error -2
xilinx-vdma 83010000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83010000.dma failed with error -2
xilinx-vdma 83020000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83020000.dma failed with error -2
xilinx-vdma 83030000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83030000.dma failed with error -2
xilinx-vdma 83100000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83100000.dma failed with error -2
xilinx-vdma 83110000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83110000.dma failed with error -2
xilinx-vdma 83300000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83300000.dma failed with error -2
xilinx-vdma 83400000.dma: failed to get axi_aclk (-2)
xilinx-vdma: probe of 83400000.dma failed with error -2
81a00000.serial: ttyS2 at MMIO 0x81a01000 (irq = 51, base_baud = 8324187) is a 16550A
81a10000.serial: ttyS1 at MMIO 0x81a11000 (irq = 52, base_baud = 8324187) is a 16550A
brd: module loaded
loop: module loaded
m25p80 spi0.0: found n25q00a, expected n25q512a
m25p80 spi0.0: n25q00a (262144 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000c00000 : "boot"
0x000000c00000-0x000000c20000 : "bootenv"
0x000000c20000-0x0000016a0000 : "kernel"
0x0000016a0000-0x000010000000 : "spare"
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 23
cdns-i2c e0005000.i2c: 400 kHz mmio e0005000 irq 24
pca954x 1-0074: probe failed
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at e096d000 with timeout 10s
Xilinx Zynq CpuIdle Driver started
failed to register cpuidle driver
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
Segment Routing with IPv6
can: controller area network core (rev 20170425 abi 9)
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20170425) max_hops=1
input: gpio-keys as /devices/soc0/gpio-keys/input/input0
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
Freeing unused kernel memory: 1024K
Starting udev
udevd[803]: starting version 3.2.2
udevd[804]: starting eudev-3.2.2
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue Aug 7 14:46:40 UTC 2018
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Configuring network interfaces... Cannot find device "eth0"
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCbuodqV3+PlsLFYmCl6sGgp2d7ncQlM2G0LRTDnNCRlzYAQEsBrl5FhIu099EZ2QA4he9JECxTOVcBatMIG2eVzojL27h4i4Goc2ykGvK/BiGZ02GACZi3sx6/3gi9gOeRO0yPACV+Mkkr1JkSUG8/KGaBO1rSATdQBprIVoPhiTkxW0cXzGcc1SXcb44BbM1HHsLcoTp7mzkQCZL4A2O+QBMvfC00RHumSsAwbY1VCzJwAhvdlLZwQ8KgeyDbkEdru1bqwkT4gzZpptshbXh/KYSdywImMWzZZxsOQobFLXq50ggsSXiPID6pR2uZA2WGzRX/lTzeUzlW3xyrbq+5 root@solo4
Fingerprint: md5 4d:b7:09:e1:f5:10:70:fa:16:cb:df:33:ea:a9:af:8e
dropbear.
PetaLinux 2018.1 solo4 /dev/ttyPS0
solo4 login:<hangs here, cannot type>
